Question about Sharp AR-M455N Copier
Problem with sharp ar168d
i have a sharp ar 168d, i just bough this printer, and the toner, it scans, but when i try to print it comes out blank pages, its the same when printing from the pc or making a copy.
My copier copies very dark no matter where you put the exposure, what do we need to do to correct this problem?
Posted on Aug 25, 2008
  • 33 Answers
If you do not have developer in the machine it will not print. let me know if you have it or not.
Posted on Nov 18, 2007
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
Printer ar168D Error L1-00
The L1-00\r\n error indicates the scanner didn't return to it's home position or is locked and can't leave the home position. There is a lock switch (designed to lock scanner into place for safe transport) located to the left of the copier and just under the scanner. It's a plastic dial that needs to be turned to the "unlock" position. Once done, your problem should be fixed.
Nov 12, 2009 | Sharp AR-168D Copier
Sharp AR168D not printing
Look above the shelf where copies come out. If you see a disk about 1.5 to 2" across , it may have been bumped into the "locked" position.
Either turn it 90 degrees or take it out & throw it away.
Oct 02, 2009 | Sharp AR-168D Copier
My SHARP AR-168D is not recognizing a new toner cartridge.
Make sure what you've got is Sharp's AR168NT and not AR152NT. Sharp mades changes about a year ago to their toner and the chip on an AR152NT will not work with an AR-168D model.
Aug 18, 2009 | Sharp AR-168D Black and White Copier
Sharp AR-168D will not print
you should change your printer data cable or fix correctly with printer port.
Jul 30, 2009 | Sharp AR-168D Copier
H4-00 error on Sharp AR-168D
the code needs to be reset even if you replace the fuser.
Press clear, press *, press #, press * your display should go blank press 14 then press print,
I'm doing this from long term memory I may have the # and * symbols swapped
Apr 09, 2009 | Sharp AR-168D Black and White Copier
Sharp 168D printer, scanner
Try downloading new drivers for your computer
using this link
You can get the correct drivers by using AR-168D
Jul 21, 2008 | Sharp AL-1642CS Copier
SHARP 168D - Won't print from RDP session
Does the printer print directly without an RDP session?
Jun 25, 2008 | Sharp AR-168D Copier
Sharp AR 168D will not print from PC
Try disabling the print queue. In windows 2000 go to printers, then properties of the canon printer, advanced and select "Print directly on the printer".
Also try printing from another computer and replacing the interface cables.
May 05, 2008 | Sharp AR-168D Copier
Sharp AR-M455N Copier Logo
136 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
