Question about Ricoh Aficio 2018D All-In-One Laser Printer
Just after fuser unit, gears
Check the foto and tell me parts numbers of these two gears.there are in section just after fusing unit.don`t know which unit is or how is named. also one of these , is double sided as showing.
    Top Expert:
  • Ricoh Master
  • 51,186 Answers
What photo check your post it isn't there
Posted on Apr 09, 2015
Testimonial: "opp sorry.... doesn`t loaded"
  • admin
    admin Apr 12, 2015
    photo loaded,can help?
    Master:
  • 346 Answers
Go to company website and click on product support.
Pring blank pages
Step 1:
Good day...
Before we start first make sure the machine is turn-off for our safety process.
Question: 1. Did you try to change the other toner cartridge?
Step 2:
Possible cause and way to check Toner Change Problem & No more Printing:
- Dirty Sensor (check all the sensor)
- Dirty Glass (check all the glass)
- The cartridge is not properly installed
- Full Waste Toner section
- The corona wire is dirty or broken (Inside the cartridge)
- The transfer Unit is dirty or broken (Inside the cartridge)
- Broken gear motor connected into the drum section
- If they have developer include in this model try to check it and
repalce if empty
- Broken Fuser Film
- Broken Fuser Lamp
- Broken or dirty Cleaning Blade Section
- Check if they have also chips include in the cartridge
Step 3:
Check all the possible cause and try to clean or replace the parts if broken.
Let us know if the problem is solve.
Sorry for my english
Feb 19, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
I have a Konica Minolta C650 Bizhub. It required me to replace the fusing unit. I did. However, the machine does not recognize the new fuser. It still gives the "replace fusing unit soon"...
There is a fuse in a new fuser unit that resets the internal electronic counter. There is no other way to reset the counter. You either need to return the fuser unit to where you got it and request another one or have someone replace the fuse that is inside the new fuser unit you bought. My suspicion is that the unit either is NOT new and maybe someone scammed you or that the unit is a rebuilt unit that someone forgot to replace the fuse in. I stock the fuses so they are readily available from numerous sources. I can provide you with those if needed. Basically you remove the fuser and then remove a cover that is around the large connector on the fuser. Then hidden inside the wiring bundle you look for a plastic zip tie that is holding the fuse. The fuse is encased in a section of clear shrink tubing. You must cut this fuse out and replace with a new one.
Hope this helps.
Dec 27, 2011 | Office Equipment & Supplies
Hi, I have a C6500 Bizhub pro, but, recently displays an C3102 error. I need to print an urgent job and y can't! Please helpme!
The fuser exit rollers are the light grey painted rollers on the exit of the fuser itself. There is a slider mechanism that when slid forward or towards the rear, will adjust the pinch of the roller. Primarily it is there to deal with what is called a waxing effect where the rollers physically leave an impression in the soft toner on thick stocks. Reducing the pinch for thick stock reduces this. However, when doing thin stock, especially letter size paper, jamming can occur if the pinch is not engaged since there is no physical contact to drive the paper to the next conveyance rollers when doing duplex or face down printing.
The slider can be found on the left side door of the fusing unit itself, near the front. Normal operation is in the middle.
Replacing the CDB is just one of many troubleshooting steps, it is not the end all to this.
The 3102 code you encountered has nothing to do with temperature and humidity. It is a code related to the failure of the fuser conveyance. Gamma correction is also unrelated because gamma correction is image related, not conveyance related.
I highly suspect that you are encountering this code because of some kind of failure related to the fusing unit itself, again related to the movement of the fuser, which usually is in motion during many test modes of the main body components. Check all the connectors to ensure they are seated properly. The previous document relates to what to check and replace related specifically to fuser pressure roller.
We do not leave fusers at the customers either. We have spares at the shop that we rebuild during slow periods. This is simply our own initiative, not the norm, and is also a part of our troubleshooting regarding fusing unit related errors that are not so obvious...it is part of the elimination process, as some fuser related codes can be caused in other areas, such as the CDB, a bad conveyance clutch or motor or simply timing adjustments that are out of the normal range.
PROBABLE CAUSES:
1.One of the gears in the fusing unit gearboxfails. The shaft for fusing unit gear/H has been changed so that it is now supported at both ends instead of just
one end. The gear is now made of a stronger material.
The new design has been incorporated into all bizhub PRO C6500 machines beginning with s/n A03U0000787. A replacement gearbox is available for
machines with lower serial numbers. For the machines with serial numbers between A03U010000788 and A03U010001446 the fuser gearbox is already
updated and only fusing gear /H (p/n A03U808811) needs to be replaced.
Note :See attached Bulletin Number5923.This only applies to bizhub PRO C6500. All other models have the new style. To viewthe PDF, Adobe Reader®
must be installed. Adobe Reader® can be downloaded for free from the Adobe® web site at: Adobe - Adobe Reader download - All versions .
2. The machine cannot determine the separation cam home position.
Check the following items PS16 (p/n 08AA 8551 2) and Release Actuator flag (p/n A03U 7244 00). Make sure when the fuser jam release green knob is
turned counterclockwise, the Release Actuator flag (p/n A03U 7244 00) blocks and unblocks PS16/PS17. Check to see if the sensor is disconnected. If
turning the Fuser Jam removal Knob does not change the position of the Release Actuator flag, then check the drive gears associated withM30 (p/n 27LA
8003 0) for broken or stripped drive gears andreplace them if damaged.
3. A one-way gear (p/n A03U 8093 00) is slipping in the fixing drive assembly.
Replace the (3) fixing drive gears with the modifiedFixing Drive Gear/M 22T (p/n A03U 8093 11) andthe fixing drive shaft/A (p/n A03U725800).
Please refer to the attached Parts Modification Notices for details. To view a PDF, Adobe Reader® must be installed. Adobe Reader® can be downloaded for
4. Failed fixing limiter.
Replace fixing limiter (p/n 65AA53651).
5. Failed ICP14 on Conveyance Drive Board
Replace Conveyance Drive Board (p/n A03U H050 04).
Apr 27, 2011 | Office Equipment & Supplies
When printing making loud noise
fuser gears. replace the fuser. part number rm1-3740-030cn
Nov 16, 2009 | HP LaserJet P3005n Printer
HP P3005 making grinding noises
this is a problem that HP refuses to acknowledges. Its caused by the gear that meshes with the main fuser gear..it wanders to the right as the printer prints. we are checking into a fix for this, since we are getting no cooperation for the manufacturer, Canon or HP. Canon makes the print engine
Apr 01, 2009 | HP Hewlett Packard LaserJet P3005 Printer
Canon IR5000 not running 20 lb. will run 60lb. and cover. 20 gets stuck in middle
If it's getting stuck in the Middle , I am assuming it's getting stuck right a the fusing section, Ok if it is running 60 lbs of paper greatly but, jams in the Middle , this tells me your fuser needs to be adjusted, This is something you don't want to do if your NOT a Service Technician most likely if your fuser was adjusted for 60lb paper the temperture was also adjusted so the paper won't be too too hot, I am certain your fusing unit will need to be adjusted or the Upper fuser/Lower Fusers are worn. Yea, you'll have to call a indiepent or an authorized dealer for this, unless you know how to rebuild the fuser yourself- be careful- this is exteremely hot unit.
Mar 04, 2009 | Canon imageRUNNER 5000 Copier
Lexmark C720 grinding noise & fuser damage
From the site of your Picture, you need a new fuser unit.
The coasting is peeling off... that is not good. And I will bet you get allot of paper jams.
To replace the fusing unit is not hard to do. For the most part taking the covers off the machine and getting them back on is the hard part... Let the fuser unit cool down before you touch it..
Just remember to unplug the machine, Electronic Static Discharge is not good for the Boards in it, touch the metal chassis before you touch the boards if you don’t have a wrist strap) get your self a table and some room to work and take your time.
Take the toner cartridges out
I would do a maintenance kit while I had it apart. (rollers, transfer rollers etc)
Vacuum it out; clean it while you have it open.
(Warning toner and developer is very fine, you might need a vacuum with a micro filter on it, other wise it might go every where)
The service Manual has details on how to do all this. If you follow that you should be ok.
You could try to get all the parts to Fix the fuser unit, but it is easier and faster, cheaper to replace the whole thing. Some places offer a core exchange.
If you need any assistance let me know...
This is from Lexmark
http://www.lexmark.com/lexmark/product/home/605/0,6970,204816596_846034106_306769501_en,00.html?tabId=1
These are various other places that offer parts and supplies.
http://www.innovone.com/~tsa/
http://www.all-laser.com
http://www.p2gcentral.com
http://www.precisionroller.com
Oct 27, 2008 | Lexmark C720 Laser Printer
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Gear making a grinding noise
Not too good news I'm afraid. It sound like the fuser gear has failed. Generally the fuser unit (hot section or hot rollers in the back) need to be replaced. Usually when the gear has worn or failed the fuser rollers are also worn and need to be replaced. The gear can be replaced seperately but is a very risky operation and usually results in parts in the fuser unit falling appart due to age and wear, so it is best done as a unit. If possible do not run the machine as it can cause damage to gears around the fuser unit. The best option is to find out how much a fuser unit and labour to fit would be at your local service centre.
Jan 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Gear that drives the fuser unit
Yes one can replace it but it aint no easy job, entire frame needs to come apart, I always change the whole L frame, but gear is available, set aside half a day, take pics or purchase the service manual, it still takes me 40 mins to change a frame on one of these, and you will need to go that far then some to get to just the gear in frame..
7deadab.jpg Link to part number/price/purchase of fuser drive gear
Not such a easy job, you have been warned from one who knows OK
Good luck
Jan 09, 2008 | Brother MFC-8840D All-In-One Laser Printer
Ricoh Aficio 2018D All-In-One Laser Printer Logo
83 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
