Question about Miscellaneous
Can you tell me when this gun was made !!!
Choke bore barrel and log forged in one. pat. june 15 - pats pending...
I have a Hopkins & Allen XL No 2, however the patent date on the barrel IS NOT EXACT & different than most others I have come across.
patent numbers mean little in trying to determine a date of manufacturer
and original patent number could be issued and the product put into production then years later to make an improvement a new/ modified patent is to improve the product
Jan 17, 2018 | The Optics
How can I bypass the pats system on a 1999 crown victoria
Ford P.A.T.S system bypass - YouTube
? 2:05
www.youtube.com/watch?v=CvRKZ-DHjGk
Mar 13, 2013 - Uploaded by Ryan Dubyak
Ford P.A.T.S system bypass. Ryan Dubyak ... Transponder Chip Key Bypass How To For Any Car! - Duration ...
Bypassing the PATS ' 4.6L Based Powertrains ' Crownvic.net
www.crownvic.net > ... > 4.6L Based Powertrains
Jun 27, 2011 - 15 posts
They have an entirely different PATS system that does not have an .... I've had a '99CVPI PCM in my '98 MGM for about 10 months now, even ... For ANY of you 1998-2000 Grand Marquis or non-police Crown Victoria guys, ...
Oct 31, 2015 | Cars & Trucks
Trying to find year and manufacturer of a single shot 410 breakover shotgun. Serial number L5972 has serated area by notched site.
iver johnson single barrel champion shotguns with a single letter suffix to the serial number were manufactured between 1920 and 1929. it seem that most of the 410 were used quite a bit and very few are in excellent condition. the original finish was an oil finished stock, browned barrel and case hardened frame.
CHAMPION MODEL 36--------------------------------1909-1922
Single barrel; rebounding center mounted hammer; top lever operated break open design; gauges: 12, 16, and 20; barrel length: 28, 30, and 32 inches (features barrel and lug forged in one piece) bored full chock only; American black Walnut but* stock and fore-end; automatic extractors; weight 6¾ pounds; overall length with 30 inch barrel 45 inches; case hardened receiver (nickel available as option), browned barrel; automatic ejectors extra cost option; .410 bore, 24 and 28 gauges offered in 1913; 24 gauge dropped 1928; all gauges except 12 dropped after 1941; name changed to Champion single Barrel in 1917.
CHAMPION SINGLE BARREL---------------------------1923-1978
This is the same gun as the earlier Model 36 champion except that the smaller gauges are now built on the same frame as the large gagues. See above picture for specifications. The exact year production stopped has not yet been determined. Some of these single barrel shotguns have been seen with Canadian marking, these were most likely shipped to Canada and then marked as there is no evidence that Iver Johnson's Arms & Cycle Works ever had a manufacturing factory in Canada
Jun 01, 2015 | Optics
Could you tell the price of Col 45 hand gun Serial Number 62753 Pat. Sept 19 1871
10 to 15 thousand dollars depends on the condition.
Mar 09, 2015 | Optics
Does a 2001 mercury cougar have a chip in the key
Yes, it does........
The Passive Anti-Theft System (PATS) is fully passive in operation and requires no special procedures by the driver to arm or disarm the system. It is invisible to normal scrutiny and is operated by a miniature transponder within the key body. The transponder communicates with the powertrain control module through a transceiver mounted around the ignition switch lock barrel. The PATS functionality is incorporated within the powertrain control module.
PATS may be identified by a larger than normal sized ignition key. A larger sized ignition key indicates the presence of the transponder that controls the system.
The transponder code reading is carried out when the key. having been inserted into the ignition lock barrel is turned from position "0" to position "II" to crank the engine. If the Powertrain Control Module (PCM) receives the correct code the engine will start. If the PCM receives either no code or an incorrect code the engine will not crank and PATS remains armed and the engine immobilised.
Anti-Theft Indicator
Whenever the ignition is switched on the anti-theft indicator will remain on for three seconds while the system reads the ignition key code.
The anti-theft indicator will flash rapidly or glow continuously after the initial three seconds to indicate the PATS has immobilised the vehicle.
Sep 06, 2014 | 2001 Mercury Cougar
My sons battery keeps going dead overnight, the PATS light is flashing all the time, even when I pulled the fuse out of the fuse box. Any idea what is draining the system and causing the PATS light to
pats is the system that is controlled by your key the pats transponder and the pcm,it is a security system the system is relitivly easy to fix I ask you to please log on to you tube and check out ford focus no start it will explain the easy fix you have to do.I could try to explain it to you but it would be easier for you to watch the video and it will fully explain it to you
Jul 25, 2014 | 2006 Ford Focus
Dont know how to set the coke
Read the barrel on the top, left side, back near the receiver. It'll tell you the gauge, the chamber length, the choke type etc. if it says "fixed choke", it's forged into the barrel and can't be changed. If it's a "poly choke", older gun, it'll have grip knurlings on the barrel muzzle that you twist. If it's a "win choke" or "accu-choke", it has a removeable choke tube in the muzzle of the barrel. There will be two notches that fit a choke tool. Seriously, though, just fire the gun as it was when you bought it and don't even bother with the choke until you get some experience and know what you want. This is a bit older question so there's no doubt in my mind you already answered your own question and are an expert with the gun. This answer is more aimed at the folks who will search on the same topic and might see this. Great gun, btw....congrats!
Jul 20, 2013 | Mossberg 500 AllPurpose Field Shotgun 20...
How to reset my factory car alarm in a 1999 mercury cougar v4 2.0? thanks
1999 cougar. before they tell me I need a fuel pump I want to be SURE the anti theft system has not shut off the fuel to the engine.
how do I confirm that?
Dec 08, 2008 | 1999 Mercury Cougar
Miscellaneous Logo
18 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
