Question about Miscellaneous
I have a 1999Gp1200 waverunner and I am wondering if water shouldbe coming out of the portside cooling or "pe" hole when I have the water hose hooked up to it while it's running as I'm flushing it out
    Top Expert:
  • Miscellaneous Master
  • 47,630 Answers
Of course the weep hole should shot water out that is the indicator it's working
Posted on Apr 09, 2015
dennymulford
  • 1055 Answers
SOURCE: Lower radiator hose leak at water pump housing
water pump housing is cracked ,replace the water pump
Posted on Apr 11, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: over heating
Have you changed the thermostat? The way you describe it seem like a thermostat.
Posted on Jun 30, 2009
  • 1779 Answers
SOURCE: it has rusty water coming through the hoses and
Did you have the radiator removed from the vehicle, then flushed, or was it done w/out removing it? If it was done w/out removing it, it was not flushed properly or thoroughly. Regardless of being flushed in or out of the vehicle, the engine block has a drain plug that should be removed, and it too should be flushed. If you had it flushed properly, and the correct amount and mix of coolant replaced, you should be able to drive for at least a couple of years before a coolant change would be needed again, and longer than that before you would see rust in the system. Whoever did the work did a #$(* job. They should provide another complete flush and new coolant for no additional charge, as you already paid for it, and that is not what you got. Once properly flushed to remove all rust and sediment, you should not have any overheating problem. Also note that a plugged up heater core can cause no heat in the passenger compartment.
Posted on Dec 08, 2009
  • 111 Answers
SOURCE: no heat , replaced radiator , water pump, rad. cap
it may be either the electric heater box(in the dash), or a a bad heater core. have you looked into these? the cooling system won't usually cause you to not have heat. in some cars there is an assembly inside the dash that actually helps heat the air in some cars and just redirects the air through the vents, panel, or the floor in others most cars use a heater core as part of the cooling system, after the water leaves the engine hot it travels through the heater core on its way to to the radiator to be cooled the hot water in the heater core heats the air that is pulled into the cabin allowing the vents to blow warm air. this is why the car will not blow warm air until the water in the engine has had time to warm up on a cold start.i hope this helps.
Posted on Jan 10, 2011
clifford224
  • 1975 Answers
SOURCE: need help finding inlet heater hose from fire wall to engine
The inlet going TO the heater core should be the top one (I think) but in any case it would be the one with the heater control valve on it (see picture below) Hope this is what you were looking for....
Posted on Mar 05, 2012
Why does yamaha waverunner fx cruiser ho not run in lake but will run hooked to water hose
Sounds like you have a bad stator. It may be producing enough spark to start the motor, but under a load (as in the water) it simply can not supply the amount of spark needed. Sometimes when a stator is tested on a ohms meter it may test good, but still be defective do to the load it will come in contact with when put in the water.
Jun 29, 2014 | Yamaha 12V Air Pump
Water is not coming out my exhaust
reverse flush it were the water should come out put the hose in there.
Nov 06, 2013 | Yamaha Waverunner Xl 700 Xl 760 Xl 1200...
I have a 2009 Yamaha VX Cruiser waverunner there is a very strong gasoline odor when I lift the seat to check the oil or do other maintenance I'm wondering if this is normal, I bought it used it only has...
check all fuel lines are in good condition , check fuel tank pipes etc ! run on a hose ( start engine first ) and look round for leaks ! water off then stop engine ! P...
Oct 28, 2013 | Yamaha 2009 WaveRunner VX Cruiser
I bought a 97 gp 1200 waverunner and the first few times i took it out it ran great, i changed the spark plugs because it wasn't opening completly up at wide open throttle. I put it the water and it...
THE BEST WAY TO CLEAN OUT YOUR INGINE AND HOSES IS TO HOOK UP THE FLUSH HOSE TO THE SIDE OF THE WATERCRAFT ,,,,IF YOU DONT HAVE THE ADAPTER CONECTION HOSE YOU WILL NEED TO GET ONE ITS A VERRY IMPORTENT PART OF MANTENACE ,,,,YOU NEED TO FLUSH IT OUT EVERY TIME YOU TAKE IT OUT OF THE WATER TO KEEP ALL THE SAND FROM BUILDING UP IN YOUR COOLING SYSTEM,, AND TO GET ALL SALTWATER OUT THE SALTWATER WILL EAT AWAY THE HEAD LITTLE BY LITTLE,,PLEASE NOTE SOME MODELS HAVE A HOOKUP IN THE VERRY BACK WHERE YOU CAN HOOK A REGALAR WATER HOSE TO,,,HOPE THIS HELPS.
Jul 19, 2011 | Yamaha Alp 40 Motorcycles
91 waverunner overheats. it runs fine for about a minute then wont accelerate. When i remove the heat sensor it will accelerate but not as smooth as when it first starts.
THIS IS BAD ,,,THE HEAT SENCER IS THERE TO KEEP THE INGINE FROM BLOWING UP ,,,I RECEMEND THAT YOU CHECK THE WATER OUTLET PORTS TO MAKE SURE THERE CLEAR ,,,HOOK UP YOUR FLUSH HOSE AND FLUSH OUT YOUR COOLING SYSTEM ,,,IT COULD BE BLOCKED SOMEWHERE ,,,,MAKE SURE THAT WATER COMES OUT OF YOUR FLUSH PORTS AND THAT WATER IS COOL TO THE TOUCH,,,HOPE THIS HELPS..
May 16, 2011 | Boating
On a early eighties model 15hp suzuki 2 stroke how do you know if the water pump is working?
Hi!
The easiest visual test to see if your motor is pumping cooling water is that the water will come out the "check hole" just below the engine bonnet.
However. it's possible that the check hole has become clogged with debris. A piece of thin wire or even a toothpick should be enough to get the debris loosened so water will flow.
You can buy "ear muffs" at any chandlery to hook your motor up to a garden hose for your test.
WARNING!
If steam is coming out of the hole, SHUT THE MOTOR DOWN IMMEDIATELY! You'll overheat the motor and cause a very spendy repair job.
Good Luck
Mar 15, 2011 | Suzuki Boating
Improper hose conection water coming out exhaust.
If your shure that a hose is on wrong then there is a place it goesonto that is also wrong . Two wromgs. The only place that a hse could be on wrong is at the exhaust asperater tube that hooks the EGR vavle to the exaust manifold. The heater hoses hook next to each other behind the engine going though the firewall. Follow these hoses back to the motor and see that they don't connect to the pipe on the lower left side of the exaust manifold. If its doing that remove it and see if you can find another hose the same size that will reach the exhaust tube and connect it and vise versa connect the other hose there. The Hoses can be alright though and the engine has a bigger problem a blown head gasket or cracked head. On some models the catalist converter has a hose hooked to it remove it and see itf water comes out, if shouldn't but if it does follow it back to the engine and unhook it there. If water ( Coolant comes out ) ( You may Have to add coolant not water to the cooling system to tell ) then this connection should be connected to a heater hose that you found going thogh the firwall. If you still dont find the problem and the cooling system holds presure and the water coming out the tailpipe is coolant and the engine runs OK ( I dought it). All engines produce a little water when running mainly when run shortly and not warmed up, it will appear black in color and not smell like antifreze. A prankster could have put the garden hose or man hose up the tailpipe to worry you some suspect those that helped point out the water in the first place. The exhaust hoses hook up to the air cleaner housing and pipe and the water hoses hook to the firewall a pipe on the back of the block and a short pipe hooked to the water pump. Repair manuels have pictures of the hoeses in the cooling system chapters.
Aug 10, 2009 | 2000 Ford Focus
My car is over heating when i shut it off the coolant resivoir is boiling and brown in color
It sounds like a faulty thermostat. Follow the main radiator hose to where it hooks onto the engine. The thermostat is located inside that housing. But is the cooling fan operating? Do you see any leaks at the radiator, hoses, or water pump? The water pump should have a "weep hole" and coolant will be coming out of it if the water pump is defective. Hopefully, it is the thermstat, that is an easy fix. Hope this helps and good luck.
Jul 15, 2009 | 1993 Chevrolet Caprice
Excessive smoke coming from waverunner exhaust
is their a trick to putting on exhaust 1998 waverunner xl 1200?
May 27, 2009 | Yamaha 12V Air Pump
Miscellaneous Logo
26 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
