Question about GMC 2004 Yukon XL 1500 Denali
2004 Yukon 6.0 V8 instrument cluster problem
What is the solution to fixing the instrument gauge cluster when it went out I called the dealer and they said if all gauges went out but the panel lights work then most likely the panel does not need to be replaced so I worked on the connection to the panel and it will come on most of the times but then will fail or some times they just start working. and the battery has gone dead twice for no reason but mabe a short ? does the connecter to the panel require service or replacing? and the battery thing someone said there are wires running over the column that wear?can someone help going crazy
  • GMC Master
  • 11,743 Answers
No DTC'S stored any modules ? Any parasitic drain on the battery ? Does scan tool communicate with the instrument cluster ? Do you know about GM power modes
  1. Access the Class 2 Power Mode in the Diagnostic Circuit Check on the scan tool.
  2. Rotate the ignition switch through all positions while observing the Ignition Switch Power Mode parameter.
Does the Ignition Switch parameter reading match the ignition switch position for all switch positions?
What type scan tool are you using ? Can yours communicate with all the modules on the vehicle ?
Select the display DTCs function on the scan tool for the following control modules:
Transfer Case Electronic Control (TREC)
Body Control Module (BCM)
Electronic Brake Control Module (EBCM)
Instrument Panel Cluster (IPC)
Powertrain Control Module (PCM)
Sensing and Diagnostic Module (SDM)
Does the scan tool display any DTCs for the control modules listed above?
Does the scan tool display any DTCs which begin with a "U"?
Posted on Apr 09, 2015
    Sergeant:
    New Friend:
  • 126 Answers
We would be glad to assist you in a repair of this cluster.
Southernelectronics.com
Posted on Apr 13, 2015
All gauges stopped working on Friday but came back on after going through checking all lights etc. After turning right signal light on ( while driving) the gauges came on. All gauges went again today and...
this is a common issue. the internals of the instrument panel clusters become defective, and is a sealed unit - the entire cluster must be replaced. this must be performed at the dealer because they need to reprogram the mileage into the new cluster with the GM scantool. you should call your local dealer with your VIN#, some models are covered by a secret / extended / goodwill warranty. if the dealer says no, request the 1800 number to contact gm. good luck!
Oct 25, 2010 | 2004 Chevrolet Silverado
Instrument cluster keeps going off and on. i have
Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Silverado instrument cluster repair
Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Yukon instrument cluster repair
Jul 25, 2010 | 2002 GMC Yukon XL
Replace spedometer cable 2003 gmc yukon xl
There is no speedometer cable on the 2003 Yukon, if there is no transmission issues like shifting problem. Your instrument cluster has gone bad, to pinpoint. Your stepper motor to your speedometer gauge has failed and needs to be replaced. You can do a search on Ebay for the stepper motor for around $10.00 which is better then the $400.00 cost of another instrument cluster.
There was a TSB on the replacement of the instrument cluster for your Yukon free of charge. The only cost to you is the labor charge unless your willing to do the job your self. Just go to the Gm Dealer and give them this TSB Number: # 07187C: Special Coverage Adjustment - Instrument Panel Cluster Gauge Needle Function - (Mar 20, 2009)
Subject:
07187C -- SPECIAL COVERAGE ADJUSTMENT - INSTRUMENT PANEL CLUSTER GAUGE NEEDLE FUNCTION
Models:
2003-2004 CADILLAC ESCALADE, ESCALADE ESV, ESCALADE EXT
2005 CADILLAC ESCALADE, ESCALADE ESV, ESCALADE EXT (U.S. ONLY)
2003-2004 CHEVROLET AVALANCHE, SILVERADO, SUBURBAN, TAHOE
2005 CHEVROLET AVALANCHE, SILVERADO, SUBURBAN, TAHOE (U.S.ONLY)
2003-2004 GMC SIERRA, YUKON, YUKON XL
2005 GMC SIERRA, YUKON, YUKON XL (U.S. ONLY)
Some customers of all 2003-2004 model year and certain U.S. 2005 model year Cadillac Escalade, Escalade ESV, and Escalade EXT; Chevrolet Avalanche, Silverado, Suburban, and Tahoe; and GMC Sierra, Yukon, and Yukon XL vehicles have reported that one or more of the instrument panel (IP) cluster gauges stick, flutter, or become inoperative. This may cause inaccurate readings, including the speedometer and fuel gauge. Special Coverage Adjustment This special coverage covers the condition described above for a period of 7 years or 70,000 miles (110,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership.
Dealers are to replace the instrument panel cluster after the condition has been verified. The repairs will be made at no charge to the customer.
For verified failures between 70,001 miles (110,001 km) and 80,000 miles (130,000 km) on U.S. vehicles, dealers are to provide the customer with an instrument panel cluster (IPC) only. Any additional costs, including labor to replace the instrument panel cluster, will be the responsibility of the customer. Dealers are responsible for the return of the customer's IPC back to the Electronic Service Center
Thank you for using fixya and good luck.
Apr 28, 2010 | 2003 GMC Yukon XL
Gauges stop working in 2003 Silverado 1500
Subject:
Models:
THIS BULLETIN IS BEING REVISED TO INCLUDE CERTAIN 2005 MODEL YEAR VEHICLES IN THE U.S. ADDITIONALLY, FOR U.S. 2003-2005 MODEL YEAR VEHICLES, GM WILL PROVIDE THE INSTRUMENT PANEL CLUSTER (IPC) ONLY, AT NO CHARGE TO THE CUSTOMER FOR VERIFIED FAILURES BETWEEN 70,001 MILES (110,001 KM) AND 80,000 MILES (130,000 KM). ANY ADDITIONAL COSTS, INCLUDING LABOR TO REPLACE THE INSTRUMENT PANEL CLUSTER, WILL BE THE RESPONSIBILITY OF THE CUSTOMER. DEALERS WILL BE RESPONSIBLE FOR THE RETURN OF THE CUSTOMER'S IPC BACK TO THE ELECTRONIC SERVICE CENTER. PLEASE DISCARD ALL COPIES OF BULLETIN 07187B, ISSUED SEPTEMBER 2008.
CUSTOMERS ARE BEING INSTRUCTED TO CONTACT THE DEALERSHIP TO ARRANGE AN APPOINTMENT IF THEY BELIEVE THEIR VEHICLE HAS THIS CONDITION. THE CUSTOMER IS BEING ASKED TO PROVIDE THE VIN SO THE IPC CAN BE ORDERED IN ADVANCE OF THE SCHEDULED APPOINTMENT. THIS WILL ELIMINATE THE NEED TO KEEP THE VEHICLE OVERNIGHT. DEALERS ARE TO OBTAIN THE VEHICLE MILEAGE WHEN SCHEDULING A SERVICE APPOINTMENT. THE VEHICLE MILEAGE WILL BE REQUIRED WHEN PLACING AN ORDER FOR THE IPC.
Condition
For verified failures between 70,001 miles (110,001 km) and 80,000 miles (130,000 km) on U.S. vehicles, dealers are to provide the customer with an instrument panel cluster (IPC) only. Any additional costs, including labor to replace the instrument panel cluster, will be the responsibility of the customer. Dealers are responsible for the return of the customer's IPC back to the Electronic Service Center.
For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after September 28, 2007 for 2003-2004 model year vehicles, and March 23, 2009 for 2005 model year vehicles, are covered by this special coverage and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to September 28, 2007 for 2003-2004 model year vehicles, or March 23, 2009 for 2005 model year vehicles, must be submitted to the Service Contract provider.
Apr 19, 2010 | 2003 Chevrolet Silverado 1500
I have a 03 yukon and the fuel guage is stuck on full does any one know what to do
There was a campaign to faulty instrument panel on your year of Yukon and you should check with your local GM dealer for a free instrument panel replacement. A special policy came out for 03-04 trucks and suvs with less then 70,000 miles, and less then 7 years old.
Subject: Special Coverage Adjustment - Instrument Panel Cluster Gauge Needle Function #07187 - (09/28/2007)
Models: 2003-2004 CADILLAC ESCALADE, ESCALADE ESV, ESCALADE EXT, 2003-2004 CHEVROLET AVALANCHE, SILVERADO, SUBURBAN, TAHOE 2003-2004 GMC SIERRA, YUKON, YUKON XL
Condition
Some customers of 2003-2004 model year Cadillac Escalade, Escalade ESV, and Escalade EXT; Chevrolet Avalanche, Silverado, Suburban, and Tahoe; and GMC Sierra, Yukon, and Yukon XL vehicles have reported that one or more of the instrument panel (IP) cluster gauges stick, flutter, or become inoperative. This may cause inaccurate readings, including the speedometer and fuel gauge.
Dealers are to replace the instrument panel cluster after the condition has been verified. The repairs will be made at no charge to the customer. Returned IP clusters will be inspected upon return and replacement of IP clusters that do not exhibit the condition will not be covered.
For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after September 28, 2007 are covered by this special coverage and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to September 28, 2007, must be submitted to the Service Contract provider.
Mar 04, 2010 | GMC Yukon XL Cars & Trucks
Instrument panel cluster and driver information center not working. checked fuses under hood, what else?
GM has had a issue with the clusters in the 2003-2005 trucks. The cluster will be replaced for free for your truck if it has less then 70k miles. I would take it to your local dealer and tell them that the voltage gauge sticks at times. They should order one for you, takes 1-2 days and replace it for you at no charge. If this does not fix the problem, you will have a new cluster at no charge.Unless the battery light comes on, the alternator should be good. This is a copy of the GM bulletin.
#07187C: Special Coverage Adjustment - Instrument Panel Cluster Gauge Needle Function - (Mar 20, 2009)
Involved are all 2003 and 2004 model year and certain U.S. 2005 Cadillac Escalade, Escalade ESV, and Escalade EXT; Chevrolet Avalanche, Silverado, Suburban, and Tahoe; and GMC Sierra, Yukon, and Yukon XL vehicles built within the following VIN breakpoints: 51100014-51247028 / 5E100002-5E223209 / 5F800001-5F882297 / 5Z100003-5Z224691
Good luck friend.
Jan 24, 2010 | 2003 GMC Yukon XL
2003 Chevy 2500 Amp gauge not working
Good luck friend.
Jan 12, 2010 | 2003 Chevrolet Silverado 2500HD
Speedometer freezes
Good luck friend.
Jan 11, 2010 | 2003 GMC Sierra 2500HD
2004 GMC Denali's speedometer not working.
I just had mine go bad in my 2004 xl.... I called the company and they said if its within 70-80 thousand miles they will assist... Mine has 86000 and they basically said "your screwed!" I have 6 kids and can't afford a 550.00 speedo that shouldnt be a burden on me... With a vehicle as nice as a denali xl it should be taken care of!!!!!!!!! This is rediculous!
Oct 04, 2009 | 2003 GMC Yukon Denali
Speedometer messed up
Jan 29, 2009 | 2003 GMC Yukon
GMC 2004 Yukon XL 1500 Denali Logo
791 people viewed this question
Top GMC Computers & Internet Experts
bigdawg7299
Jeff Armer
David Ellis Rhea
Are you a GMC Computer and Internet Expert? Answer questions, earn points and help others
