Question about Roper Refrigerators
Makes a clicking sound about every 12 mins but is cooling okay and sounds normal
  • Bob L Aug 07, 2015
    Sounds to me like the start device (relay/overload) Easy to change . the relay is attached to the side of your compressor
  • Roper Master
  • 5,323 Answers
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Posted on Apr 09, 2015
TSSU4812 refregirator making clicking sound and not cooling
Without a compressor analizer you will need to check the winding
resistance. or you can just cross your fingers and hope the relay
and start capacitor are the problem. Sounds like the condenser coil was plugged so you could possibly have a locked up compresor.I doubt it is low on refrigerant charge.
Jan 15, 2013 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
I have a 02 passat when I start If up it sound like a truck. What do you think it can be. Its not turbo it just started doing it
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make loud truck noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
My 2004 t&c 3.8 is making a weird sound like a
There is N-number of possibilities for the car to make wierd noise or any other kind of noise.
These will help.
Thanks.
Thud in trunk at take off
There is N-number of possibilities for the car to make thud noise or any other kind of noise.
These will help.
Thanks.
Nov 28, 2012 | 2010 Toyota Camry
Chevrolet k1500 whining noise
Its actually from where the noise is coming from.Front end or rear end.From engine area or from inside from steering or from breaks.
There are N-number of possibilities for the car to make whining noise or any other kind of noise.
For step by step troubleshooting these problem,i suggest you to refer the help links mentioned below.Its a complete solution with proper explanation to identify the cause of problem:------
Click the link below:-----
These will help.
Thanks.
Nov 28, 2012 | Chevrolet Silverado 1500 Cars & Trucks
Machine selects a program fills up with water then does nothing, but still makes usual clicking noises. If drain is selected machine indicates 12 mins as normal starts to drain then shows 1 min and does...
This sounds like a bad main control board. Try unplugging it for 10 minutes then replug an try again. If you get the same results replace the main controller.
Jun 16, 2010 | Bosch Exxcel WFX 3267 Front Load Washer
The refridg. makes a clicking sound is not cool and smells foul.
No the freon is okay. There is a relay on the compressor that is called PTC relay. That is what the problem is. Unplug the unit and remove the relay from compressor terminals and replace. Should cost 25 bucks. Them little guys are expensive. Let me know how it goes. And don't forget to rate this advice. ken
Dec 31, 2008 | Whirlpool GD2SHGX Refrigerator
Frig. and Freezer not cooling. Clicking sounds heard every 2 mins
sure sounds as if it is def a compressor overheating, now that the compressoe will be cooled it should work , but your right damage may be already done, the good news if any is that you should be covered under 5yr manufactures warr for compressor
Dec 22, 2008 | Maytag MTF2155GRW Top Freezer Refrigerator
Washer make clicking sound
First locate were the sound is coming from. put your ear very close to the timer and listen for this clicking sound. remember a timer will make a clicking noise which makes the timer go around. Timers can get noisey with age. The sound might be coming from below also .I would run your washing machine until the part fails. They might also have a motor controller in this unit which is seperate to the timer which will make a high pitch clicking noise.
Aug 18, 2007 | GE WHRE5260E Top Load Washer
Refrigerators Logo
67 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
