Question about Eclipse AVN5435 Car DVD Player
Open button will not flip the screen for cd or dvd use
Cd-rom ate dvd disc
In most cases the screw is on the bottom, flip laptop over, there should be one or two screws located in that square, remove them, "sometimes a button release" open tray door and pull out until driver slides right out.
Apr 25, 2012 | ASUS 15.6 AMD C60 3GB RAM 320GB Hard Drive...
The DVD/CD drive won't open
There's a little hole in the front of the dvd drive (it may be behind the flip down cover). Stick a paperclip in the hole while pushing the eject button.
Jan 21, 2012 | ASUS Computers & Internet
I would like to know if there is a way that I can burn the videos from MY Flip device to dvd's through the dvd burner? if not directly, can it be done through the computer?
im not sure on your FLIP device using jvc everio but if it has a dvd burner in its program i dont see why you could'nt burn it to a dvd
you would have to convert your video to a dvd format Any Video Converter is a freeware program you can find it at cnetdownload.com
http://download.cnet.com/%7Bvalue=http://www.download.com/any-video-converter/3000-2194_4-10661456.html Any Video Converter is an all-in-one video converting freeware with easy-to-use graphical interface, fast converting speed, and excellent video quality. It can convert almost all video formats including DivX, XviD, MOV, RM, RMVB, MPEG, VOB, DVD, WMV, and AVI to MPEG-4 movie format for PSP or other portable video device, MP4 player, or smartphones. It is the freeware to convert video files between multiple formats and download YouTube videos
you must connect the device to the computer once its connected you will be able to see it in my computer click start right click on my computer select open you should see your FLIP device open it you should be able see your video file.
then open up your burning program depending on which burning program you have you can select either dvd or cd to burn an iso or make a cd/dvd movie once you have made your choice a browser should open navigate to your flip device video select it ((will depend on which burning program you have)) add to you could a graph oh how many mbs have been used once it loads select burn
hope this helps
Jul 01, 2011 | JVC Everio Share Station DVD Burner Burner
I keep getting the close the cd/dvd guide
When you flip the main cover up, and flip the CD/DVD tray down, look at the cartridge color guide label (the colored dots). See the LIGHT CYAN dot? Directly across from that dot around underneath the gray cover is supposed to be a little plastic fin. That fin pushes the sensor switch in the CD/DVD tray to let the printer know if it is open or closed. If it breaks off, then the printer always thinks the tray is open. If it's broken off, you will have to either stick a toothpick or something into the switch, or glue a new thin piece of plastic in its place.
Mar 01, 2010 | Epson Stylus Photo R320 InkJet Printer
MY in dash dvd player with flip open screen doesn't open
in dash flip tv dosent come allthe way out
Oct 29, 2009 | Car Audio & Video
Will not open
Is this a de-tach face?
Jun 20, 2009 | Clarion VRX485VD Car DVD Player
My screen won't flip out from the dash
try pushing the little * button on the remote
May 03, 2009 | Kenwood KVT-715DVD Car DVD Player
I recently purchased a 2008 Scion xB and it has the Navigation system but I can't seem to get it to do anything but flip the screen that opens access to the CD/DVD slots. The screen never displays the...
This Unit is asking for the Format Disc. It will need to be Formatted before you can use it. The Dealership has the CD that you need for this. It should have come with the Unit. Please Rate my Response, I need all the Help That I can Get! Thanks!
Jan 27, 2009 | 2008 Scion Xb
Display will not show when tv flips out!
MOST SCREENS R NOT ON IN THERE RESTING STATE, THERE USUALLY A MECHANISM THAT TURNS THE SCREEN OPEN WHEN IT OPENS, TRY SLIGHTLY PUSHING THE SCREEN BACK LIGHTLY TO SEE IF IT COMES ON HOWEVER IF U CAN RESET IT , TRY THAT IF THAT DOESN,T IT WOULD HAVE TO BE REPAIRED FROM THE MANUFACTURE
Sep 02, 2008 | Panasonic DV-169 Valor DVD/VCD/CD/MP3...
Eclipse AVN5435 Car DVD Player Logo
53 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
