Question about Refrigerators
It is silent over night bur as soon as the door is opened in the morning the motor kicks in and it starts buzzing. this goes on all day.
  • Refrigerators Master
  • 5,323 Answers
NOT SURE THIS IS UR PROBLEM BUT THOUGHT ID SEND IT
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE
Posted on May 17, 2015
How do I fix a buzzing sound in my fridge?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Apr 09, 2015 | Refrigerators
My dryer initially makes a buzzing sound and will not begin the cycle until I give it a few turns manually...
you have a bad motor,if you open the door,hold the door switch in with one hand and spin the drum with the other and have someone else push the start button on and if by helping it to spin it starts usually the motor is bad but i did find on the maytag neptune style dryer that the belt cut into the belt pulley and was holding up the drum and the motor was buzzing like it was bad but like i say usually it's the motor.next time send the brand name and model number and i can help you out better.
Jan 25, 2014 | Whirlpool LER5636P Electric Dryer
Noisy Dishwasher
it is a capacitor to start the motor for the next cycle. I think it is inside the door. you may have to call a tech.
May 19, 2013 | Whirlpool GU2300XTVQ Builtin Dishwasher
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
My dryer is making a buzzing sound when trying to turn it on. Not working. Cleaned lint in machine. Also made sure the door is closed. This happened a few weeks ago, didn't work for a few days and then...
the buzzing noise is the motor trying to start try a test leave the door open with one hand press the door switch with other hand spin the drum at the same time have someone press the start button if your dryer starts then and when it is cool it is the motor replace the motor
Apr 05, 2010 | Dryers
2006 sebring 4 cyl - in cold weather security alarm goes off whether i have it left unlocked - use key to unlock or fob - every morning it goes off - yesterday - when i was leaving work - went to unlock...
I know a quick fix to get it started but you might think i'm crazy to do this:
My 2003 Dodge ram van 1500 does the same thing. I put a small heater on the driver's side floor blowing the hot air toward the door.
I plug in the heater when I get home from workand let it run all night.
The computer for the alarm is under a kick plate near the driver's door next to the driver's seat on the left side. Once it warms up the alarm; it will shut off the alarm and you can start the motor.
Jan 06, 2010 | 2006 Chrysler Sebring
On occasion, my furnace will not kick on at
If your Rheem furnace is less than 10 years old, it may store an error code to help you figure out if it is the furnace or the thermostat. Look at the circuit board for a blinking light. If you have to remove the panel that opens up the door safety switch, it will erase the code. Look for a small viewing port. Next time the furnace fails, prior to doing all the things you did last time, look thru the viewing port to count the number of blinks. Once you get the number, open the cabinet and on the wiring diagram glued to the back of one of the panels'\; there will also be an error code chart. It may give you a starting point where to look. If you have no error code, chances are that your thermostat is freaking out or has a bad connection. Hope this helps.
Dec 28, 2009 | Honeywell CT3200 5-2 Day Electronic...
WILL NOT START WHEN YOU TURN THE START SWITCH, THE MOTOR JUST HUMMS
two possibel reasons for this
1, you have something stuck in the blower moter
look down the lint trap you may just be able to see it
2. your motor is going bad
open the door and hold the door switch with tape or something like it
push the button and try to spin the tumbler while you hear the buzz
if it starts up and the buzz goes away,,,, your motors start wionding is gone and you will need to replace the motor
Oct 21, 2009 | Dryers
Dryer buzz when I try to start, If I open the door, hold down the door switch and turn the drum it's start the motor and run. Any idea why?
The drum belt is probably worn and slipping on the motor shaft. Spraying belt dressing on the belt may give it enough grip to get started temporarily but the belt should be replaced soon.
Aug 28, 2009 | Dryers
Problems Keeping the cycle going
On the back of the selector switch there is a timer motor or clock motor assembly. The gears wear out or the motor has lost its ability to go through the cycles. Replace it and you should be fine.
Jan 16, 2009 | Dishwashers
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
