When I push the start botton it begins, then I smell burning rubber and it shuts off
    Top Expert:
  • Washing Mach... Master
  • 51,127 Answers
Call the local repair man
Posted on Apr 09, 2015
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Have electrical issues with 1996 T&C van. Problem with Remote Starter and smoke and smell of burning rubber. Had to disconnect battery to get the van to stop trying to start. When i drove it home, it...
Yes it is . The remote starter wire has touch together and is wanting to start the starter, they have shorted together, The burning rubber smell is the wire melting due to the electrical short. Take the remote starter out plus the push button and reinstall using new set of wire And if you decide to install a new remote starter youll have to install a fuse in line with the positive wire.
Apr 24, 2011 | 1996 Chrysler Town & Country
Miele Vacuum Cleaner - burning smell / motor won't stay on
check brush the belt may have popped off and is binding or brush is binding clean brush of any debris thread/hair wrapped binding brush and check and or replace belt
Mar 24, 2010 | Miele S318 Bagged Canister Vacuum
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
My frigidaire dryer had burning rubber smell now wont turn on
soulds like the fuse in the unit overloaded, fluff or oter items may have fallen onto the element, or the unit was overloaded, and the belt was slipping on the motor drive pulley. check for rubber drive belt debri. replace damaged items as required.
Jan 25, 2009 | Frigidaire GLER642A Electric Dryer
Frigidare top loading washer 6 cycle - 10 years old
you may want to inspect the bottom part and see if it still uses fan belt. it could be that the belt is loose and the motor is spinning but can not drive the transmission. so the rubber burning smell is coming from the slipping belt.
the solution is to tighten the belt or replace it if necessary.
tnx 4 using fixya,
drcool
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Refrigerator burning rubber smell when it tries to turn on
sounds like the relay on the compressors is getting hot and cutting the unit out, if the fridge is quite old it may well be the run windings gone short circuit in the compressor pot. The relay switches from start to run windings so may be firing the start circuit, switching over to a shorted run winding, and then getting hot and activating the thermal cutout and hence the burnig smell, plus the start and rapid shut down of the compressor.
Mar 19, 2008 | Refrigerators
Burning Smell
Keep it unplugged and look for burned wires, or rubber wires hardened from extreme heat. This will be a good start in finding what is going wrong. One more thing to check is if the compressor is heating up after running for a while. Let it run for 20 min or so, shut off the power and feel the compressor. Is it hot?
Jan 12, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
