Question about Health & Beauty
My hair straightener LED display shows a lock symbol. What do I need to do?
  • 1,309 Answers
Oftentimes on the brands I'm familiar with you press and hold one of the buttons for a few seconds and it will unlock.
Posted on May 27, 2015
3 Suggested Answers
  • 67 Answers
SOURCE: If you straighten your hair with a hair iron do you need to use a protection spray?
Yes - the heat from hair irons can really dry out your hair which is why you shouldn't do it every day. Also you should use a protection spray. Buy a good quality spray, it will last you quite a while and really make a difference.
Posted on Feb 20, 2013
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
Bottom oven stopped working there is a key symbol showing on the panel what is wrong ?
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock.
Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Oct 04, 2014 | Bosch HBL 5056 Electric Double Oven
Does anyone have any good tips for straightening hair? I am new to this.
1. Make sure your hair is dry
2. Use oils
3. Prep the flat iron at the right temperature
4. Straighten your hair with your overall style goal in mind
5. Brush don't comb!
6. Add volume
rehost_2016_9_13_0dc297ae-7caf-4215-b998-71d5ca0093eb-fblmica31ak52inb20judn4s-3-0.jpg
Feb 20, 2013 | Health & Beauty
How to unlock a remote of an ac, whenever i am pressing the on/off button of the remote it is showing the lock symbol in the led display, please help as i am unable to operate the ac at all
its very simple.just remove the batteries and wait for a while. then put the batteries back and the remote should return to its normal state......
Jun 24, 2011 | Whirlpool ACC108PS Air Conditioner
How do you use a conair straightener? what does the dial with the numbers mean?
The settings 1-10 are for wet and easy-to straighten hair. Like hair that is a little thinner or almost straight.
The settings 11-17 are for damp hair that is about average thickness.
The settings 18-23 are for hair that is thick or wavy.
Lastly, the settings 24-30 are for dry hair that is harder to straighten.
So, the higher up you go, the higher the difficulty the hair is.
Hope this helps! :]
May 31, 2011 | Conair Health & Beauty
I need directions on how to use the Revlon ceramic Straightener model RVST2024
I love my hair straightener. It doubles for a clean modern straight look to sexy voluptuousness Kim Kardashian curls without going to the salon. If you do it right your hair will look professional and feel so soft.
1. Clean and Wash Hair: I always like to have clean hair before I style it, it isn't necessary but it makes me feel more refreshed.
2. Make sure your hair is dry. I prefer to air dry because it is the healthiest way to not damage your hair. But if you want to get more volume, using the blow dryer works well.
3. Before using any straightener make sure you get heat protector gel or spray because this will help make sure your hair does not become damaged when styling.
4. I like to split my hair up into sections to get them out of the way by using hair ties or hair clips. Sectioning your hair also helps a lot of if you have specific styles you are going for.
5. Finally, do not turn on the straightener too high because it's a sure way to damage your hair. Instead, consider low-med. If it's your first time, don't rush it because you will get burned. Give yourself an hour or more! Learning how to do it the first time can be frustrating and it doesn't always look great the first time. With some practice you can also create curls with a straightener as well.
Other tips: They have specific wet-dry straightener which can be used on wet hair but unless you have those, do not use the straightener with your wet hair because it'll give you split ends and damage your hair.
Here are some more tips for straightening that might be useful for you.
Dec 18, 2010 | Health & Beauty
Bosch classixx 6 1200 express is showing a key symbol in the LED - when I switch on the washing time goes back to 0 and the alert sounds and I cant start the wash I dont know how to switch the key...
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Aug 19, 2010 | Bosch Washing Machines
Wot colour should the guage on my bmw 316 be wen needing changed
Gauges reads as follow
Green LED = The fewer displayed closer to next service
Yellow LED = In conjunction with OIL SERVICE service or INSPECTION comes on when next routine service is due.
Red LED = a routine service is overdue.
Clock symbol in conjunction with INSPECTION = shows that an anual inspection is due.
Jan 16, 2009 | 1996 BMW 318
What the difference betwen conair wet-dry ceramic straightener and the infinity nano system
the differnece is that rhe wt-dry ceramic straightener is only 20% ceramic and burns your hair while the infinity nano system straightener is better but still leaves your hair with a burnt smell. If you have that burnt smell it means your hair is frying. Use a damage repair shapoo and conditioner
Dec 25, 2008 | Conair MN250CS Hair Trimmer
My hair straighteners will not come on. I have changed the fuse and this made no difference
see that happened to me u just have to thro it away and get a new one trust me it wont work again 3 of my family memeber r butician hair ppl or whatever salonist wehatevea u wanna call them so i get free straightener hair dryers and stuff so i dont have to worry :)
Dec 20, 2008 | Conair Professional Ceramic Hair...
Health & Beauty Logo
951 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
