Question about Lands Phones
#kx-tg454 phone rings once then disconnects. please help.
SOURCE: KX-T7730, all the phones connect with operator ring at the same time when having an incoming phone
please i need your help,i use KX-T7730 in my office and of recent when incoming calls comes in all the phones in the office starts ringing and also i would like to know how i can lock and unlock the phone so as to prevent other users from accessing it.Thanks
Posted on Apr 21, 2008
SOURCE: Caller Id not working, phone disconnects after 2nd ring
This problem turned out to be a phone company problem.
Posted on Jun 21, 2008
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
mohammed387
  • 1952 Answers
SOURCE: on incoming call,rings once then disconnects
reset the ring setting
Posted on Jul 01, 2009
cnavarro
  • 2460 Answers
SOURCE: on 308 pansonic pbx (kx-t7730),
When you take this unit out of the box, you get programming instructions. One of them is the ringing (program 408) for day mode. (409/410 for night and lunch). By default, all phones ring on all lines in all 3 modes. You have to remove the ring to make it go away.
Carl
Posted on Sep 29, 2010
Phone rings once and gets forwarded
Hello there,
Call forwarding is a feature of PABX and Public Exchange systems so do you mean the phone rings once and then 'forwards' to another different telephone number ? If so, then you need to contact the company / person controlling your Lines as you cannot change this on your phone.
If you mean that the phone rings once and then goes on to Answerphone, then this is down to the setting of 'ring count' which is on page 40 of your user manual downloadable here http://www.manualslib.com/manual/117136/Panasonic-Kx-Tg2431.html
If this doesnt answer your question, these please ask again and try and give us more information to help you.
Sep 25, 2014 | Panasonic KX-TG2431 Cordless Phone
I can make calls but phone doe not ring
You said "it seems to ring once then stops." One possible cause of what you're describing is called a "Ring Trip." It is characterized when the button that flashes to indicate an incoming call changes to steady red (which would normally indicate the call is answered) although no one actually answered the call. If that occurs, then you have to test to see whether you can tell where the problem is coming from. If you unplug all the phones, you can then call in (from a cell phone or other phone that's not part of the system) and see if the incoming call rings unanswered, as it should when no phones are attached. If all rings in OK, plug just one phone in at a time and call in to see if any particular phone causes the problem. If one causes the ring trip, then disconnect that broken phone. If ringing still stops when no phones are attached, you'll have to disconnect the phones' connection wires (Station Wires) at the phone system box that plug into the "Station Ports" (label them before you unplug any!). Do not unplug the plugs for the wires that feed phone company lines into the phone system, the jacks are called CO line ports. With the "Station" wires unplugged, see if If all rings in OK by calling in from a cell phone or other phone that's not part of the system. If all rings in OK, plug just one station wire in at a time to see if one causes the problem. If one station wire causes the ring trip, then disconnect that troublesome wire and inspect its "system box jack" and its phone jack for water damage, carpet cleaning solvent, exterminator spray or any other corrosive liquid damage. Sometimes a staple through a wire where there's humidity can cause the problem. This process will find the offending wire, jack or phone that causes a "Ring Trip." There are many other possibilities, but the extremely limited description you've provided "it seems to ring once then stops." doesn't help me send you a better answer yet.
Jun 27, 2014 | Panasonic KX-T7730 Corded Phone
My panasonic home phone only rings once, it used to ring normally and would also say what number is calling. please help.
We recommend you unplug the Panasonic base unit and make a test call from another number. If the line disconnects after 1 ring then you have either a telephone line problem or another device connected to the telephone line is the problem.
Mar 03, 2014 | Panasonic (KX-TG1032S) Phone
How to change the incomming ring tone on panasonic kx-t7630
Oh hell... you must be going nuts if its the ring tone I think you're stuck with. I loath the manual that comes with this system so here it is in English:
  • Press 'Prog'
  • Press 'Intercom' twice
  • Now you can either go through the different ring tones by pressing 'SEL' on the LCD screen or using the Up and Down keys on the circular pad on the bottom right of the phone.
  • Once you have the tone you like click on 'Enter'
  • Pick up handset and hangup to complete the process.
Dec 04, 2008 | Panasonic KX-T7630 Corded Phone
How to change ring tone of kx-t7730
sir please i want to when call my consol i'm not there i picup phon our telephone set plz suggest
Jun 16, 2008 | Panasonic KX-T7730 Corded Phone
Apr 10, 2008 | Panasonic KX-T7730 Corded Phone
Program manual
Your phone will work on a few different Panasonic phone systems. If you are looking for manuals on KX-T7720 and KX-T7720 all you will find is a user guide for the phone. You need to determine the model number of your phone system before starting to look for a programming manual.
Jul 17, 2007 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
55 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
