Question about Garden
I nedd a primer (rubber) for my chainsaw, Mod. CS38(family CS38A01 Art? nr 45.014.85) how can I get one
I was away from home for a long time, when I returned I nedded to use my chainsaw but the rubber primer was broken, now I cant start my machine
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Try chainsawr.com These guys have most anything you'll need for small engines. Next try Jacks Small Engines. They have one of the most user friendly parts listings services I've found.
Posted on Apr 13, 2015
    Sergeant:
  • 333 Answers
Hello Manuel, I'm not familiar with your model number. You should be able to find a primer bulb at most small engine repair shops, hardware stores, or even the dealer for your saw. You can also find them on EBAY.
Posted on Apr 09, 2015
Craftsman chainsaw mod 358356280 fuel line routing ,it has no primer bulb
If no primer,it will only have a line for the vent and the other will connect to the fuel filter.
May 20, 2017 | Craftsman Garden
I am doing away with my primer bubble on a Poulan Pro ClassicI need to see a image or a picture of this how is done
Without the primer bubble you'll have a very difficult time starting the engine.
Jun 19, 2015 | Poulan Garden
Spear & Jackson chainsaw CS38 cuts out after
There are a couple possibilities. Your Carb adjustment is off or your fuel system is clogged up. On the Carb. there is an L and R you want to richen up the R side adjusting it a quarter turn counter clock wise. If this doesn't solve the problem check your fuel lines and filter. If there is a small tear in the line all the dirt and dust will go into the Carb and stick to the screen inside the carb body. Hope its the first one. Good luck!
Jan 22, 2013 | Garden
Chain saw parts list
As you do not say what machine this is i will give you generic set up,if you have a remote primer, the fuel hose with the fuel filter on in the tank goes to the fuel inlet on the carb the connection nearest to the alluminium pump cover held with a single screw, the other carb conection goes to the longer conection on the back of the primer ( suction side ) the shorter connection on the primer ( pressure side ) takes the fuel back to the tank, if the primer in on the carb itself, the hose with the filter on goes to the connection furthest away from the primer bulb, the other connection goe back to the tank, with both systems the primer pulls fuel from the carb into the bulb and dumps back to the tank
Jun 17, 2012 | Garden
Poulan Woodshark 1950 14" Chainsaw Family: WPWES
Checked all the parts lists, they seem to use the same primer through all types no.s part no. 530047213.
Jun 24, 2011 | Poulan Garden
I am replacing a primer bulb in a chainsaw and the lines are gone so i need to find out which line goes where
Leave both primer ports open, then attach the fuel line that feeds the carburetor from the fuel filter to one of the primer ports--pump the primer and if you guessed correctly, it should pump fuel into the primer bulb. That is the primer port that goes to the carburetor output connection. The other primer port connects to a short line that goes back into the fuel tank with no filter. Return the original feed line back to the upper carburetor port. Connect the open primer port to a short line that connects to the carburetor lower port. Be sure to use original rubber lines, not plastic. Hope this helps!
Jun 22, 2010 | Garden
Poulan P3400 Chainsaw Fuel Line Routing
If the saw has a primer bulb, then you require one line from it's output out to the tank return. Another line runs from the carburetor outlet to the primer inlet. Make sure that you use original rubber lines, not plastic replacements. The primer ports are found by trial and error--hook the filtered line directly to one primer port and leave the other port open. If the bulb is in good condition, and correctly connected to fuel, the bulb should fill with fuel after several pumps. If nothing, reverse the port connection at the primer--and pump test again. One of these two connections should allow pumping to occur. When you get pumping, install the tank return line to the empty primer port. Remove the filtered line from the primer and install on the carburetor. A new piece of line runs from the now empty primer port and connects to the output port on the carburetor. If the carburetor lines are correct, you should be able to pump fuel through the carburetor body and out to the primer bulb. If nothing happens, you may need to swap the carburetor lines, and you will likely need to service the carburetor. Hope this helps!
May 25, 2010 | Garden
Need parts breakdown for CS38. no fire at plugs
Clarification Request
Posted by dontbother10 on Sep 18, 2009
We need the make, model number, and serial number from the manufacturer?s tag to help you further. We also need to know if it is gas or electric and American or European.
Clarification request not answered. This question cannot be answered as asked.
Jul 01, 2009 | Garden
Procedure for starting
Thats called the primer Make sure the on/off switch is on the on,Push the primer at least 4 to 5 times,then pull it..once it starts you may have to push the primer a few more times to keep it running once it runs on its own and you dont have to push the primer to keep it running Cut Away,Also one more thing you probably already Know make sure its full of bar oil..Hope this helps you and have a great day...
Apr 06, 2009 | Garden
Garden Logo
135 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
