Question about Kitchen Appliances - Others
Has a red temp rest button and is in out position dont know if is supposed to be that way
  • 899 Answers
If the button is out, it means that it has "tripped off" This would normally be because the unit has got too hot. Press it back in and the fryer should work normally again.
Posted on Apr 09, 2015
Red light blinking ice in maker and dont found pushtab on the left and the red light stop flashing
Which model do you have? Sounds like you have a optic issue but need more information. Also please include the position of the harvest fingers within the Ice maker. Need to know if they are resting in like 2 o'clock position. Thanks
Apr 18, 2016 | Maytag 22.7 Cu. Ft. Side-by-Side...
Tire reset dont reset
Turn the key to the "on" position, but do not start the engine. Access the low tire reset button by opening the passenger door removing the fuse panel cover located on the passenger side of the dashboard. Press and hold the red "reset" button until the light begins to flash and goes out. Release the button. Replace the fuse panel cover and you should be good to go. If that doesn't solve it and your tire pressures are all correct, then it's electrical. That light is only supposed to come on when one tire reads 12psi lower than the other three.
Jan 21, 2013 | 2001 Buick Regal
I have a 1992 mercedes 200 E WDB 021 Saloon, it has 8 button air condition and I dont know how to use it. Control wheel on blue position but When I push the button (leftmost)which has a glass figure on it,...
The pulley on the air condition has to turn it has a belt on it. The Compressor engages to pre cool the evaporator. Most likely you have a blend door pod leak or leak in the hose or the sampler valve is bad. I would replace the sampling valve behind the glove box/air bag. As that reads the cabin temp and if it thinks the car is cold the heat will stay on because everything is automatic. All vents will blow cold when it thinks its hot and in addition to floor and corner dash center vents will blow cold when it works. If the direction of air is correct then the A/C system may have a leak or need a charge of freon.
May 05, 2010 | 1992 Mercedes-Benz E-Class
My A/C is not blowing hard
That high pressure rest button is most likely it(A breaker from the wind/mess), try resetting it.
Aug 11, 2009 | Ruud UAKA037 Air Conditioner
I HAVE A SLIM PS2 RED LIGHT COMES ON SHOWING HAS POWER BUT RESET BUTTON WONT TURN GREEN when I push the power button.
well first of all your only supposed to press it. dont hold down. i dont really know why, but i suppose if anything something having to do with the power cord. proud to be part of your help
-brandon
Mar 30, 2009 | Sony PlayStation 2 (PS2) Console
Cozy Wall Heaters
On the gas valve, look for a marking that indicates "Pilot". If there is no such marking, you do not have a pilot and the system is electronic ignition. Ok so if you find the pilot position, you will be able to turn a know to that position and depress the knob into the gas valve. At the same time you are depressing the knob, look for a red button that snaps when you depress it. This is a Pizo starter. If you do not have this button, look for a viewing port where you can insert a long match. Once you have the knob depressed and the viewing port open if needed) you should be able to light the pilot with the snapper or match. Before you release the knob on the gas valve, sing "Yankee Doodle". This will give the flame enough time to heat up a probe to the proper temperature and the flame should stay on. Button up any port you opened and then turn the gas valve knob to the "On" position.
Nov 21, 2008 | Heating & Cooling
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
Orange light
The orange light is for you to know that the plastation2 is working unless it is not reading the disk then you etheir take it back or tip it over on its side then let it do the rest or if that dont work then it either broke or if you get it to work then you are alright at games.................. thats all the info i have on that........ there you go.
Jan 24, 2008 | Sony PlayStation 2 Slimline Console
Not reaching temp
On the machine that we have, there are two [2]push button switches in line for the heater tank. One is on the front of the tank and the other is around the right side. I have always called them clicks-on's but.. they are red in color and need to be rested if ever they get to hot. Be sure to relise that they did infact pop for some resone. Did the tank for some resone run dry?
Apr 19, 2007 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Kitchen Appliances - Others Logo
144 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
