Question about Mitsubishi Heating & Cooling
Thermistor for Mr. slim Mitsubishi circuit board
    Master:
  • 301 Answers
  • 6 Answers
SOURCE: no heating from Mr slim
P8 refers to outdoor protection device activation usually caused by low gas charge or blocked condenser coil. any good a/c company can resolve this for you. however please note that if it is gas related a pressure test must be carried out to determine where that potential leak may be and that can be very costly.
regards
Ed
Posted on Nov 14, 2007
22yooper
  • 828 Answers
SOURCE: Mitsubishi Mr. Slim M/N MSH15EN
Try calling G A Larson's for technical advice. I think that they handle this product. 499-0866
Posted on May 22, 2008
  • 958 Answers
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
  • 27 Answers
SOURCE: Mitsubishi Mr Slim air conditioner
get model and serial #s and look up unit for diagnostic codes
Posted on Nov 26, 2008
SOURCE: Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
Posted on May 02, 2009
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
P8 showing on air cond and air con is not working
P8-Abnormality in outdoor unit.
Solution:
1) Check the indoor/outdoor connecting wire in proper point.
2) Change the connection of electric wiring, if reversed phase.
3) Check the protection device, if malfunction, replace it.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Thanks.
Feb 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
We have a P8? CAN'T FIND MANAUL
1.Wrong wiring of indoor/outdoor
connecting wire.......................Check the indoor/outdoor connecting wire.
2) Reversed phase......Change the connection of electric wiring.
3) Protection device is working........ Check the protection device.(LP,HP)
4) Damaged outdoor coil thermistor.....Measure the resistance of the outdoor coil thermistor.If the resistance is normal, replace the outdoor controller board.
5) Check out door coil is cleaned. If not do it.
thanks.
Jan 30, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Mitsubishi electric Mr Slimair conditioning. It runs a few minutes in cool mode, then it stops and an error of P8 code appears. When it runs, the fan is not strong.
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
Hope,it's helpful.
Jan 15, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Its not working and flashing P6. Its a Mr Slim
dear sir/madam i think.... mr Slim A control R407c & R410a systems.
P6 = indoor coil frost protection in cooling or indoor coil overheat protection in heating.
Cooling
One of the 2 indoor coil sensors reads minus 15 deg C for 3 mins.
Heating
One of the indoor coil sensors reads over 70 deg C.
If you are sure the refrigerant charge is correct & system operation is correct then it could be a coil temperature sensor reading wrong temperature.
If you have one of those little monitor things which plug into the outdoor circuit board you can monitor the indoor coil temperature.
On later type remote controllers you can get all operating data like temp sensor data but you will need a service manual to do this.
Or you can measure the ohms resistance of the temp sensors & compare with the chart in the service manual. if you can do it by yourself do if not then contatct ot mitsubishi maintenance personnnel for furhter action, thank you hope answer the question please vote!
Sep 23, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
We have a Mitsubishi Mr Slim air conditioning unit, i've checked the circuit breaker, the remote works but the unit will not engage.
DOES IT DO ANYTHING I THINK ON THE RIGHT SIDE IF YOU HAVE YOU BOOK IT FLASHES ERROR CODES IF YOU HAVE THE COVER OFF
Sep 18, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
MMy Mitsubishi Mr. Slim Air conditioner is
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
May 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Model number
Visit Mr. Slims website at www.mrslim.com. There you will find a tab for Customer Service. Look in Library to find your model and technical manual. You may have to look at a few to find out what you have for an inside unit, probably it is a PUG.
Oct 15, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Indoor unit comes on for 5 seconds and then shuts down
"Off" the circuit breaker and then "on" again then start the unit .
Oct 08, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
135 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
