Question about Kelvinator Refrigerators
Service center in Islamabad, - Kelvinator Refrigerators
My sim is reject so cant open it i dont have my nic so how i can open it
Contact to ur service provider,
contact details:
Head office
Address
13-K, Moaiz Center, F-7 Markaz, Islamabad, Pakistan
Phone +92 51 111 345 700
Customer Relations:
Mailing Address
P.O. Box 345, Main Mall GPO Lahore
Phone +92 42 111 345 100
Email telenor345@telenor.com.pk
Mar 14, 2014 | Google Computers & Internet
Sim card registration fail nokia 1110 islamabad pakistan
it can be block to a particular network provider,this can be fix by patching the serial or the imei number so it can be used,the only way to fix this problem by using a gsmgadget and a fbus cable,available in any mobile service shop near you.
Jul 27, 2011 | Nokia 1110 Cellular Phone
Solution of Problem (Cannot send sms)
I hope you can receive text sms. We have never come across sending and receiving text messages problems related to handset. If you can receive, then you can send them, except your messages settings. I don't understand when you say "Warid" anyway, if you haven't reset the phone to it's factory default, please do it now using the code 12345 (i hope you haven't changed it, if so, use your code). Go to settings > Restore factory > Ok and enter the code 12345 when you are prompted. Your phone will automatically restart after it is reset. Now try sending a text message once again. If this doesn't help, then follow the instructions below;
Go to Messaging > Options >settings > text message > message center (note the message center in use as soon as you open the "text message") then highlight the message center name which is in use, select it and check the center number (you'll need to refer to another sim card's message center with the same service operator). [also set "reply via..." as "no" and "delivery.." as "maximum..."] If it's different, then make the changes and save it. Now restart your phone and try sending the text message again. If the problem still persists, it's from the service provider, call the customer care of your network operator and tell them your problem, they'll help you fix it.
Good luck.
Thanks for using FixYa.
Jun 23, 2010 | Nokia E63 Cell Phone
NO WATER INTAKE WHILE RINSE OPTION IS ON
It sound like the cold water inlet valve is faulty, the rinse cycle uses only cold water, and the water in the 'wash' cycle is probably hot.You need a new inlet valve, which on your machine is probably a double hot/cold unit.If you can't get a new inlet valve, a handyman/electrician may be able to change the wiring to use the 'hot' inlet valve for cold water which will allow the machine to wash, and rinse, using cold water through the hot valve..Tikka?...Good luck...Nomess
Jun 01, 2010 | LG WFT1071TP Top Load Washer
May i finde any service centr in Islamabad Pakistan
I guess there is no Canon service facilities in Pakistan. Sorry
Aug 04, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
RAV 4 USer and Service Manual
You can register here and get access to the owners manuals (I would think the service guide/recommendations too): http://www.toyotaownersonline.com/Owners/reg.do
Oct 03, 2008 | 2004 Toyota RAV4
Refrigerators Logo
37 people viewed this question
Top Kelvinator Refrigerators Experts
Charles T Nevin
Charles T Nevin
Melissa Martin
Melissa Martin
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
