Question about Air Tools & Compressors
What is proper framing nails - Air Tools & Compressors
    Master:
  • 301 Answers
It depends on how deep you want to nail to go.
Tips for Using Finish Nailer
Posted on Apr 09, 2015
Senco frame pro 601 turns nail upside down with nail head going in wood first
The nails can turn over if you have the wrong angle or gauge nails in the tool. Make sure you are using the proper nails for your gun because they are not all the same.
Feb 19, 2015 | Senco Tools & Hardware - Others
Misfires new gun
If your using refills that have wire holding the nails together.
Check to see if bits of wire, debris is collecting in around the striking hammer. I switched to paper and never looked back. Must have gone through 5k worth of nails and rarely jams. Other things to check,
1. Check the striking hammer, make sure it is not bent or damaged.
2. Check air pressure, Low pressure can cause jamming, misfires.
3. If the tool needs pneumatic oil, 2-3 drops before you start good rule of thumb.
4. Check spring return. Sufficient pressure must be maintained or the nails will not feed properly. Misfires, incorrect feed, jamming etc.
I had a Hitachi brad nailer and it was horrible. Fire 1 brad nail would jam or misfire. Did everything I could think of nothing worked. Put it up, got a Rigid brad nailer and never looked at the Hitachi again. :)
Sometimes you just get a lemon! (PS I understand you have a framing nail gun. Brad nail gun above is used for an example)
Hope this helps
Mar 24, 2014 | Hitachi KNR90AE Round Head Framing Combo...
My 601 won't shoot any spikes it just leaves a 1/4 '' indent were nail should be?
If you're getting an indent in the wood from the driver, the gun is working properly. If the gun isn't driving fasteners/nails it's because the nail isn't under the driver when it's activated. Several things could cause this: Having the wrong angle nails in your gun. There is something in the feed path of the nails preventing them from feeding fully into the nose piece. The feed shoe is jambed or feed shoe spring is broken.
Feb 18, 2013 | Senco & Frame Pro 601 Framing Nailer
I just bought a used Bostitch Coil Nailer. 3 1/4" nails work fine but the 2" nails will not keep feeding.
Check the spacing of the nail collation between the two nail sizes and also the spacing of the copper wires. Some nailers have a different setting for the check paws on the latch door to compensate for the thinner nails (too much clearance between the latch door and body of gun). Check manual at www.bostich.com for proper setting of check paws between nail types. Good luck
Oct 12, 2010 | Stanley Bostitch Coil Framing Nailer
2 nails shoot at the same time
It could be just from using poorly clipped or collated nails. I have noticed that with some cheaper nails, the clipped heads are not all lined up properly. If a nail has rotated slightly during the collation proccess, the unclipped portion of the nail head protrudes over the previous nail in the clip. This causes the heads of two nails to be struck at once. Another problem I've encountered is collation wire that doesn't shear off with each nail. An ever lengthening strand of wire protrudes into the nail chamber and eventually the driver snags this wire as it drives a nail. This jerks the clip forward forcefully forcing more than one nail into the chamber or causing the next nails in line to rotate slightly, thus exposing the unclipped portion of the nail heads to the driver.
Mar 13, 2010 | Tools & Hardware - Others
MY NAIL NOTIS SHOOTING AND BENDING THE NAIL INSIDE THE GUN
you have a problem with the nose or the driver. I would also check for a jammed nail in the nose assembly. let me know what the model number is and I will try and find a breakdown for you.
Sep 18, 2009 | Stanley Bostitch Coil Framing Nailer
Nail comes out another hole
are you using the right nails and are they inserted properly if this is an angle gun? Also look for a jammed nail that might be causing this. look at the magazine bolts to make sure they are tight. You can go to Paslode.com for the owners manual and troubleshooting guide.
Sep 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
NAILER WONT FIRE NAILS
DO NOT USE WD40 . Is The Nailer fireing? If Not check the micro switch by the fan . Make sure it is pushing on the switch.. Otherwise bend it a little
Jul 06, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Jun 11, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
Framing nailer intermittently doesn't shoot the nail.
Make sure to blow out the magazine where the nails load, make sure the spring tension on the nail clip is working properly, make sure you're not holding the clip somehow with your off hand so the clip can't feed correctly.
Apr 20, 2009 | Tools & Hardware - Others
Air Tools & Compressors Logo
188 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
