Question about Toshiba E-studio 165 Copier-scanner-printer-fax
After power outage will not turn on. fuses good. Anything else I can check?
After a power outage, the tv wont turn back on. was hoping there is a fuse that may have blown.
Hi Michael,
Yes there is a fuse in your TV too and sometimes you do escape with a blown fuse after a power outage. Please open if you can the back cover of your TV, locate the fuse. If you do not see any damaged or blown parts, replace the fuse with the same rating. If the works, enjoy watching. If the fuse blows again, the power board needs to be repaired or replaced.
Good luck.
Apr 04, 2016 | Sanyo Televison & Video
Will not power up after power outage
it contains two fuses one of 10 Amps and other for 500mA.
Replace 10Amps fuse with same type and rating.Best thing is to take this fuse and show it to the sale person of electronic shop.
Before you touch any parts of the microwave oven please disconnect the mains power chord and never touch the main power capacitor as this contains very high voltage even after disconnection.
Mar 24, 2014 | Whirlpool Microwave Ovens
Battery Back-Up not coming back on after power outage. Charged for several days without anything plugged in with trip button pushed in. Surge side still working. No beep light or anything on battery...
Does the unit have a breaker on the back? There may also be a fuse. You should be able to find a users guide on the CyberPower website.
If the unit may have failed during the power outage.
Jan 07, 2013 | CyberPower Computers & Internet
WE HAD A POWER OUTAGE.NOW MY KEURIG WONT TURN ON. CAN YOU TELL ME WHAT THE PROBLEM IS. THANK YOU.
Hi,first you need to check if fuse has not been blown out.Because when POWER comes back after an outage there is a surge voltage flowing through electrical lines.It is advisable that when their is a POWER outage you have to turn off your FUSE box or SAFETY box to make sure that it won'tdamage appliances when POWER comes back>Technically when POWER SOURCE or SUPPLY has been shut off for a period of time.When POWER is back, expectantly there is an abnormal flow of current/line; current will not be as stable until a period of time..AC current behaves like a wave,values changes from time to time especially when POWER SOURCE has just been TURNED ON..So better turn off FUSE BOX when experiencing POWER OUTAGE so that when power comes back SURGE VOLTAGE wont flow within the circuit>Hope this helps..
Jun 22, 2011 | Keurig Elite B40 Coffee Maker
My 2005 Phillips 27 in TV will not come back on after a power outage....
A power surge may well have blown your fuse. Check the fuse in the plug first. If you can't check it, just swap it with a known good one. If that doesn't do anything, then it's possible there may be a blown fuse on the TV's power board. If you don't know what you're doing, don't take the TV apart; there are high voltages stored in capacitors, even when disconnected from the mains.
May 02, 2010 | Philips Televison & Video
Wont turn on after power outage
there is a power supply board that goes bad in this set. Good luck
Aug 15, 2009 | RCA P61927 61" Rear Projection Television
Microwave-doesn't warm anything anymore
Hello rarms1965... chances are that your microwave was the recipeint of a power surge during the power outage you mentioned.. there is no way of knowing what component took the brunt of a surge and it could very well be your magnetron tube, filament transformer of any number of control logic components.. The problem is that anytime you open the case to check things.. unless you know what to look for or even more so.. what NOT to touch ( High Voltage Capacitor comes to mind) you don't know what you are up against. If it isn't a real expesive model ( you didn't provide a brand or model with your inquiry).. then the cost to diagnose & repair could very well exceed teh cost to replace.. Your call.. but whatever you do.. be sure you KNOW what you are doing..
Good Luck my friend..
Sep 24, 2008 | Microwave Ovens
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
Toshiba E-studio 165 Copier-scanner-printer-fax Logo
60 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
