Question about Maytag 3.5 cu. ft. Front Load Washer MHWE200XW
It spins fast but the clothes are still saturated when done. Unless it's a really small load
    Genius:
  • Maytag Master
  • 1,585 Answers
Replace pump sounds like impellers at fault
Posted on Apr 12, 2015
Won't spin fast when fully loaded
You may have a weak clutch. If you can stop the washer during spin by hand, that's what it is.
Jan 26, 2014 | Kenmore 24422 Top Load Washer
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Special Edition Top Load Washer - model # 24692300 - clothes are still quite wet following spin cycles. Machine appears to spin at a reasonable speed. HELP!!.... Thanks
Hi, Could be as simple as a slipping belt, they can get glazed, stretch or even get wet small water leak, and get the tub spinning but not fast enough or taking to much time getting going fast that the washer timer says it should be done and goes into the next mode. If you have no Idea how to repair the belt or check by looking under the machine after you unplug it, the only help is the repair person.
Nov 23, 2011 | Washing Machines
My bosch front loading washer on the small cycles will not spin the water out of the clothes..why?
Does it sound like the machine is spinning as fast as on longer cycles?Some machines run a slower spin speed on small cycles which can leave clothes wetter than normal. I've got this on mine and all I do is when the wash has finished I change over to the fast spin only program which then takes it to it's highest spin speed.
Jan 25, 2010 | Bosch Washing Machines
GE WSSH300G0WW will not drain
this means the machine isnt spinning fast enough, or the drains are clogged.
Apr 29, 2009 | GE WSXH208A Front Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
My hotpoint aquaris machine is not engaging the fast spin function. When it comes to the fast spin in the cycle the machine goes dead. The machine was performing the fast spin until recently however the...
everything you have described points to a blocked pump,worth blowing down the clear pressure pipe from the switch end while your in there to make sure thats clear!
Jan 12, 2009 | Hotpoint First Edition FEW12 Front Load...
Kenmore front load wet clothes
Before going further it is important to determine if the machine is reaching full spin. Make sure the unit is set to MAX extract and watch the inner tub. The tub should be spin really fast (1000 rpm's or better) during the final spin. If not you have lost one of the phases on the motor.
Jan 08, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag 3.5 cu. ft. Front Load Washer MHWE200XW Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
