Question about Retail Supplies
When i want to close the register sharp ER-A242 in the end of the day. I turn the key to x1/z1 and it give me error code E0.2 and a number .. How to fix this? Thanks
  • 592 Answers
E02 is a code telling you to complete the previous transaction. So turn your key back to R and press TOTAL/TEND button and proceed.
Posted on May 09, 2015
  • 159 Answers
SOURCE: I have sharp er-a420 it was in my garage for two
Most Sharp register, including the ER-A420, have a rechargeable battery mounted inside to hold all memory when the power goes out. It should last a few months, but two years is a bit much. This might get it going:
  1. Unplug from AC POWER.
  2. Turn the key to PGM.
  3. Hold down both paper feed keys (at top-left of keyboard).
  4. While holding those two buttons down, plug the power back in.
  5. Turn the key back to REG.
  6. Enter 1 CASH # to sign on as Cashier 1.
  7. Try a sale.
There is a strong chance this won't do the job, because the memory has been randomized by total loss of power when the battery died. Worse yet, the battery may be too far gone to ever take a solid charge again. If so, you probably need the help of a Sharp register dealer to replace the battery, totally clear all memory and reprogram it. It's probably worth the money; the -420 is an excellent little register.
Posted on Dec 24, 2009
SOURCE: my sharp cash register ER-A550S stop working
The letter H appears in the screen. The register will not respond. Any idea to what the Letter H means?
Posted on Aug 24, 2010
chiefmecha
  • 600 Answers
SOURCE: The mode switch stays on
The units built in protection circuit might be faulty or needs resetting, this unit is operated by a rechargeable battery, try charging the batteries, you can do that by switching the mode switch to any position other than OFF, then plug in to ac outlet, charging the batteries may take up few hours up to two days, depending on batteries and their charge level,
for more info, try reading through here, http://www.cashregisterhelp.com/files/cas_man_XEA404.pdf
Posted on Sep 15, 2010
Electroboy
  • 1648 Answers
SOURCE: We just got a Sharp ER-A440 register (used) and need to reprogram it and get the interface cable RS-232C. We are overwhelmed with how to use this, can you help?
Hi. You do not need an RS232 cable to program the machine. It can be programmed via the keyboard.
Firstly, it would pay to have the battery checked. They use an internal rechargeable battery which should be replaced every four years. If it hasn't been changed, it can leak on the circuit board and damage the machine. If the battery is not holding a charge, it will also lose your programming when the power is turned off. This is part of normal dealer servicing but you can't be sure that the previous owner has had it serviced and checked.
You will need to program department names. This is listed under "programming for departments - alphanumeric characters" in the instruction manual.To change the shop name on the receipt, see the section called "Programming various functions - programming of print messages".Once you have given those two a try, I can point you to any other parts of the manual you will need. Just let me know what else you want to set up.
Posted on Nov 23, 2011
Electroboy
  • 1648 Answers
SOURCE: I have a Sharp Register ER 2782A Serial number 29000302 and I am looking for a Round ink pad and ribbon to replace the old one I have
Now that is an old machine. 1980 model. They were called endless ribbon and ink roller. I don't think you will find any Sharp dealer who can supply these now. If you want to keep using it, you will probably have to adapt one of the ink cartridges from the other models.If you need more information, C-tech still has all of the manuals for the ER-2782A here:http://the-checkout-tech.com/manuals/cashregisters/Sharp3.php
Posted on May 11, 2012
Testimonial: "thanks for your help"
How to do a settlement on end of the on sharp xe-a303??? Please help???
Key to X1/Z1 mode then press decimal point. Then press TL (cash).
If anyone needs a Sharp XE-A303 manual, one of the users has it here: http://the-checkout-tech.com/manuals/cashregisters/Sharp13.php
Oct 30, 2013 | Casio Parts Cash Register PC Desktop
I have a sharp er- a242 and a e34 will not clear itself from my register?! How do i fix this?!
E34 is an overflow error. It may be that the price you're entering is higher than the maximum allowed for that department. The default program is $10,000.00, I think, but can be programed as low as a penny.
Or maybe you entered a price with a decimal point in it? $2.95 is entered by just touching the numbers 295. (Sorry if I'm insulting your intelligence. Just trying to cover all the bases here.) Clear it with the CL key and try it again.
Maybe the register's Journal has overflowed. The ER-A242 stores 2000 lines of activity, but they should be printed out sometime. Turn it to X1/Z1 and touch:
700 . @/FOR CA/AT/NS
It's going to print a bunch of stuff - be sure you have enough paper loaded for it. If you have to pause, turn to the MGR mode. Page 60 of your manual has the details.
Maybe you've finished a sale - almost - by tendering part of what is owed on it. Touch CL to clear the error, then #/TM/SBTL to show exactly what is owed on the sale. Enter exactly that amount and touch CA/AT/NS.
I hope one of these ideas works - I have decades of experience on Sharp registers, but almost none on the ER-A242, so I could be completely wrong here. But none of these solutions will damage anything, so try them and let me know which, if any, help.
Jan 19, 2013 | Computers & Internet
How to get grand total of the month on sharp cash register ER-2385
I can't believe we still have a book for this one - the ER2385 began production in 1987!
Most business owners take their totals daily. You probably have, too, by turning the key to Z1 and touching
. CA/AT (I hope you can the decimal point in front of the CA/AT. It's essential.)
To take monthly totals, do exactly the same thing, but in the X2/Z2 position.
Note that these totals are monthly only because you print them monthly. If you do it every Saturday night, you'll get weekly totals. The register prints totals that have accumulated since the last time you took a Z2 reading. It's up to you to make them monthly by taking them monthly.
So, on January 31 take your usual nightly total, then the Z2 total. Taking the daily one first ensures that today is included in the month.
Skipping the decimal point before the CA/AT will give you an X2 total. The same numbers will be printed, but they won't be cleared back to zero. That's fine if you want to see your totals so far, without messing them up, but if you forget it at the end of January, then February's totals will include both months. The same rule applies to daily totals. Use the decimal point if you want the numbers cleared.
While the CA/AT key gives the familiar department totals, other readings are available.
PLU gives your PLU totals, if you use them. (X1 and Z1 only)
#/TM gives totals for each hour of the day (X1 and Z1 only)
SBTL gives a total for each day of the month (X2/Z2 only)
Dec 30, 2012 | Computers & Internet
How do i get manager reading on my er a330
I think you mean your end-of-day money totals:
Turn the key to X1/Z1
Touch the decimal point, then the CA/AT/NS (CAsh, Amount Tendered, No Sale) button - or maybe it's just CA/AT on the -A330.
It will print out a Z reading: the day's sales totals and clear them back to zero, except the Grand Totals at the top of the tape.
If you skip the decimal point it will print an X reading: the same tape, but will not clear the totals, so they can continue building. You can print an X tape several times a day if you're curious about sales, so far, without messing up anything.
I talk about Z totals as a daily total, but they accumulate for as long as you let them, before taking a Z reading. It is only a daily report as long as you take it daily, as most business owners do.
Nov 19, 2012 | Sharp ER-A330 Cash Register
We are using a Sharp XE-202 cash register. Is it set up to give you the total tax collected each day?
Yes. As long as the tax has been set to your product buttons, you should see tax totals on the standard report in X1/Z1 mode
Jan 31, 2011 | Casio Parts Cash Register PC Desktop
Hello, I have a sharp xe-a404 I need to know how to do daily reading to bring all totals back to zero so I can start new day. Thank You!!!
turn the key to X1-Z1 enter the decimal and press cash. however this will not reset the Grand Totals unless its been set in the service mode.
Sep 10, 2009 | Sharp XE-A404 PC Desktop
ITS DOING NOTHING
I'V GOT A CASIO TK-2300 ELECTRIC CASH REGISTER.ON SCREEN IT SHOWING INDW OVER 0 WHEN I PRESS ANY KEY IT SHOW MAC-CODE 0 THE NUMBER PAD IS WORKING.IF I TURN THE KEY TO REG1,REG2,RF,PROGRAM IT STAY SAME BUT IF ITURN KEY TO X1,Z1,X2/Z2 IT SHOW OPE ERROR 0.CAN SOME ONE HELP ME TO SOLVE MY PROBLEM.THANK YOU.
Apr 16, 2009 | Casio Parts Cash Register PC Desktop
SHARP ER-A440
2. Master reset (All memory clear)
There are two possible methods to perform a master reset.
· MRS-1
Used to clear all memory contents and return machine back to its
initial settings and return keyboard back to default keyboard layout.
Procedure
1) Unplug the AC cord from the wall outlet.
2) Set the MODE switch to the (SRV¢) position.
3) Plug in the AC cord to the wall outlet.
4) While holding down JOURNAL FEED key, turn to (SRV) position
from (SRV¢) position.
· MRS-2
Used to clear all memory and keyboard contents.
This reset returns all programming back to defaults. The keyboard
must be entered by hand.
This reset is used if an application needs different keyboard layout
other than that supplied by a normal MRS-1.
Procedure
4) While holding down JOURNAL FEED key and RECEIPT FEED
key, turn to (SRV) position from (SRV¢) position.
5) Key position assignment:
After the execution of MRS-2, only the RECEIPT FEED and
JOURNAL FEED keys can remain effective on key assignment.
Any key can be assigned on any key position on the main keyboard
i found this on the manual at this site...
http://www.skan.com/Manuals/A440/ERA440-SRV.pdf
Jan 26, 2008 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
148 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
