Question about Sansui C-1000 Stereo Control Amplifier Preamp
How does this wire into the tuner - Sansui C-1000 Stereo Control Amplifier Preamp
Wiring diagram to hook up 1995 Ford F150 to Pioneer super tuner three.
owner manual,Download manual
installation super tuner 3. Download manual
95 ford 150 wiring diagram,
25655506-gorlwoxjc0ugisydrtb3kvdf-5-0.gif pioneer 3 wiring
Apr 19, 2015 | Ford Cars & Trucks
Tip
How to Build: Antenna Tuners
Get you a metal box about 4 inches X 4 inches. Use 2 female Cb antenna inputs from old Cb radios or Radio Shack. Get a old Am radio tuner out of a AM radio(530-1700 khz.) Buy or scrap up some copper wire; big gauge I used. Wound 8-10 turns about " 1 inch round close tight wound. Solder to AM tuner- C1 it shall say on top of Am tuner. Solder Center of Am tuner to Ground(Metal box). For those who know electronics the Tuner is 0-365pf Am band 530-1700khz types. OK, back to assembly. drill a hole for the Two Female Cb Inputs on both sides of metal box. Attach copper wire inside to center taps of Inputs on both sides. Drill a hole for Am tuner and Screw on its lock nut and place a knob on it. Solder all grounds of Female Antenna inputs and Tuner Ground and all Grounds to metal box. Use a washer and Bolt to lock down Grounds to Box. This is how it operates after you use a Jumper to hook to TX of Cb radio. Antenna to other side. Its just a simple L/C network. The Tx travels through copper wire(coil) inside box and gets shunted to ground by the right level of PF Capacitance. The operator tunes it in to get a close to 1.1 to 1.5 SWR ratio. Its simple, but helps with bad Antennas.
on Apr 01, 2011 | Radio Communications
The antenna/cable connector looks broken. can this be replaced?
Hello
In most models of Sharp Telivisions,antena socket is an integrated part of the tuner itself and cannot be replaced with an other one. There is only one way and is to replace the tuner itself.
If you don't mind of style, you can solder two wires, one from the center pole of the antenna socket, and other from it outer rim, and take it out and connect to an external ariel socket [can be bought from electronic sparepart shop as a seperate socket] , to whcih you can connect your ariel pin. It will look a little dull, but you can face the probelm, without replacing the tuner. When making these connections, use sigle cored shield wire. It center wire must connect to the center pole of the broken tuner socket. OK.
Dec 09, 2010 | Sharp 27N-S300 TV
When head unit is on tuner everything is fine when on ipod or cd mode there is no sound ...i have taken off the face and reset the unit and still tuner sound on ipod and cd sound off
are you using an amplifer? if so, it sounds like you are using the blue wire instead of the blue/white wire to turn the amp on. the blue is antenna remote and turns of when it is not in tuner mode. the blue/white is amplifier remote.
Oct 28, 2010 | Alpine CDA-9883 CD Player
Marantz SR870 tuner not working
Make sure your FM antena connection is good. A receiver will not pick up an FM signal without an antena. Even a small piece of wire will work to test. If the Tuner section is bad, an external tuner can always be connected to an Aux input. Due to cost, it may not be cost effective to repair this unit.
Hope this helps.
Oct 08, 2009 | Marantz Audio Players & Recorders
Where can I procure parts for a WF203 model TV. The part that receives the coax cable is broken and I need to replace it
Try ued.net you'll need make and model numbers, depending on how old tv is it could be either a antenna isolator or a tuner.
Aug 05, 2009 | Televison & Video
Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Jul 06, 2009 | Audio Players & Recorders
Have a Denon 685 receiver. Purchased a Sony HD tuner (tuner only --$99). Hooked it up to phono input and it worked. After a while protection circuit clicked in. Used integrated tuner in unit. Worked longer...
if you disconnect speaker wire from rear and the problem is solved you will have a real problem in speaker wiring-you must fix it first or disconnect it from receiver and put new wires instead of.
Jul 16, 2008 | Denon Audio Players & Recorders
KVT 617 CD/DVD "reads" but only audio from tuner
Ok, so I called Crutchfield, where I had purchased the unit, and the guy there said this is a common thing. Believe it or not, it IS the wiring. The guy said the blue wire on the harness needs to be connected to the blue/white wire on the Kenwood unit. Which is weird, since it's usually color-coded. He said the blue wire is a 12-volt amp wire, which works with the tuner, but when you take it off tuner, it kills the 12 volts and so you get no sound.
I haven't fixed it yet to be sure it works, but I thought I'd post this anyway, in case someone else is waiting on this. I'll post again if it doesn't work. :0)
Jan 29, 2008 | Kenwood KVT-617DVD Car DVD Player
Attach new antenna wire to tuner (Funai TV VCR combo )
If you take off the tuner cover you should see where another wire was attached to the PCB as there will be a small hole with nothing connected and a piece of wire at board level or broken level with the Printed curcuit board. If you dont see it then the best thing for you to do is to send the tuner to a tuner repair place like PTS tuner service and they have a flat rate to overhaul tuners and assy's or see how inexpensive a new tuner assy is. Its available at pts electronics for 49.95 along with many many more items like rebuilt printed curcuit boards ect ect ..www.ptscorp.com Good mluck
May 04, 2006 | Funai F3813D 13 in. Combo
Sansui C-1000 Stereo Control Amplifier Preamp Logo
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
