Question about Hoover Washing Machines
How do i fix my hoover washing machine that show a03 error
It was good in first attempt second attemp is not drying and show error code ao3
    Genius:
  • Hoover Master
  • 1,585 Answers
Check pump
Posted on Apr 19, 2015
Hoover washing machine model dny d8p error code ao3.makes some cranky noise while washing ,,specially when spinning..not drying well
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Apr 11, 2015 | Hoover Washing Machines
My hoover washing machine model dyn d8p has a code error of ao3/t know what is wrong ..its new and just used then 3 month now but it was not drying well and showing that error code
if it is 3 months old , I suggest that you call the repair shop as it is under warranty
touching it yourself or having any unauthorised person fix it will void the warranty.
Apr 10, 2015 | Hoover Washing Machines
Hoover VHD sensor Dry shows Eo8 vibrate badly and stops any suggestions please regards Peter
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/specific-faults/3070-hoover-vision-hd-washing-machine-fault-codes.pdf
Mar 09, 2015 | Hoover Washing Machines
E15 error hoover
my washing machine HOOVER DST 10146 P is showing error code E15 what does it mean and how to fix it?
Jan 03, 2014 | Washing Machines
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Hoover washer dryer Error Code E12 during dry programme. How can I fix?
E12 means a problem filling on dry cycle.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
Nov 03, 2012 | Washing Machines
ERROR CODE H02 ON MY HOOVER SENSOR DRY WASHER DRYER WD9616C
Hi I have the error code ho2 on my Hoover wash machine does any one no what it means
Oct 21, 2012 | Washing Machines
Hoover AAA 160 Washer error code 4
PLEASE INSPECT DOOR BOOT (RUBBER DOOR GASKET) IF NOT CAN BE FILL VALVES NOT COMPLETELY TURNING ITSELF OFF ,,, IF ALL LOOKS GOOD REPL/ PRESSURE SWITCH
Nov 29, 2008 | Hoover AAA160 Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
