Question about Whirlpool Refrigerators
I have a Whirlpool wrf989sdam. The ice maker will cycle 4 times with the ice getting smaller and smaller each cycle till no water is in the tray. Any help would be grateful.
  • Whirlpool Master
  • 5,323 Answers
Ice Maker Is Frozen Up This ice maker repair is even easier. If your ice maker has frozen up, take the following steps to thaw it out:
1Unplug the refrigerator.Remove the ice bin from the refrigerator and remove any loose ice from the ice maker.
2Find the fill tube.This is awhite rubber-like hose that delivers water to the ice maker. Pull down the small metal clip off the housing that holds the fill tube (though not all ice makers have this clip).
3Warm the hoseand surrounding mechanism. To do this, you can train a hair dryer on the ice maker to melt any ice blocking the mechanism. But be very careful (sop up any dripping water with a rag) as electricity and water can present a serious risk of electrical shock. Also, be careful not to melt the plastic parts.
4If you don't want to use a hair dryer,you can soak the supply tubing with hot water, using a turkey baster and catching the overflow in the empty ice maker bin. In some cases, it may be easier to remove the ice maker than to thaw out the fill tube.
On heat release ice makers You will want to check the heating element within the ice maker for continuity and a visual inspection of the board and conductors for burns and seizing, chared marks.
How to Test the Ice Mold Heater There are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver. Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. It is easier to work on this type of unit by first removing the entireicemakerfrom the freezer compartment. The unit is usually mounted to the freezer case by two or more screws. Remove the bottom screws first. While supporting the ice maker, remove the remaining top screws. Unplug the ice maker from the freezer cabinet if you have not already done so. Along the edge nearest the shutoff arm, a pin protrudes through the mounting plate . The arm pin has a spring under the mounting plate. Reduce the tension on the spring by moving the shutoff arm into the "on" position, down, against the ice maker.
Test the heater for resistance using amultitester. Set the multitester to the ohms setting X1. Touch one probe to each of the two terminals (or wires). The reading should be in the range of 60 to 90 ohms. If you get a significantly different reading, such as zero or infinity, then the mold heater is bad and needs to be replaced. Conduct this test with the refrigerator unplugged. Test the moldheaterfor resistance using amultitester. Set the multitester to the ohms setting X1. Place one probe into the hole labeled "H" and the other probe into the hole labeled "L". The multitester should read in the range of 60 to 90 ohms.
Also be sure to check and test water valve with a meter for continuity and voltage..( a full 120 and nothing less) And a visual inspection for any ice build up or blockage in tubing and flow line. Remember u may get a close circuit reading of continuity however it may still be bad in that it may remain constantly closed and water keeps flowing more than suppose to. Hence chunks of ice build up.
Posted on Apr 10, 2015
  • Anonymous Apr 10, 2015
    Thanks, It was the water line. It was frozen. I put some soft foam around it. It ran through the first cycle but we will see if it keeps working.
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
  • 172 Answers
SOURCE: I have a Whirlpool side
Humm thats a good one, but I will try to help you out. First off you say the icemaker is new, so does that mean you bought the icemaker and installed it on the refrigerator. Or is the refrigerator new and it has an icemaker. If you installed the icemaker new on an older refrigerator you can have a few problems. Most likely the freezer is not getting cold enough for the icemaker to cycle on its own. Especially if you are peaking in every few minutes like I would be doing. The icemaker will start a new cycle when the temperatur hits 0 degrees. If the freezer is only getting to 5 degrees the icemaker will not cycle. In that case the problem would be with the refrigerator not the icemaker. If the freezer is getting to 0 degrees then you may want to take that icemaker back and get a replacement. Good luck and I hope I helped. mca0824@aol.com
Posted on May 02, 2008
  • 1073 Answers
SOURCE: Ice Maker Won't Drop Ice
you have a problem in the module of the ice maker if it is new take it back for a new one
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Posted on Mar 31, 2009
SOURCE: Frigidaire Ice Maker not working
I have a Frigidaire side by side refrigerator freezer MRS20WRGW0. I had the thermostat-defrost replaced yesterday. Now the ice maker isn't working, doesn't have water in the "tray" part that makes ice, but does still dispense water through the door. What could be causing this problem?
Posted on Mar 28, 2011
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
Ice dispenser not producing ice. water not being fed through pump to ice tray
It sounds like you might have a bad fill valve. There are several reasons that an ice-maker doesn't get water. If the freezer isn't cold enough, the ice-maker thermostat will not allow it cycle. There are two different styles of ice-makers. Pull the white cover off of the ice-maker, if you see two gears the you have one of the earlier models. Turn the smaller of the two gears counterclockwise slowly until the gears start to turn by themselves. Now if you do not have the two gears under the cover, then you have a modular ice-maker. There are several holes in the brown plate. Each hole will have a letter beside it. Jumper between the T and H holes until the ice-maker starts to turn by itself ( you should hear a click if you'll listen closely). Now that you ave cycled the ice-maker, check and see if there is water in the ice tray. If you still have no water then change your fill valve. If you do have water then its usually cheaper to replace the actual ice-maker. Be sure to check the temp of the freezer, most ice-makers will not cycle above 10F degrees. Most ice-makers are around $130. Most valves are around $50. I hope this helps you solve the NO ICE situation.
Mar 20, 2011 | Freezers
Not making ice,checked optics ,good ,water valve coil tested good, no restrictionsbut i get no water in tray,also freezer temp is 8 degrees.
OK you mentioned the ice maker had no cubes or not making cubes, try filling tray with water from tap. Let freeze and if the ice drops into ice bin the ice maker is OK. Most times the ice maker thermostat is at fault (pt. 27 in photo) if not cycling. Read OHM's between both coils and they should be very near to same reading, if not replace water control valve=> 4389177 by applying first 120VAC to see if valve opens. If water goes into ice maker this way or OHMs between the two are nearly the same your Ice Maker=>2198597 Ice Maker Assembly may need replaced. If you would like to rebuild your Ice Maker here are the part Breakdown view=>
GS5SHAXN Ice Maker Replacement Parts
Let me know how your ice or water turns out, Thanks Sea Breeze
Feb 11, 2011 | Whirlpool GS5SHAXN Side by Side...
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
No water to ice maker but there is to the water dispenser in the door. Whirlpool model ED22PQ
This could be two reasons. The water control valve that sends water to the ice maker or the ice maker is not sending the signal to the water control valve to send water to ice maker There are 2 valves on back of your refrigerator one for ice and the other is for the dispenser. If ice maker is empty then the signal should be sent to back control valve and 120 volts should open the valve for about 4 seconds. If that valve is bad nothing will happen.You can test the ice maker by filling with tap water and if it cycles until time to refill and no water fills the tray then I think the water control valves need replaced. Click on link below and enter your model number in model search feature. Let me know what you find, Sea Breeze
http://servicepartstec.blogspot.com/
Water Valve - Dual Outlet
P/N: 2188542
May 25, 2009 | Whirlpool Refrigerators
Just installed ice maker cords, no water filling ice trays
Hi make sure that the arm on the ice maker is in the down posistion as it will only put water in the ice maker in this posistion. It will take a little time to fill so be patient as the timer in the front on the ice maker needs to cycle first. Make sure you have connected it all correctly to...
Dec 29, 2008 | Whirlpool ED2FHEXN Side by Side...
2003 whirlpool ice maker doesn't work
May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
Make sure that the ice maker is in "on" mode.
May 03, 2017 | Refrigerators
Ice maker not making ice
Does the tray get water? Is your water filter plugged? Does it cycle the tray to dump ice like it has ice in it?
Mar 24, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerators Logo
106 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
