Question about Vacuums
I searched the internet, could not find any parts for Carpet Magic Model CM-2H, Ser. No. 55680. Need a replacement Plexiglass recovery tank cover.
Agent Don
  • 310 Answers
SOURCE: I am lokkig for a
Generic problem for all Vacuums
I am looking for a
I am looking for a replacement recovery tank for Eureka Atlantis opti heat carpet extractor #2591...
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Unfortunately this is a hard item to find so I would advise you to contact the Eureka Factory customer service at the phone number listed below and they should be able to direct you to a dealer that sells the part or they can sell it to you as well.
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Don – The Vac Man
Posted on Apr 21, 2008
  • 17 Answers
SOURCE: recovery tank not filling
The tank has an automatic shutoff float (red) that will stop the suction if the water level gets too high. this can also happen if the tank is not level or clean as the float can bounce around and jam at the top. I've actually had this one happen). I would make sure the float is down during the cleaning and see if the suction comes back. if not, please provide more details and we'll get 'er fixed!
Posted on Feb 04, 2009
SOURCE: Lost the Front Panel of the recovery tank...need help
Try this.
http://www.usavacuum.com/F5900-s/139.htm
Posted on Apr 28, 2009
beltronic205
  • 1460 Answers
SOURCE: Replacement part: lint filter located on main frame
If uk try espares.co.uk
Posted on Nov 20, 2009
  • 97 Answers
SOURCE: my machine wont pick up the dirty water. If I take
at power head clean out area before power head also look for small hose and clean out and look at rollers,i hope this works if you have directions still they should be able to help you out some more.thanks
Posted on Nov 30, 2009
Why does my steamvac not suction the water up?
Typically there is a little red filter accessible from the bottom of the cleaner. Lay it down and flip it over to take a look. It's a little screen like filter. Large particles than can possibly cause a clog are filtered out there. Just pull it out (it will only come out part way) and clean the debris from it.
I have a Hoover Steam Vac also. Learned that trick the hard way. If that's not the problem (it usually is) then I will need the model number from your machine. Hopefully they didn't put it on the bottom of the machine where the numbers wear off. That's where mine was.
Zashiban
Jun 24, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
How do i hook up my stair cleaner part to my hoover steamvac to clean my carpeted stairs? f5909=900 model
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover vacuum carpet cleaner will not sucktion (sic)
No, this cleaner uses no belts.
If you are having a suction problem, first check that the lid on the recovery tank is lined up to the tank when installed to get a good seal.
Second, remove the tank and make sure the round black rubber seal is present on the pipe from the base that aligns with the bottom of the recovery tank. That seal connects the vacuum from the motor to the recovery tank.
Oct 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steam vac deluxe - no suction and the scrubbers aren't spinning uless you tilt off the floor.
I would suspect that your turbine assembly bearings need to be replaced. also check for debris inside the brush assembly. check the intake filter under the front clear cover. verify the recovery tank lid is on securely, as well as the foam filter on the tank lid is clean.
Oct 10, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Not Sucking the dirty water
It seems that when you emptied the recovery tank it has not been placed back proper.
please make sure it is sealed else you will loose suction
Jul 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Question-can I purchase a recovery tank front panel for Hoover Carpet Clean - F5853-900, series 17.9, serial number 069700345408? I can be reached at (304) 243-3788
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=675962
Posted by dings on Jun 16, 2008
Question-can I purchase a recovery tank front panel for Hoover Carpet Clean - F5853-900, series 17.9, and serial number 069700345408?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can contact the local factory authorized Hoover dealer in your area and they might have a good used part or they may have a new one in stock or they can order it for you if you give them the brand name and model #, serial # or choice #2 is that you can contact the Hoover Factory Parts Dept and they can ship you out one recovery tank front panel for the Hoover Carpet Clean F5853-900 Series 17.9 and serial number #069700345408.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 16, 2008 | Vacuums
No suction to retrieve water from carpet
The tank lid of your recovery tank is designed to engage two tabs to lock the front of the lid down on the seals. Look at the front corners of your recovery tank. You will see a tab extending out on each corner. These two tabs insert into the corresponding grooves in the lid. Once engaged, the lid folds down and the clip on the lid snaps into the back of the tank. When installed correctly, if you pull up on the front of the lid, it should NOT lift away from the tank. The front of the tank has a square "duct" that is removable for when the hose is inserted for furniture, etc. Make sure that this duct is replaced back into the tank when using on the carpet.
Jan 19, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
