Question about Brother MFC 210C All-In-One InkJet Printer
I have error 29 on my 210c
What is error 29 means and how to fix it, Thanks. P.C.
  • Brother Master
  • 1,113 Answers
Re: I have error 29 on my 210c
!!!! Magenta ink error !!!!
The ink has run out or the ink cartridge is not set into place.
26: Black ink
27: Yellow ink
28: Cyan ink
29: Magenta ink
1. Reload ink cartridges, referring to the Owner's Manual.
2. Ink cartridge PCB defective Replace the ink refill ASSY.
3. Cannot detect ink cartridges.Main PCB defective Replace the main PCB.
I know your machine was not originally showing signs of main board fault or Ink supply issues, although main board can be killed by incorrect use of maintence mode.
Posted on Nov 14, 2007
0 characters
3 Points
What to do with error 0000
Dear Inger
If your product is under IR series the error code meaning is abnormal fixing temperature.
Remedy-Go through the following to clear the error: CLEAR >
ENGIN > ERRCLR; and then turn OFF and then ON the power.
2.Check connection of the Connectors (Thermistor Connector
and AC Connector).
3.Replace the Fixing Main Thermistor (Film Unit).
4.Replace the Fixing Assembly.
5.Replace the DC Controller PCB .
Feb 28, 2015 | Printers & Copiers
My print Canon LBP 5300 show the error E001 0001 and not run. How can I repair this problem. Thanks.
this error means, that you have temperature trouble in fixing section. To repair the fault, you need to replace fixing unit.
Hope that helps!
May 31, 2011 | Printers & Copiers
Canon MX328 Error code appear "5B00" what does it mean and how can i fix that error? thanks. jodans
not work, in display printer shows error 5b00. I can't go to nv ram setting. Can you help me?
Feb 08, 2011 | Canon Printers & Copiers
Thanks for using FixYa. Error E000 means low temp detected in the fuser unit, Faulty thermistor, lamp or PCB. Check fuser for jammed paper. It’s an issue related to the fuser unit. Try and clear the error by entering the service mode:
  2. Go to #7 Printer and press OK
  3. Go to #4 Printer Reset and press OK
  4. Yes = ( * )
  5. Power cycle unit.
If this does not help, on most units you have to start looking at your Fixing Assy. or Thermistor. Make sure that you do not have a piece of paper wrapped around Upper Fixing Roller or and other foreign substance in that area. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jun 03, 2010 | Canon ImageRUNNER 3570 Copier/Printer
E02-02 - what does this error mean for a DP-C213?
E2-02 means there is an error with the lifting motor assembly for tray #2. You will not be able to use your tray #2 until it's fixed. You can check it, sometimes there's just paper clogged at the rear of the paper tray. Remove your 2nd tray to see if there is a paper clogged inside.
Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
May 07, 2010 | Panasonic DP-C213 Color Copier
I have System error E007 problem in my Canon iR-2016 copier machine?
Thanks for using FixYa. Error E007 means there is a jam in the Fixing/Fuser Assy. Error E007 is related to a non-detection of the Fixing Film/Upper Roller, the fixing film sensor didn’t detected the rotation of the film for 6 sec or more while the fixing motor is driven. Please check the condition of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error. If everything is fine then try clearing the error by entering the service mode, you can do it by pressing *(star), then press 2 and 8 keys at the same time & then press *(star) again.
Now press COPIER>FUNCTION>CLEAR>ERR, to clear the error code.
Please do rate the solution and revert for further assistance.
Sep 28, 2009 | Sharp AR-M350N Copier
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
What is an error 3807?
If this error is from your printer itself, This error code means that you need to replace the Printhead. Call Kodak so that they can process a replacement for you 1800 421 6699
Aug 24, 2009 | Kodak ESP 5 Printer
E000 error message on canon imagerunner 2000 copier
E000 means :
"The main thermistor reading does not reach 40oC 14 sec after the fixing heater goes ON (fixing low temperature error)"
Jan 19, 2009 | Canon ImageRunner 1600 Copier
Error code 173
That error means low temperature on the heat roller. The thermistor (something like an electric thermostat) measures the amount of heat needed to work. Error 173 refers a lower temperature than required, while error 172 refers overheat. The complete error list will be of no use to you, since most errors will refer you to an authorized service center.
Sep 20, 2007 | OKI B4300 Led Printer
Brother MFC 210C All-In-One InkJet Printer Logo
247 people viewed this question
Top Brother Printers & Copiers Experts
Jim Yeh
Level 1 Expert
Jesus  Colon
Jesus Colon
Level 1 Expert
Rick Johnson
Rick Johnson
Are you a Brother Printer and Copier Expert? Answer questions, earn points and help others
