Question about Senco Air Tools & Compressors
Proper nails for a SENCO SN IV - Senco Air Tools & Compressors
    New Friend:
  • 131 Answers
2" to 3 1/2" 2" for sheathing and 3 1/2" for stud framing.
Posted on Apr 24, 2015
3 Suggested Answers
  • 31 Answers
SOURCE: SENCO COIL ROOFING GUN DOESNT ADVANCE NAILS
Clean the track and piston by removing nail tray (there are a couple of allen screws)and removing the gunk from the nail tape and if you have been shooting something glued that to. Remove head assembly and thoroughly clean and oil that also. that should fix you right up I have a couple of these guns and that is typical.
If that is no the problem rebuild the gun it is worth it as they are a great air gun
Hope this helped
Posted on Dec 30, 2009
  • 1388 Answers
SOURCE: I have seen many nails that supposedly fit the
Senco uses 33 degree paper tape clip head, however many generic brands will label their box 30-34 degree to fit several nailers. This practice causes jams in some guns and others work fine. The goal is to save money but could cost more in the long run if gun is damaged. You can use generic (other than 33) if you take a strip of nails and place them against the outside of the rails aligned with either the line of driver path of angle of the rails. This will give you a visual as to the alignment. Best result is when the complete nail is in line with the path of driver. Next best result is when the head is in the path of driver and point of nail is slightly away from path, worst is when point hits path and head is back. Good luck
Posted on Mar 27, 2011
My Senco finish nail gun only shoots a nail every OTHER pull of the trigger. It's a model SFN30 and does this about 65% of the time. It's clean and has really had very little use.
Your driver is not returning fully.
Most often this is caused by:
1) A bent driver blade - pull the driver out and inspect it, make sure it is straight.
2) A broken seal o-ring on the bottom end of the cylinder (#66)
Senco SFN30 15 Ga Finish Nailer Parts
Feb 16, 2017 | Senco Air Tools & Compressors
Senco frame pro 601 turns nail upside down with nail head going in wood first
The nails can turn over if you have the wrong angle or gauge nails in the tool. Make sure you are using the proper nails for your gun because they are not all the same.
Feb 19, 2015 | Senco Tools & Hardware - Others
Why does my Senco SN 901 XP frame nailers driver stay forward?
not sure what powers the senco if it works on combustion or air could be damage O rings. Another possibility is a trapped nail under the blade. Have seen where a nail has not been driven out of the magazine but has bent and points down the magazine close to end of gun. What happens is the blade drives over the nail but becomes trapped between nail and roof of the nose assy. Probably need to strip the gun a little.
Mar 24, 2014 | Tools & Hardware - Others
SN IV shoots nail fine but loses air out the top
Exhaust seal insite the top on top or gasket ?
Feb 14, 2014 | Senco Air Tools & Compressors
My senco frame nail gun isn`t working
First get an exploded view of gun and parts list and numbers from senco.com,,take nail gun apart,,,take a good look at the rubber bumper stop to see if it is broken,,look at the driver nut to see if it is tight,,,,you can go to juldan.com once you have gotten a list of the worn parts,,,juldan sells complete o ring kits along with nearly all parts needed for your repair
Jan 18, 2013 | Senco Air Tools & Compressors
My old Senco SN-IV just blows the driver out when air is plugged into it, and does not cycle through a complete cycle,what coud be the problem?
This is most likely caused by either a faulty trigger valve or the ring on the outside of the cylinder is bad.
Apr 18, 2012 | Senco Tools & Hardware - Others
SENCO MODEL-IV how to set nail depth
I went to the Senco site and they don't list the model IV. I would suggest that you go to Senco.com and type in your model number and you can download a manual for all their tools. They didn't really have that many tools that you could set the depth on from what I can remember.
Jul 28, 2009 | Senco Tools & Hardware - Others
SENCO SN-IV LB3500 Seal leaks air
The old seal was origionally the same as the new one, a white nylon, however over time the seal breaks down and looks like hard wax. The new seal may be installed by heating with hot air gun till plyable and gently streach over lip. While the gun is open, lube with nail gun oil. the piston should not slide down the cylinder under its own weight, if it does, replace the piston oring. Diagram available at senco.com
Nov 25, 2008 | Senco Air Tools & Compressors
Air Tools & Compressors Logo
441 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
