Question about Hobart Dishwashers
Hobart chh50 pass through dishwasher. heats tank to correct temps but red ready light keeps flashing. fill pump seems to keep running. no error codes displayed.
Chh 50 2008 model. heats ok but red ready light keeps flashing. boils tank and dumps to rinse tank but fill pump seems to keep running. really need some urgent help with this guys :-
    Master:
  • 301 Answers
I found this website that can help you further.
Hobart Kitchen Appliance Product Support ManualsOnline com
Posted on Apr 09, 2015
Testimonial: "thanks steve"
Tip
What to do to get your Whirlpool dishwasher to start when the light keeps...
<span>Hello,<br /><br />To reset the dishwasher push in this order the,<br /><br />HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF<br /><br />the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??<br /><br />example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4<br />7 flashes then pause then 7 flashes its displaying the error code#7 ect ect<br /><br /><br /><br />GENE</span>
on Sep 06, 2011 | Dishwashers
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
Unit has been flashing F1 and now doesn't seem to complete the cycle. Just keeps running.
The F1 error codes is a water heat fault,the control has determined that within 60 minutes that the correct water temp.has not been reached
The possible causes of that are
A burnt out heat element
A burnt out thermostat
Gene
Aug 22, 2011 | Asko 24 in. 1895 Built-in Dishwasher
My dishwasher clean light keeps flashing and wont run. it flashes 7 times and pauses then repeats. whats the issue?
This is an error code.
The error indicates that your dishwasher is failing to heat the water in an allotted time. The error can be caused by numerous issues but the first thing you want to do is reset the control board.
-To reset the control board press: high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash. If you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
-All the lights will go solid at which point you press cancel to reset the board.
-If the control board doesn't reset, it's likely that you've just got a faulty control board and the control board will need to be ordered and replaced.
The next step in this process is to start a new cycle and see what happens. If the error code returns, then you'll want to reset the board again and check several things. The most common reasons for this error is because the water coming from your household is just too cold. The dishwasher is expecting 110 degree water to enter your dishwasher, so if your pipes are cold, the water may only come in luke warm. To correct this issue, just run your faucet next to the dishwasher until the water coming out is hot. On another note, make sure the dishwasher is washing with good water pressure. You can put a cup in the upper rack facing upwards and run a cycle to see if it will fill within 10 minutes of starting the cycle. If it doesn't fill with water then you know that the dishwasher isn't producing enough pressure which, in turn, will cause the water to not heat. You'd want to take your pump and motor assembly apart to clean inside if you had a loss of pressure.
You could also have a failed component including a faulty heater, control board, or high limit thermostat. You'd need to uninstall your dishwasher, disconnect power and lay it on it's back to check the resistance of the heater as well as the resistance of the high limit thermostat to confirm if they were bad or good. You should get tangible reading of between 5 and 30 ohms on the heater if it's good and less than one ohm on the high limit thermostat. If both of those devices check good, then replace the control board because that's the one device you cannot test.
Jul 05, 2011 | Maytag Dishwashers
The dishwasher will not run. The Clean light keeps flashing with 7 light intervals. When you press Cancel/Drain, the timer has 2 minutes and runs for 2 minutes. Not sure if it is drain since there is...
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Mar 19, 2011 | Whirlpool 24 in. GU2500 XTP Built-in...
We can't get it to cycle.... the green light next to 'clean' is flashing on the panel - can't get it to stop flashing and run??
Found it; High temp scrub--Energy saver dry---High temp scrub---Energy saver dry--press start, close door ,wait for it to reset,open door press cancel and you are ready to go.
Jul 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Hobart dish machine low wash temp
make sure all the curtains are there ,also check for any baffles missing from mach. should be 2 1 on incoming side 1 on outgoing, also ck hood vents had problem before with vents wide open sucking heat right out of warewasher
Jan 09, 2010 | Dishwashers
Hobart amx/aux-s dishwasher "bof" error code
press the 1st and third buttons on the display nxt to the start button then press the start button,this will change the the display to something like BOF1 then allow the achine to fill the rinse tank you will know when this has happened as the display will go out (all of it) then you can turn on the machine using the button marked with a I the start button will light red allow it to go green and you are ready to go ... if when you are boffing it it changes to FIL the your water pressure is to low good luc fella
Mar 13, 2008 | Dishwashers
Dishwashers Logo
179 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
