Question about Midland LXT300 (14 Channels) Two Way Radio
WHAT bATTERY USE FOR THOSE WALKIE TALKIE - Midland LXT300 (14 Channels) Two Way Radio
  • Caye Poveda
    Caye Poveda Apr 09, 2015
    good thans. I bay those Bat.
  • Midland Master
  • 1,654 Answers
Here is a link to the manufacturer who can help you get the correct batteries: https://midlandusa.com/product-category/accessories-two-way-radios/
Also, a quick google search shows several alternate sources.
Posted on Jun 09, 2015
5 Suggested Answers
prerit_777
  • 214 Answers
SOURCE: where is the power switch for the MidlandLXT80
down
Posted on Feb 11, 2010
  • 52 Answers
SOURCE: HOW CAN I MAKE AN LXT80 WALKIE TALKIE WORK
visit electronicsstoresonline.com/2_way_radios_walkie_talkies.htm
Posted on Feb 15, 2010
  • 3287 Answers
SOURCE: how many watts do midland walkie talkie xt20 have?
These are FRS/GMRS (Family Radio Service/ General Mobile Radio Service) radios. The legal power limit for FRS is 500 milliwatts - or 1/2 watt. GMRS on the other hand is limited to a much higher 50 watt level. The wattage you transmit determines if you need to have a GMRS license. Most GMRS radios are in the .5- 5 watt range however.
The likelihood of your XT20 being a 1/2 watt out on both FRS & GMRS is very good. For Midland (or anyone else for that matter) to produce a radio with a 1 watt output that can run on just 3 "AAA" batteries would be quite the feat! If Midland did do this, the radio's battery life would extremely short. To balance the needs of light weight and battery life, output power needs to be reduced.
Claims of 20 miles is crazy. If you had these radios on mountain tops 20 miles apart - with a clear line of sight between them - MAYBE - you could hear one on the other. This would need to be done under only the most ideal conditions. The actual distance you can expect to get out of a pair of any brand FRS radios in "real world" conditions (line of sight blocked by trees and buildings) is about a mile.
An FRS/GMRS radio limited to 1/2 watt output when used on a GMRS frequency that is close enough to access a GMRS repeater system could easily cover 20+ miles. The key here is having a license and access to the repeater. Repeater owners take a dim view of unlicensed users access their repeater.
Channels 1 thru 7 are FRS and GMRS. That is, if transmitting .5 watts, you can use it as FRS. If transmitting more than .5 watts, you will need a valid GMRS license.
Channels 8 - 14 are expressly for FRS. Only .5 watts transmit power is permitted.
Channels 15 - 22 are expressly for GMRS at any transmit power up to 50 watts. Even if transmitting .5 watts, you MUST have a valid GMRS license on these frequencies.
I know - more infor than you wanted and no vclear cut number for wattage - but there's no info on these radios on Midland's site or anywhere else that I could find. Good luck!
Posted on Jun 21, 2012
  • 458 Answers
SOURCE: constant static midland walkie talkie
Doesn't it have a squelch adjustment?(it allows you to adjust sensitivity of the "gate" on the receiver).Turn the knob counter-clockwise until it just goes quiet.The receiver will be silent until a transmission is detected.
Posted on Oct 08, 2012
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
I need a manual for this
http://www.upzone.com/downloads/summary/7-manual/1254-the-manual-of-walkie-talkie-atomatic-battery-save-walkie-talkie-88006651.html
May 21, 2014 | BellSouth Auto multi-channels 2-way radio...
My Cobra MircroTalk walkie-talkies aren't charging. The charge light doesn't turn on and I've made sure u turned Tue units themselves off. The model number is: GA-CQ
If your problem started after replacing the batteries (mine did), see this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html If that is your problem, you can also fix it by wrapping foil around the bottom of the battery that makes that touches the bottom side charging contact.
Oct 19, 2013 | Radio Communications
When I place the walkie talkie in the charger base, the light indicator does not come on. I've put new batteries in the walkie talkies. Also, on another walkie talkie, it constantly shuts off when I...
Generally when a radio shuts off when you press the PTT button it is a sign of a bad or poorly charged battery. It takes more energy to transmit than to receive. The fact you have a charge which the light does not come on indicates you have a bad charger or bad connection between the radio and/or battery and the charger. Clean your battery contacts (on both radio and charger) with a pencil eraser and see if it clears up the problem. If not, you have either a battery or charger problem.
Best regards.
May 25, 2011 | Motorola Walkie Talkie 2-Way Radio
I have the cobra micro talk with rechargeable batteries my workers plug them up every night and get them in the morning but some arestill saying low battery, does the walkie talkie need to be turned off...
they charge better if they are turned off. since they do not have a paid dedicated channel, signals can
still be received by any walkie talkie using the same channel, and can deplete the charging process
to the radio. good luck!
Dec 07, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
When i try To walkie-talkie it wont work
They do not have signal to receive the walkie talkie service. Try texting them and telling them to get in an area where they can get better service. Walkie Talkie coverage is very spotty.
Jun 24, 2010 | Motorola Mobility Boost i415 Cellular...
Put batteries in and walkie talkie does not work
either the batterys are duds or the walkie talkie doesnt work- junk or have repaired :)
WE love to help :) and its FREE! so please be kind and thoughtful in your ratings. THANK YOU!
Mar 30, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Static
You are describing an open squelch. If this unit has a squelch control, adjust it until it quietens.
If the battery voltage drops below a certain point, it won't squelch. That could be caused by a battery that needs to be charged or a bad battery that won't charge up correctly.
Apr 10, 2009 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Nextel i850 can't receive calls
  • may be the walkie talkie can recieve signals only to an certain distance,so it may be due to the signal problem........
  • if the reciever is beyond the permitted distance it loose its frequency...........
  • or else the person who is calling walkie talkie might not hav signal in that area.....
  • and if the walkie talkie does not recieve any signal then the receiver component present inside the walkie talkie might be damaged.........
  • and if it does not reply to an signal transmitter might be damaged..........
  • i hope my answer would be sufficient for u.....thank u......
Sep 10, 2008 | Motorola Mobility i850 Cellular Phone
Midland LXT300 (14 Channels) Two Way Radio Logo
128 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
