Tv channels are changing dont stop At All - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
Main system control memory IC fault. Replace it. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 10, 2015
TV will not display picture or sound except for 1 station which appears to be 440. I can't change the channel either at the dials or remote. The display says EAS.
DONT USE the remote that came with your TV
use the buttons on the box to change the channel. did the channel change?
usually when someone only has one channel its because they are changing the tv channel not the cable box channel
think of it like this:
the TV is a monitor and should always be on the same channel (3, 4, hdmi, or whatever) its actually the box that tunes and the tv always stays on the same channel.
so if you change the tv channel you are no longer watching the output of the cable box.
USE the remote supplied by your cable provider
Aug 06, 2013 | Motorola Mobility DCH3416 (160 GB) DTV...
I have a disney tv and the phillips codes do not work. Does anyone know of different codes besides 0417 and 0115:
Follow the same steps to enter a code but instead of entering code press the channel up button repeatedly until it turns the tv channel and when it changes (dont press up again or else you will have to do it over again). When you get the remote to change channel STOP! and press the enter/ok, or similar button to lock the code in and you should be set. Good luck. If you follow the steps and it doesnt work the first couple of times dont be discouraged, Trust me all universal remotes allow you to set up you universal remote this way i guess they already know people lose the universal remotes instruction manual with all the codes in it! Hope this helps GOOD LUCK too you. Hope this works out for you!!
Jan 02, 2011 | Disney DT1350-P 13" TV
Need code to program universal remote
All you have to do is follow all the steps to enter the code and when you get to the point of entering the code (DONT) just press the channel up button repeatedly but at a slow pace the remote will eventually change the channel on your tv (Tv has to be on) when it changes (STOP) and press the enter/ok, or similar button and that will lock in the code and vwalla you dont have to get up and change the station again.and if it messes up again the follow the same steps and it will fix it again.Good Luck too you.If you follow the instructions this will take you through all the tv codes that the remote has stored and eventually the code for your tv.
Jan 02, 2011 | RCA TruFlat 27F520T 27" TV
I have a sanyo tv. Slightly older. Not hi-def or New
Hi:
This may be due to the possiblity that the you are on the wrong input source, If you watch HD Channels then the input source would either be componet or HDMI input. Try changing the input source of the television with the TV's remote until you see the Channels again. IF you are not watching HDTV then the television is on the wrong reception channel for the Direct TV's box. Try channel 4 or 3 or even 73.
May 06, 2010 | Sanyo AVM-2509S TV
Channels changing
What happens when you "hide" the remote from the TV so that the TV can't "see" it?...accordianman
Feb 29, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Turn tv on, and it scrolls through the channels
Had the same problem, channels would not stop scrolling.
It was as though someone had there finger on the channel up button.
Disconnected the sixth wire, starting with the black wire on the wiring harness for the front buttons, on/off, ch. up/down, vol. up/down, etc.
It works fine, no more unwanted channel surfing!!
Aug 29, 2007 | GE 32GT740 32" TV
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Dec 18, 2006 | Sony KV-27V42 27" TV
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
