Question about Tablets & eReaders
Why my tablet can not get wifi - Tablets & eReaders
I got new gigaset qv830 tablet can't connect to wifi & this is my first android
Android Tablet Wi-Fi Authentication Problem [Solved ...
www.tomshardware.com/.../45501-43-wifi-authe...
Tom's Hardware Guide
Oct 23, 2014 - 20 posts - ‎17 authors
I have a new Android Tablet, it seems to work okay, but I keep getting ... I am DETERMINED to get this tablet connected, though, and when I find ...
Gigaset 8" Quad Core 8GB WiFi Android Tablet w/Google ...
www.qvc.com/Gigaset-8-Quad-Core-8GB-WiFi-Android-Tablet-w...
QVC
Free
This holiday season, wrap up the gift that tops their list with this Gigaset QV830 tablet. Work and play--all from the same device.
Newsmy tablet T3 problem wifi connection - YouTube
? 3:48
https://www.youtube.com/watch?v=PSR9QU2eph8
Jul 31, 2012 - Uploaded by Jan Ochotnicky
Newsmy tablet T3 problem wifi connection. ... grey wifi/cant connect to google play error fix (root ...
[PDF]Gigaset QV830 Tablet - User Manual.pdf - liGo
Dec 26, 2015 | Tablets & eReaders
I fix the broken screen on my RCA tablet and now my Wi-Fi won't work.
Droid Pro: wifi won't turn on - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Motorola Droid Pro
Dec 17, 2012 - 25 posts - ‎23 authors
Ok so I tried to turn on my WiFi in the settings and it would say turning on ... myphone, done a factory reset and even used a WiFi fixing app. ... wifi fixer doesn'twork. ... to lock my phone without the screen staying on for 15 seconds or so. ... I was having trouble turning on wifi on my tablet and one of the post ... Auto Rotate does not work.
May 11, 2014
New Tablet/Authentication Problem with Wifi
Dec 17, 2013
WiFi stuck "turning on"
Aug 18, 2013
More results from forums.androidcentral.com
Android Tablets Forum - Tom's Guide
Dec 15, 2015 | Tablets & eReaders
My tablet,so i can get wifi and a network i had it working before on my tablet
hello sir,
something wrong with the tablet settings then, please check it and get it back to how it was when you got the wifi and the network signal
also, make sure that the wifi signal exist, by another phone, or tablet, so you be sure about it
if the settings are okay, and the wifi is ok, then its the wifi and network chip at the tablet
good luck
Oct 24, 2015 | Amazon Kindle Fire HD
Authentication problem. Reset wifi and tablet. Nothing is working.
An "authentication problem" means that that the wifi does not accept the wifi password that the device is providing, or that its MAC address may be on the exception list, not allowing it to connect. Verify that the tablet is using the proper wifi password for the system you are trying to connect to, and that you are using the same wifi security (WEP/WPA/WPA2) on the tablet that the wifi is using.
Oct 04, 2015 | Dragon Touch Touch R10 10.1 Google Android...
Why Tablet Wont stay connected to wifi?
this may be because they wifi goes away and comes back again. or maybe because it's messed up .
hope this helps.
Feb 06, 2015 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
I can not connect to the internet with my zeepad. I bought both of my daughters the same model tablet and they can get on the internet with their tablets.
Most tablets connect to the internet through WIFI. Only a few can use SIM card to connect through 3G or 4G data connection. For WIFI connection, you must have a WIFI router at home. You will normally password-protect the WIFI rounter. To connect the tablet to the internet through the WIFI-router that is in operation, you will configure its WIFI settings to match the router's password. This will be done by going to tablet's Setting, turn on WIFI, click on your router in the list of detected routers, enter the password when prompted. Ensure that Connected is shown against your router. You can then browse the internet.
Jan 10, 2015 | Tablets & eReaders
Tablet says i am connected to wifi but cant access anything online
Have you tried mutiple wifi sources to verify its the tablet or just your home wifi, reinstall the wifi drivers if possible....
Mar 02, 2014 | Archos ARNOVA 10b G3 8GB 10" Capacitive...
Wifi for my Tablet
Thank you for the Video, this made it much easier for me to determine the problem. You are correct, you have WiFi, this is not the problem, the problem is with the Tablet's WiFi Service which is freezing, thus not causing you to access WiFi.
Have you installed any new software lately? Something has broken the WiFi software on your Tablet. If you installed a new App recently, remove it to see if that new App broke your WiFi software on your Tablet. If you have not installed anything new on the Tablet maybe the manufacture downloaded an update that broke the WiFi on the Tablet. If you recently received an Software update from the manufature, let perform a Factory Resetr on the tablet to fix the issue.
Jun 11, 2013 | Tablets & eReaders
Wifi issue
When you reset the tablet your tablet wifi settings, wifi name and password will be erased. You have to detect your wifi on the tablet, connect to it and enter password right?
Oct 17, 2017 | Lenovo Tablets & eReaders
Unable to connect to wifi it just says scanning
make sure your wifi network is turned on, then open your tablet's wifi and search for it. it should be fine, if not, contact Toshiba for tech help.
Android 4.0 Tablet PC
Feb 04, 2012 | Toshiba Thrive Android Tablet
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
