Question about Onn Optical Mouse
What is error code 43 that shows up while trying to install an optical mouse?
I am using an HP laptop windows version 8.1. Last year I bought an ONN optical mouse to use with it. It worked wonderfully until yesterday. I went and bought the exact same one. Plugged it into the same USB port. It worked. Then when I closed my laptop and returned to it a few hours later; the mouse would not work. I don't know a whole lot about computers. I did manage to troubleshoot drivers. It says all Drivers are current to run this device. However I checked events and stuff like that and it shows that there is error code 43.
I need instructions for installing onn wireless mouse model ona13ho502 on an hp laptop
Your wireless mouse should have a small removable USB (dongle). This would be part of the mouse, after removing from mouse insert in Any USB on laptop. Then turn on mouse and HP should recognize!
Sep 30, 2016 | Dell Computers & Internet
Need driver for onn optical mouse and keyboard
i think ,we no need driver for mouse and key bord but we need usb driver . driver pack solution can help us , download from Google on free.
Aug 24, 2016 | Optical Mouse Computers & Internet
Error code 31 CD ROM driver not available how to install this driver
  1. Restart your computer if you haven't done so already.
    There is always the remote possibility that the Code 31 error you're seeing was caused by some temporary issue with Device Manager. If so, a simple reboot might fix the Code 31.
  2. Did you install a device or make a change in Device Manager just before the Code 31 error appeared? If so, it's very possible that the change you made caused the Code 31 error.
    Undo the change if you can, restart your PC, and then check again for the Code 31 error.
    Depending on the changes you made, some solutions might include:
  3. Delete the UpperFilters and LowerFilters registry values. A common cause of Code 31 errors is the corruption of two registry values in the DVD/CD-ROM Drive Class registry key.
    Note: Deleting similar values in the Windows Registry could also be the solution to a Code 31 error that appears on a device other than a DVD or CD drive. The UpperFilters/LowerFilters tutorial linked above will show you exactly what you need to do.
  4. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 31 error is a likely fix for this problem.
  5. Replace the hardware. As a last resort, you might need to replace the hardware that has the Code 31 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you're convinced that hardware isn't the cause of this particular Code 31 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those before you try replacing the hardware, but you may have to give them a shot if you're out of other options.
Applies To
The Code 31 error could apply to any hardware device in Device Manager but most Code 31 errors appear on optical drives like CD and DVD drives.
Any of Microsoft's operating systems could experience a Code 31 Device Manager error including Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, and more.
Aug 16, 2016 | Computers & Internet
WHERE DO I FIND DRIVER ON LINE TO INSTALL FOR MOUSE
Try the following site for mouse drivers.
Trust this helps, regards Alan
http://www.microsoft.com/hardware/en-au/downloads
If re-installing the driver does not fix the code 43 error, you may like to browse through the following:
Are You Seeing Code 43 Error Here What You Need to Do
Apr 15, 2015 | Computers & Internet
What is code 43
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Jan 23, 2013 | Lenovo Computers & Internet
The cursor jumping , when i typing my e-mail letter or use word etc... some times often some times selten ..etc? ptakach@cox.net
What type of computer do you have (laptop or desktop) and what model ? what versions of Window, what type of mouse ( usb, wireless, mouse with ball underside, optical mouse, etc )
And did this happened after a software upgrade or installation ?
What happens when you replace the mouse with another mouse, does it do the same thing ? If you haven't tried with another mouse
try doing that first as it may need to be replaced (depending the type of mouse) and that may solve your problem.
Dec 27, 2008 | HP Compaq Presario V2000 Notebook
Onn Optical Mouse Logo
65 people viewed this question
Top Onn Computers & Internet Experts
Bill Boyd
joel maureal
Mister Danger
Are you an Onn Computer and Internet Expert? Answer questions, earn points and help others
