Question about Binatone Latitude 150 PMR Two Way Radio Twin Pack BIN/LAT150
One unit is constantly in rx mode, can I turn that off?
  • 21 Answers
If it is showing the Receive symbol all the time but does not receive the radio has a fault in the receiver. Can be repaired, price as per XTR446
http://www.proteaelectronics.co.uk/repair-services-20-w.asp m9lcd6
Posted on May 10, 2015
Uniden gmr2638_2ck is always stuck on receive. Rd is always showing and static coming from the speaker
Adjust your SQUELCH control or setting so that the noise disappears. The RX indicator will go out.
Mar 01, 2015 | Uniden Radio Communications
One of three Uniden GMR3740-3CK constantly recieves static that goes on and off. tried swapping batteries and did not work. rx display goes on. Very annoying. Other 2 radios are fine. Is there a setti
Well, it IS the squelch level. Most radios do not have an adjustment for this. Take the bad one back, you've done all the tests you can. Good job.
Jan 07, 2015 | Uniden Radio Communications
Static noise rx
Check your batteries. Static can be a sign of a bad or low battery. Swap batteries between the units to see if the problem moves to another radio.
Also, check your antenna and antenna connection.
Best regards.
May 13, 2013 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
RX-V665 turns on for a second then turns off
don`t open it yet
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 13, 2012 | Yamaha RX-V665 Receiver
Uniden uh064sx-2 2-Way RX Stuck On
Didyou have any luck resolving this issue? We currently have exactly the same problem
Aug 05, 2009 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Jul 23, 2009 | Cobra Radio Communications
Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Jul 06, 2008 | Cobra PR4100-2WXVP 2-Way Radio
Constant Rx
Hi, It would initially seem that your auto squelch is malfunctioning. With the squelch apparently way down, the RX indicator would automatically appear as if you are receiving something (even if it were just noise). Assuming no other fault except the auto squelch, a possible workaround is to use any of the 38 CTCSS codes both in receive and transmit. With the CTSS activated (TX/RX), even with squelch all the way down or auto off/defective, you will not hear anything except a radio transmission with the correct CTSS code. Again, this will only work of course with just the auto squelch muting problem. Any other problem/fault and this method may not work. Hope this be of some help/idea. Post back how things turn out or should you need further information. Good luck and kind regards.
Sep 03, 2007 | Uniden GMR638-2CK (22 Channels) 2-Way...
Binatone Latitude 150 PMR Two Way Radio Twin Pack BIN/LAT150 Logo
241 people viewed this question
Top Binatone Radio Communications Experts
ray gallant
Steve
Steve
Are you a Binatone Radio Communication Expert? Answer questions, earn points and help others
