Question about Eureka 5892AVZ Bagless Upright Cyclonic Vacuum
Belt how do i change the belt on the bagless eureka boss widetrack?
  • 2 more comments
  • Anonymous Nov 17, 2007
    I need tips on changing the belt
  • gmanvv May 04, 2008
    changing the belt
  • jeanettego Sep 09, 2008
    I cannot find the screws to remove the cover!! Where are they?
  • swansong Feb 25, 2009
    ditto "Belt problem" What with this? I seem to read this continual thread!
There are a total of 6 screws - one is hidden under the right front wheel. pull the wheel assembly against its spring - it's under there.
Posted on Aug 20, 2010
Well thats just common sense but the problem is i have taken out all the screws and its still not coming off and i dont see anywhere that i have missed any screws
Posted on Sep 24, 2008
  • 1,673 Answers
Turn vac over, take out 4 to 5 screws and the top cover will come off. The belt is a cogged belt #72393 and goes between the brush roll motor and the brush roll.
Posted on Jan 15, 2008
Screeching noise from eureka bagless the boss 4d
replace beater bar belt, check and insure beater bare rotates freely with belt removed.
May 19, 2012 | Eureka 5849A Boss Bagless Upright Cyclonic...
I have the eureka boss 4495 widetrack and the end piece of the beater bar broke off. I guess I put it back together wrong when I put a new belt on. Where can I get a replacement part and will it work do...
Call the Eureka people (1-800-282-2886) and describe to them what the beater bar thingy that you broke is. Ask them if you can order that unit--if you think you can install it. Otherwise, ask them where to the authorized repair person closest to you is located. Price the repair versus a new vacuum and good luck.
Apr 20, 2011 | Eureka 4495A Bagless Upright Vacuum
Need belt for Eureka vaccum The Boss model 5848 AV-2. Can you give me a belt number for what i nee. Thanks.
The belt part number for the Eureka 5848 AV-2 vacuum is 61120A.
Should you need part numbers for other pieces of the Eureka 5848 AV-2 vacuum, click on the following site,
Mar 14, 2011 | Eureka 5849A Boss Bagless Upright Cyclonic...
What filters do i need for the eureka the boss bagless vacuum w/widetrack modal 4495
There is a Cassette Micron Filter 60696.If you have a HEPA cartridge filter you need EUREKA's HEPA part 61500.In earlier models there is a micron filter instead of a HEPA filter--for that you need EUREKA's Micron part 60801. But if you have that HEPA filter, the manual says you have to use the HEPA filter to achieve the closed HEPA filtration system again.
Dec 10, 2010 | Eureka 4495A Bagless Upright Vacuum
Eureka Boss - Belt is not broke but brush will not turn. I have already turned it over - checked belt - and pushed the reset button.
The belt may look fine but they can still be stretched or worn and it won' turn the brush. Try changing the belt and see what it does. You can get Eureka belts here:
Eureka Replacement Vacuum Belts
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Change vacuum belt
This unit is not designed for the consumer to change the belt. Eureka recommends you to take it to a service station to have this done
Dec 19, 2008 | Eureka 402A Bagless Upright Vacuum
Eureka Bagless Widetrack, The Boss, Vacume, model 5893
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis. It is Part #27871.
Jun 05, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
Eureka 5892AVZ Bagless Upright Cyclonic Vacuum Logo
313 people viewed this question
Top Eureka Vacuums Experts
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
