Question about Panasonic KX-TG4134N 4 Handsets Cordless Phone
Saying base no power - Panasonic KX-TG4134N 4 Handsets Cordless Phone
Our phone says base no power
It is very simple, either the base station is defective or the base station power adapter is defective. I would go with the base station, but check the phone power adapter with a volt meter for correct voltage output as well..
Jan 20, 2017 | Lands Phones
I have model KX-TGE 270 and the handset on base says "base no power"
your base should have power to get the handset working.make sure your base has power , may be loose connection, pull the power cord on the base and insert back and see. or try another outlet to see if any power goes to the base.
Dec 02, 2014 | Lands Phones
Phone says check ac power
The base unit is indicating it is not receiving any AC power.
Aug 01, 2012 | Lands Phones
Handset says searching
Searching means its searching for a signal. If the phone cant contact the base it will say searching. Make sure the handset is in range of the base and the base is connected to the power.
May 16, 2012 | Uniden DECT 6.0 Cordless Phone ID
My uniden phone says - out of range
I just finished fighting my phone for this same problem.Try unplugging the base for a minute and plug back in. I had a dead battery, changed it, it still said out of range. Next I deregistered it by holding the "off" and # buttons until the menu popped up saying "deregister". I had to select "deregister without the base" to get it to work. After all this, I unplugged the base, and that is what solved my problem.
May 25, 2010 | Uniden TRU9585 Cordless Phone
The phone keeps saying searching for base
To windyhorse 51 I pressed the button on thebase of the phone, and it works now,many thanks!!
May 23, 2009 | Vtech Digital Cordless Telephone VT-2568
We had Uniden model TRU8866. Handset #2 was damaged and lost. We purchased a new phone through Uniden. It says Set #4 on it. We would like it to say #2 The new phone is a Power max5.8ghz.
In order to re-register handsets with TRU8866 base unit, you have to reset the base unit, de-register the handsets, and then re-register the handsets. To reset the base station, disconnect the power from the base and then press and hold the CID, Intercom, and Exit keys while you connect the power. Wait for the beep, and let go of the keys. Now re-register the handsets - the first one will become #1, and so on.
May 16, 2009 | Uniden Lands Phones
Motorola MD400
Take battery out of handset for one minute.
Unplug base unit (power and phone line) for one minute.
Plug base unit back in (power and phone line).
Put battery back in handset. Place hangset on base for
one minute. This got my phone up and running.
I had no battery power in the base unit, but if I did, I think
you have to remove those as well.
Apr 17, 2008 | Motorola Mobility MD41 Expandable Handset...
All of the sudden the phone just stopped working. It says 'out of range'.
remove battery from handset then unplug base from power supply. Reinstall battery in handset then plug base back in to power.It worked for me.
Dec 16, 2007 | Uniden DCT756 Phone
No Link to Base
to re-register the phone, hold down the "handset locator" button on the base untill he "charge" light flashes. then, on the phone, hold down the flash/call waiting button until the LCD screen says "handset registering." if after it registers it says "error!!!" then retry. that is what it says in the instructional booklet, but i have not done this successfully. mine keeps saying error.
Oct 22, 2007 | Panasonic KX-TG2313 Cordless Phone
Panasonic KX-TG4134N 4 Handsets Cordless Phone Logo
114 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
