My tv wont turn on. I turned it off like normal, came back a few hours later, and now it won't turn on.
Turned the tv off, and everything seemed fine, little red light in the corner shining away like it has since I got it. Went to turn it on, to see that little red light blink briefly before the tv turned on, but this time, it just went out, and nothing has happened. Unplugged the tv, and plugged it back in, without turning it back on, light stayed on for a second, but then went out. and now it won't do anything.
  • 191 Answers
SOURCE: TV won't turn on, please help......
change your power suply
Posted on Nov 02, 2008
djchillsnyc
  • 152 Answers
SOURCE: red light blinks 9 times on Panasonic TH-42PZ77U
hello, panasonic plasmas have a safety shut down circut to protect the main panel when a short is present or internal circut panel is non functional some info i found in the service manual for 10th generation plasma
if your tv is still under warantee take advantage of the pany free service other wise it is a matter of exchanging the defective board then you will need electronic skills for this repair if you plan to do it yourself. it would be wise to have a skilled tech check it out and give you a estimate there are some techs that will come out and check it for free and give you a repair price.
here are some repair manual tips for blinking panasonic .. i didnt find 9 blinks on this manual i may be using a different manual but these are panasonic plasma blinking fault tips for 10th gen
becuase all models have different blinking codes you may need the model specific service manual
for 10th gen model some models 2008,2007,
8 Blinks SOS:
Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
9 blinks panel config sos
10 Blinks SOS:
The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS:
The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
hope this helps..
Posted on Dec 09, 2008
SOURCE: Red blinking light
same problem, red blinking light in series of 5 flashes
Posted on May 31, 2009
  • 257 Answers
SOURCE: I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Posted on Aug 13, 2009
  • 7 Answers
SOURCE: tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
Posted on Aug 31, 2009
I had plugged my computer in the other day, turned it on and it worked fine. I put in a flash drive to copy somethings to it. Put the flash drive in, finished with what i was doing powered down and...
I guess you tried restarting the computer a couple times. You didn't accidently send the "C" drive to the flash drive? Have you tried putting the flash drive back in (if it hasn't been changed) and tried booting?
Dec 30, 2013 | Sony VAIO Notebook
Messed up Image
You need to replace both of the convergence ICs. They are both STK392-570 you can get replacement ICs at the following link and they provide free instalation instructions with pictures on how to replace the ICs. Here is the link.
http://servicemanuals.vstore.ca/
Jul 08, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Recent problem with picture
Plasma Tv panel only have a lifetime of 10000 hours. the phosphor inside the panel and the zenon, xenon gas only will last so long . Pretty much like a florescent light bulb.
Apr 10, 2008 | Televison & Video
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Messed up Image
bad connection on convergence amps or need to replace them
Oct 11, 2007 | Mitsubishi VS-50805 50" Rear Projection...
Color distortion
Problem on CRT board, this is the board on the back of the tube. It has a open transistor for the green.
Oct 08, 2007 | Toshiba 32AF43 32" TV
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
