Question about Irritrol 6 Station Rain Dial RD600-EXT Outdoor
Irrigation control box on irritrol rd 600 flashes fu5 and locks all other functions up any ideas?
Irritrol error 5en
5en is actually Sen; it's indicating that there is an open weather sensor or if no sensor, make sure that the sensor switch is set to bypass
Jul 21, 2014 | Irritrol Systems Irritrol RD-900-INT
Irritrol rd 900 lcd flashes 5en and system will not water.it fails in manual,semi,and programmed
There was a bad batch of capacitors that came out of China a few years back. All of them eventually blew and caused many different electronic devices to fail. The capacitor is a round can on the electronic board. If the dome is rounded, it is bad. If they are all perfectly flat, they are OK. Check all the capacitors. Since the power pack is 24vac, the RD900 will certainly have at least one capacitor on the board. If bad, it can be unsoldered and replaced.
Jun 02, 2014 | Computers & Internet
How can I set the timer for a seven sector Dewbee by Irritrol?
The same manual for Irritrol's early MC Series may be used. I no longer have any Dewbee or MC Manuals but I do have written instructions available that should help. Let me know if still needed.
May 14, 2014 | Kitchen Appliances - Others
Charged my RD 600 system and water comes out of all 5 stations
Make sure the bleeders are closed. Sounds like all the valves are open and all are running at the same time.
Apr 11, 2014 | Irritrol RD600-INT-R Rain Dial 6 Station...
Irritrol rd 900
IT'S NOT THE TIMER: The hydraulics in the valve are stuck. Best solution is to purchases same valve and replace all the internal parts with the ones from the new valve.
May 15, 2013 | Irritrol RD900-EXT-R Rain Dial 9 Station...
I have an Irritrol Irrigation system (RainDial PLUS)
With the water turned on you may be able to hear or feel the water running through the bad valve. If not, you can turn each one on and off by hand by either turning the solenoid or the bleeder valve figure out which one it's not. Once you find the culprit you can see if it needs a new solenoid or open it up to clear out any sediment or debris that's keeping it from closing.
Apr 07, 2010 | Plumbing
Irritrol 6 Station Rain Dial RD600-EXT Outdoor Logo
110 people viewed this question
Top Irritrol Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Irritrol Measuring Tool and Sensor Expert? Answer questions, earn points and help others
