Question about Watches
Where can I get a new band in Baltimore City for my MDC74564W. Went to 2 elite jewelers in the area no one can replace watch band
    Master:
  • 346 Answers
You'll probably have to go back whee you bought your watch or at least find the company website and look under user support.
Posted on Apr 09, 2015
  • 3 Answers
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Posted on Mar 04, 2008
escapement
  • 2334 Answers
SOURCE: Invicta 2875 wrist watch band too large
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
escapement
  • 2334 Answers
SOURCE: Adjusting band on brand new Invicta Professional Dive watch
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Job done!
Posted on Mar 20, 2009
escapement
  • 2334 Answers
SOURCE: How do I shorten the watch band?
Job done!
Posted on Mar 28, 2009
SOURCE: Replacement bracelet for Tag Heur 6000 series, model #WH1151.BD0678
Perhaps this replica watch and strap would fit. It's $295
http://www.salesreplicawatch.com/Tag_Heuer_6000_Series_Mens_Watch_WH1153.BD0678.html
Posted on Aug 26, 2009
Casio Fisherman (PAS400B) watch replacement clip for spring pins
mcdevito75 here, I'm surprised a jeweler couldn"t help. Here is Casio"s contact number, speak with them, TIP, get a spring bar 1/2 MM smaller and larger than what you measured. Contact Casio at 800-435-7732 9AM-----5 PM EST. hope this helps.
Aug 03, 2010 | Casio Forester PAS400B-5V Wrist Watch
I have a women's kc1239 wrist watch. I've brought it to my jewelers to fix the pins near the clasp, but noticed the 2nd pin down from the watch face was broken, too. My jeweler said they cannot fix this...
I am sorry but u are going to need to replace the watch band, the jeweler is correct, did he suggest the correct replacement band, he should have a selection of bands that will work with this watch.
Dec 07, 2009 | Kenneth Cole KC1239 Wrist Watch
I have an invicta pro diver watch with stainless steel band. I need to buy 2 or 3 links and pins. Would a new band be better and where do I buy either item? Ilive in area code 75601, Longview, Texas. Thank...
I know of a couple places in San Antonio and Austin that would be able to custom fit your new band or help you with a repair.
Precision Time
They are located in the malls in either city. They also have a web site.
PrecisionTimeCo.com
You can try to contact Invicta for new links and they may have them depending on the age of the model. Look at your owners manual for contact information.
Sep 18, 2009 | Invicta Automatic Pro Diver 8926 Watch
Casio G-Shock GW-300 replacement bands
I have a Casio g-shock gw-330a and now find myself again replacing the band. So far, $60 on bands. They last me two or three years. To install the band, take the band and watch to a Jeweler. My local Sears does it for me. $5 for installation; $5 for purchase shipping; $20 for band. $30 every couple of years.
This cost disturbs me.
Jun 09, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Replacement band for the Invicta 2307
SORRY but FIXYA sells nothing .check with your dive shop
Aug 17, 2017 | Invicta Watches
Discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Jan 25, 2009 | Nautica N07574 Wrist Watch
Mens bueche girod 9k gold watch the gold band is 1 inch short
You have two options and for both you need to find yewellery repair shop.
Option1) Some jewellers sell NOS (New Old Stock) gold watch bands. If your vallet is thick enough for this option- shop around and buy one.
Same jewellery repair shop will be able replace the old band with the new one, even if the band is soldered to watch case.
Option2) In the same shop ask if they can built up (lengthen) the clasp. In this case you will spend less money, but you will loose on looks.
Note: As mostly all gold watch bands are maschine made, it is allmost impossible to repair or lengthen them in a good looking way. Anyway- consult the jeweller first and see what he says. He may have some NOS witch is exactly matching your old watch band pattern.
Good luck.
Jan 01, 2009 | Watches
Resizing my watch
screw
small jeweler tools
take to jeweler for 5 bucks they will knock a link or 2 out for you
Jun 12, 2008 | Invicta Pro Diver 9745 Clip-on Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
