Question about Garden
Need a new opc cable
Its the cable from the dead mans handle which cuts off the engine
    Top Expert:
  • Garden Master
  • 41,482 Answers
Google make/model/parts
Posted on Apr 09, 2015
How do I fix the speed control on an Ariens walk behind lawn mower?
do you mean the throttle cable? as its a push mower im gussing it is. If the mower is relatively new then it will be fitted with an opc (or dead mans handle) in which case there is no need for a throttle control as the engine speed is governed and should only be used at the fixed goverened speed
Apr 08, 2016 | Ariens 21 In Classic Walk Behind Push Lawn...
Problem Starting Mower
if the brake cable does not disengage the brake all the way the pull cord will not work properly.It will seem stuck.
Apr 02, 2015 | Gcv160 Gas Engine
Why wont my Flymo qs 46sd rev ?
does it have a throttle cable fitted?? you really dont need an idle as as soon as you release the opc or dead mans handle it will cut out anyway. engine should be reving at 3000-3100 rpm. if this mower has a briggs and stratton engine fitted, remove the air filter and check the spring and linkege is still attached to the air vane govenor
May 20, 2014 | Garden
The string is hard to pull
Make sure the 'Dead Man's Handle' (OPC control) is operating correctly. If not, you're fighting a flywheel brake (and the ignition will be grounded)!
Aug 17, 2013 | Garden
Throttle cable assembly
The cable you are trying to replace is the OPC cable (engine brake cable), not a throttle cable like you are trying to fit. You need to take it back and get an OPC cable, which will have the correct end on it to fit into the bracket on the side of the engine.
May 19, 2013 | Garden
Cord won't pull more than a few inches on new mower. Seems locked up. I've only ran it once.
Ensure the cable for the dead man switch is not kinked. Follow the cable from the handle to the engine. There are 2 bolts that mount the dead mans switch to the engine , remove bolts, remove dead mans switch from engine, let hang, try starting. If starting, clean dead man contacts and reinstall. You may have to remove recoil rope assembly and engine cove to get to dead mans switch.
Jul 04, 2012 | Troy Bilt 5.5hp Self Propelled Mower
How to take up slack on mower throttle cable
My first question is why is there slack in the cable? If it's just the outer housing is drooping away from the handle where it runs down to the engine, you can use some plastic wire ties, or electrical tape, or for a short term fix, even twist ties (like for bread sacks).
The outer part of the cable should be clamped down near the throttle control. Loosening the clamp and moving the outer housing back towards the handle will take up looseness in the inner cable.
If it's a new cable, you may need to pull the interior cable out at the engine end and shorten it by cutting with pliers. Most cables have a solid wire in the center. The cable fits into a small hole on the throttle arm. There should be an "L" shape on the end of the wire--if you cut it off, make sure to leave enough room to make another the L-shape in the end of the wire--it's what keeps the cable from sliding around in the hole.
Jun 25, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Encore Premier 36 walk behind- safety switch connection problem
you can adjust the handle not the switch try and swapping the switch with the other side and see if the problem follows the switch
May 12, 2012 | Garden
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
