Question about Dewalt Tools & Hardware - Others
Model xrp dc988 is a schematic of the gearbox available on line?
  • Dewalt Master
  • 1,885 Answers
Search Results dc988KA there is a parts list
Posted on Oct 12, 2016
My dewalt 18 volt Dc988 XRP will not engage when you squeeze the trigger all the time. It goes in streaks or is intermittent. Also the variable speed is not working. it only goes one speed.
Your switch is having a problem it can be caused by excessive load on the motor.
The motor must be sounds not shrill and must have power , the most people think on the batteries but in more case by switch problems its the motor there is a field effect transistor inside the switch behind the cooling brass plate thats shorted and that is for the variable rpm .
Replace switch and if the motor sounds good then the problem should solved. if also the motor is bad go for a new replacement body ask your dealer.
May 09, 2017 | Dewalt Drills
I own a DC988 XRP drill. I recently used it for drilling some holes. While drilling I heard a pop and now the drill only spins at a slow speed. Any advice as to what component needs replacing? Brushe
That drill had several speed options, do you have it on high?
Brushes are usually a power/torque issue and wouldn't effect speed unless they were really bad
Nov 29, 2014 | Drills
Dewalt dcd950 chuck
Its is about a 2 years modified the XRP chucks In Netherlands the model 950 is not QS made for europe but all the XRP machines have had a special solide looking Chuck For the original Chuck there was a special tool to remove the chuck the gearbox must be open to and a special N119912 a complete unit of repair tools to remove the chuck and replace , BUT the new modificated repair is by get a normal standard keyless chuck , asked them for about the modification because of the older repair tools and chuck http://www.2helpu.com/world/map.aspx it's about much more cheaper to choose for modification the N119912 is possible renumbered thats possible the right same tool because of the model DCD 950 is not selled in Netherlands . the DCD945 instead of but it means the same kind of modification .
May 29, 2014 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Switch sometimes does not work
The switch on these drills is notorious for doing exactly what you describe. One thing to check is the battery terminals on the bottom of the switch, they get bent or broken off easily. It could also be internal to the switch but the only fix is to replace it. You need Dewalt part number 152274-22 to repair the drill. It's a fairly easy repair but shop the internet, they cost from $55 to $75 plus shipping.
Feb 03, 2012 | Dewalt DC988ka 18 - volt XRP 1/2''...
Need repair schematics for dc988 dewalt cordless drill
web search-dewalt dc988 schematics-click on 2nd site,{parts list and diagrams
Oct 06, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
Need workshop manual for dc988
Here is a download for the manual you want.
http://toolnet.dewalt.com/Toolnet/OMrepos/00A5C2051109D14300800003A4D6051F.pdf
You could download to a cd or print it out. Whatever is best for your workshop.
Hope this helps.
Jan 05, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Diagram for rebuilding DeWalt DC988
Yes.
Go to dewaltservicenet.com and look up your model. (Hint: Press the "Go" button on the screen not the Enter button on your keyboard to submit your model in the field). Make sure you have your type number available.
If your transmission is in a million pieces I can help you get it back together. There is no diagram for the transmissions.
Sep 18, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18v drill dc988 type requires switch
Here is a link for a parts diagram for your model. It has the proper part number that you will need.
Hope this helps.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/dewalt/DC988KA_TYPE_1
Sep 07, 2009 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Dewalt xrp 18 volt hammerdrill. Need gear schematics.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will take you to a page where the schematics are.
May 24, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Dewalt 18volt drill xrp dc988 in pieces
If you are in the U.K. go here fore tech help and service dealer locator etc https://service.toolcommerce.com/products/HomePage.aspx?BrandId=2&language=en-GB&country=GB
If you are elsewhere go to www.dewalt.com and you can navigate to other countries etc from there.
Oct 21, 2008 | Drills
Tools & Hardware - Others Logo
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
