Question about Optics
I would like to see an change in the weapons ,area,so you could exchange no longer needed weapons for upgrades, or actual newer weapons and or features for them!
  • 2,121 Answers
5here are plenty of hos sites already
Posted on Apr 19, 2015
I have a Danby dehumidifier model DDR6011R and it runs but I have yet to empty any water from it. I have used other dehumidifiers in the same area and they take out tons of water. What's the problem
1st ck your humidistat settings yes the fan can run but not the compressor to take water out
2nd ck your filters could they be blocked ?
and last but not least if the unit is more than a few years old its not as efficient as newer units and will take much longer to work consider an upgrade to a newer unit , also moisture levels in basements vary due to season , winter not as damp as summer so volume of water removed will change
use an external humidy gauge to verify it working correctly there not so expensive now and can be gotten most places that sell dehumidifyers 70 % rh is considered normal
Oct 18, 2014 | Dehumidifiers
Tamper on verifone 8020
You need a new terminal. I Highly reccomend an upgrade to something that meets current standards. The 8020 is in an end of life status. They are no longer manufactured and do not meet EMV nor PCI 3.0 requirements.
Mar 08, 2014 | Lands Phones
Hi, NEC P221 W multisync has increasinly been displaying fine vertical cyan and magenta lines, most evident on white areas and grey areas respectively.
Your monitor is no longer in production but there might be some support for it. Go here to see what's available: Product Support You might need to upgrade.
Jul 28, 2017 | NEC MultiSync FE950 (White) 19" CRT...
8ta 2gb sim package giving limited service error with zte mf820 lte usb modem. Same sim works on 3g in BB9810 mobile phone in same area. same in different telkom mobile areas. Modem works on 3g with Mtn...
You may need to upgrade to a newer sim card. There have been changes recently, esp. with the broader adoption of, and newer versions of LTE. LTE is a whole different radio system than 3g or even 4g. (It is actually 3g on super steroids) I think a sim upgrade should fix the problem.
Aug 11, 2013 | Lantronix LMR 8TA (LMR8TA-02) Networking...
I have a uniden scanner they changed the codes in centre al where can i get the codes for free
If everything was working fine, and then all the activity "disappeared," your area probably upgraded and migrated to a trunked radio system. If that's the case, your BC120XLT can no longer follow the activity, and you'll need to upgrade your scanner to stay in touch with the action.
To verify the systems in use, and for a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Nov 04, 2009 | Uniden BC120XLT Handheld Scanner
Where to go'where we can upgrade our weapons
Your weapons upgrade the more times you use them. There is a level bar for each weapon.Once filled you get the next level of that weapon.
May 12, 2009 | Sony Ratchet and Clank 3
GE refrigerator 12 years old runs continuously, exterior warm
Probably not. Newer (and I mean under 15 years old or so) refrigerators may run more % of the time than older units, but are using far less energy while running, so total energy consumption is actually less. The newest energy star models often use less electricity than a single incandescent light bulb uses if left on 24/7. If your run times are noticeably longer just recently, and there have been no other significant changes to account for it (like more and / or longer door openings or a warmer ambient temp., etc.) then you may have caught a defrost problem or bad door gasket problem early. The warm temp on the outer case near the freezer is to prevent condensation from forming in those areas, and is normal. (as a matter of fact, older refrigs often used low wattage electric heaters for that task, almost all newer units use waste heat from the cooling system to accomplish that task) Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Feb 16, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Goes through hotsynch process, but nothing happens
Install newer version of palm desktop and create new profile.
Sep 11, 2005 | Palm m125 Handheld
Optics Logo
170 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
