Question about KitchenAid 30 inch Over-the-Range 2 cu. ft. Stainless Steel Microwave - KHHC2090SSS
KHHC2090SSS-2 light problem - KitchenAid 30 inch Over-the-Range 2 cu. ft. Stainless Steel Microwave - KHHC2090SSS
Flickering light on kitchenaid microwave khhc2090sss
If you're referring to the cavity light, it's possible the bulb is just loose in its socket. The cover has to be removed to access the bulb.
Nov 04, 2017 | KitchenAid Microwave Ovens
Our microwave does not consistently come on. When we put in the time to cook it tells us to open/close door. If the cavity light comes on then it works, if not it doesn't work. Please HELP! Thank you
Sounds like you have one or more faulty micro-switches for the door. They are not expensive to get, but your service center will likely charge you a lot to fix it. If you are handy, you can pull the case off and replace them yourself.
Oct 18, 2016 | KitchenAid "KHHC2090sss Microwave Hood...
I have a Kenmore microwave mounted above my stove. The light that lights my stove is blown and I can't find the right replacement bulb. It has two little prongs that should fit into the unders
Are these little spot lights? About the size of 1/2 dollar round and maybe 1.5 -2 inches long? 2 prongs about 1/2 inch apart? Take one of those lights and show it to a local hardware dealer like "Lowes". There are may types and some are 12V some are 110V. Thats why I suggest showing to the local hardware guy.
Jan 12, 2015 | Microwave Ovens
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
When the microwave is cooking the light inside dims. When done cooking the light returns to full brightness. Is that normal or is there a problem with the microwave?
I've seen this with most microwave ovens I've had. When the microwave emitter kicks in to cook, the unit uses much more power, providing less to the internal bulb, which dims a bit. Unless it's very dramatic, for example the bulb turning off or going almost out, it's normal behavior. If the bulb is going very dim or out, it could be that the circuit it's connected to isn't providing enough amperage to adequately run the oven. In the case of your microwave, it's rated at 15 amps, so should have adequate power on a standard household circuit by itself.
Apr 09, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
I need a Kitchenaid Microwave service manual for model KHHC2090SSS
You can find helpful exploded view diagrams and order parts by entering your full model number here.
This model is inverter-based, so it does not use the larger, exposed capacitor that transformer-based models do. It uses one or more small capacitors hidden on the inverter board.
As long as the high voltage section was not energized within about a half-hour of disassembly, and one does not contact the high voltage connections, there's really no need to discharge high voltage capacitors.
They have built-in bleeder resistors that bleed off the charge in seconds. But there is that one in a zillion chance the resistor inside is defective, etc.
The shock from stored DC high voltage isn't what hurts you. What hurts is getting sliced up by the sharp metal chassis when you reflexively pull back your hand after the shock.
I'm also curious as to what problem you're troubleshooting.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Dec 13, 2011 | KitchenAid Microwave Ovens
When machine is first turned on it will run till bin is filled and it cuts off, but will not restart after ice is removed from the bin.This os a hoshizaki commercial ice machine
Remove front panel, look at controler,(where the blinking lights are) there should be a sticker on the back of the panel that tells you what the problem is by how the light flashes. IE- if light flashes 2 times, stps, flashes 2 times,etc, etc
Oct 08, 2010 | Microwave Ovens
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Replace light in overrange GE microwave
Advantum 120 over range microwave - with burned out interior bulb: Remove top fron grill cover -- held byu 2-3 screws on top. Remove sheetmetal plate that lies parallel to top of unit, just to the right of the square plastic porting on the far left of the unit. The sheet metal plating is about 12" wide and 8" deep and is shaped like 2 overlapping rectangles. It is held in place by 1-2 screws. (I don't recall if you needed to remove other plastic grid on right front -- I did, but I was still searching for the bulb). The bulb is located about 5" from the left side and about 2" in from the front, covered by a small sheetmetal box. THe bulb looks like the little halogen bulbs used in low-voltage outdoor lights - but is slightly larger - DO NOT REPLACE WITH THAT KIND OF BULB). Remove the one screw holding the box, unplug the bulb and find a replacement. Can't tell you where to get a bulb -- that's what I'm doing next. Good luck.
Jul 25, 2008 | Microwave Ovens
Light bulb
If you are comfortable with taking the cover off, Unplug the microwave, usually there are 2 philips screws on the top back, 2 on the right back and 2 on the left back edge cover. Sometimes, their might be a screw on the bottom but you will notice this right away if there are or not if the cover doesnt come off.
Then located the light bulb. You should be able to see the opening from inside the microwave where the light bulb is located.
Once you locate the bulb, then there are usually 2 types, type 1 screws in and the other type is a bayonet type, which you push down, and then twist. You should be able to figure this out.
Sometimes there is a plastic cover that is placed around the bulb to kinda help focus the light towards the inside of the microwave.
Once the bulb is out, then take it to your local hardware store and see if they can match it up. You might want to call first to see if they carry them before driving all over the place.
Hope this helps.
Good luck.
If i have helped you with you question, then please remember to post a feedback and a rating.
Thanks.
Mac
Feb 19, 2008 | Westinghouse WST3504 Microwave Oven
KitchenAid 30 inch Over-the-Range 2 cu. ft. Stainless Steel Microwave - KHHC2090SSS Logo
51 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
