Question about Ricoh Office Equipment & Supplies
There is a Ricoh 3235c developer setting error. How do I set developer units to eliminate error?
2 Suggested Answers
  • 161 Answers
SOURCE: my ricoh 3235c copier had image problem, one inch
Try cleaning the blade(by rubbing a piece of paper between the drum and the blade) ,also clean the charge roller(black rubber roller) with a soft clean cloth.If all else fails replace the black drum unit(It's life is 60k)
Posted on Feb 17, 2010
When i turn on the machine,error shows on the screen,development unit is not installed properly
1. Defective electrical connection for the TD sensor.
2. TD sensor not installed correctly
1. Take out the dev unit
and put it back in. If that
does not work, replace
the dev unit.
2. Press the TD sensor
firmly against the frame
of the development unit.
Jan 02, 2016 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Half copies
could be black developer unit or pcu / try printing something from doc feeder or platen glass in each single color and see if you have same problem. If other color prints find then will narrow down to items above
Aug 29, 2014 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Solid black image on Ricoh 3235C
Check exposer lamp to see if it comes on first. try printing counter report if same problem. Then could be drum unit or not getting a charge to roller on drum. then board could be bad.
Jan 26, 2014 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Faulty gradation print on RICOH AFICIO 3235C
check your driver, postscript? Or quality settings of the printer from the start menu
May 26, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
My ricoh aficio 3228c will not print in color
check your printer preference setting in computer driver you will see default set to black and white. select doc then select printer goto printer preference and select color
Feb 21, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
My Ricoh Aficio 3235c overlaps clolours when printng
With out seeing copy here is my thought either bad drum if it is streaks down copy or laser unit for yellow is out of alignment . In user tools there is a maintance tab go into it and do color alignment if it fails then could be transfer unit or laser unit for yellow will need to have a copier tech come out to fix it.
Oct 30, 2012 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
My ricoh 3235c copier had image problem, one inch wide streak down the page, so I chaged the developer unit and now it says no toner just replaced the toner too, what now? please help. thank you.
Feb 12, 2010 | Ricoh Office Equipment & Supplies
Ricoh 2045 error code SC350
It can be dirty ID sensor it retires the image unit and it cleans it… This happens when mylar of the cleaning unit is damaged…
Dec 04, 2009 | Ricoh Aficio 450 Copier
35 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
