Question about Kelvinator Freezers
It is not cooling . I have been advised to wash it with hot water to melt the ice in the refrigetor
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Inside rear panel bulging
Unplug the unit and take out all the drawers and remove the back (behind the drawers) panel carefully. (This back panel has foamy thermal insulation behind it and this will be probably be enmeshed with ice - you may have to wait awhile for this ice to melt before you can remove the panel, even after you have unscrewed it.
When you have got the back panel off, you will see a large solid block of ice, probably halfway up the cooling coils, right down to the bottom of the exposed space. You have to melt all this ice (I used a hair dryer to blow warm air onto the ice (have towels and a bucket ready to mop up the melted water, otherwise it will run over the floor. When you have melted all this ice, you will see a drain hole at the bottom of the exposed space. This will have ice in it and it must be cleared.
Then replace the back panel and all should be OK.
The panel bulges because ice/water is accumulating behind the panel, water, when it freezes, expands, forcing the panel forwards.
I reckon it's a Hotpoint Design fault. What is supposed to happen is that during the heating cycle, melted ice drops down from the cooling coils and down the drain hole onto a plate over the compressor unit, where it evaporates. BUT, during the cooling cycle, a fan circulates cold air from the cooling coils, through the entire unit, which includes the chamber behind the panel that is below the coils. Thus this chamber gets cold (-18 deg.C) so that water dripping down during the heating cycle is frozen before it has a chance to fall down the drain hole.
I now defrost in this manner every six months or so. Sadly, very sadly, Hotpoint, like other white goods manufacturers (Baxi Potterton boilers for instance) do not reply to my enquiries.
Hope this helps.
Feb 19, 2013 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Unit makes ice,full evaporator,is very slow,maybe 45 mins. from harvest to harvest. Why so slow?
Possible causes are many
Things to check
  • If air cooled, is the condenser coil clean and is the condenser fan running when in ice production ? Is the area extremely hot where the ice machine is located? If water cooled, is there adequate water pressure and is the water regulating valve set properly?
  • When the system switch is in the off position is there any water running ( if so the inlet water valve may be stuck open)
  • When in ice production, is the small tube that feeds from the hot gas solenoid hot? This tube comes from a valve at the back of the unit and feeds over the compressor and into a tee near the insulated Tx valve. This line should be hot during harvest and cool shortly after harvest.
  • Has the float switch assembly been cleaned. this is a cylindrical unit beside the water pump,It can get plugged with minerals and not initiate harvest
  • The system may have a refrigerant charge problem (short) or the compressor may be weak, at which point diagnosis would need to be done by a refrigeration tech
Hope this helps
Oct 29, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Our sub zero seems to defrost in cycles. Not sure why ice cream melts in there while other meats remain frozen. Is this an expensive problem?
The defrost may be lasting too long....and ice cream is always the first thing to melt... you need at least 10 F to keep ice cream hard...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Sub-Zero Freezers
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
Frost free freezer forming layer of clear ice on floor of freezer
This sounds like clogged drain / hose in the freezer compartment, here's why:
When the defrost circuit turns on, the compressor turns off. The defrost coil melts frost that collects on the freezer coil and drips in to a small pan located below the coil. The pan is formed so that the water that drips in it can flow to a hose connected under it. When the defrost cycle completes. the compressor runs again, bringing the temperature in the freezer to about 0 again. Any water remaining anywhere in the freezer will turn to ice very quickly.
If the hose should become clogged with ice, or slowed by mold, bacteria, etc. - water flow will be slowed, and / or eventually stopped. Ice will become thicker and thicker on the floor of the freezer as there is no place for the water to go.
A service manual for the appliance would be a good idea, but may not be required. You'll need to unplug the freezer and empty the contents. Defrost manually with a hair dryer or other heat source. If you decide to chip away ice, do so carefully.
The defrost and drain area of most refrigerator / freezers are located behind the rear panel of the freezer compartment. This is where the manual would indicate where the parts are located. Remove any ice maker installed if needed to remove the back panel.
Defrost any ice previously hidden by the panel. Chipping ice here should be a last resort, as sharp edges can damage cooling coils, tubing and the drip pan itself. Use a turkey baster filled with hot water to direct a stream at the area of the pan filled with ice. Hot water will likely have to be directed down the opening on the pan to melt ice in the hose as well.
Once the ice is cleared, mix about a 10% to 20% solution of bleach and water (1/2 ounce bleach to 3 ounces water) and direct down the drain hose. This will kill and inhibit further growth of mold and bacteria in the hose, which should help it drain water quickly.
Re-assemble and plug into power.
I hope you found this Very Helpful. If you need more help, ask again - but include the freezer manufacturer's name and model number. Good luck!
Dec 03, 2009 | Freezers
I have a maytag freezer does it self defrost?
If it has a fan in it, it's self defrosting. The moving air burns away the frost and 8 out of every 24 hours, the defrost timer will turn a heating element in the cooling coils, to melt away any ice buildup.
If it isn't a self defrost model, you can safely defrost it woth a pan of hot water. I also use a spray bottle woth hot water to help the process. DON'T use anything electrical to make the heat. Water can drip into or onto it and you could get electrocuted.
Sep 03, 2009 | Maytag Freezers
Refrigerator whirlpool model wrx38rwh6
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 26, 2008 | Freezers
Kenmore upright freezer
You should check the drain hose inside underneath the freezer.This is done at the back down below. Mine was looped too high and water could not get out. I took the loop off that was holding the hose and now water can drain away without freezing. You can pour warm water down the drain hole to melt the ice in the tube if you remove the grate covering it inside the freezer. I have read that several Kenmore upright freezer
owners have the same problem. I was astonished that this was the problem and I had put up with it for too long, defrosting the freezer every 2-3 months!.Give it a try!
Nov 27, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
64 people viewed this question
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
