Question about Dishwashers
How do I fix a F9 error on a DD60DCX6?
I HAD A POWER OUTAGE AND WHEN THE POWER COMPANY PUT THE POWER BACK ON, IT MISTAKEN PUT THROUGH 410V INSTEAD OF THE 240V. AFTER THIS THE ERROR F9 DISPLAYED ON THE DISHDRAWER. HOW CAN I FIX THE PROBLEM PLEASE.
  • 46 Answers
SOURCE: F9 Code after power outage - Model JGR8855ADS
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Generic:
Fault Code Interpretation Components To Check
F-1 Communication error between touch pad and ERC (clock)
Replace the touch pad or clock.
F-2 Oven temperature sensed by electronic control Replace the clock/relay board
F-3 Open oven sensor or harness. Replace the oven sensor
F-4 Shorted oven sensor or harness Replace the oven sensor
F-5 Power to element relay disabled in cook mode Replace the clock/relay board
F-7 Shorted touch pad key sensed for 32 secs. Replace the touch pad/control panel
F-8 Shorted meat probe Replace the probe jack.
F-9 Door lock safety circuit on ERC sensed Replace the door latch assembly
F-C or F-0 Communication error between boards Replace the relay board
Maytag-Maycop-Magic Chef-Jennair-Admiral: Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Posted on Mar 10, 2008
bestdarngood
  • 3037 Answers
SOURCE: F9 error message after power outage
The F9 is a door lock latch circuit problem, either the motor latch or the control/power supply board will need to be replaced.
Posted on Mar 22, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: F9 Error
You can find exploded views and order parts by entering your model number at the Sears parts site.
Posted on Dec 08, 2008
  • 13 Answers
SOURCE: My F9 displays Malfunction 8
Malfunction 8 is related to the brew unit typically. It is usually an indication of the brew unit motor having to work too hard to move the brew unit up and down. This is usually cured by disassembling, cleaning, replacing any o'rings that may be bad, and lubricating the unit, then reassembly.
I have had to do this twice on an an E75 and an E8. I finally broke down and bought seal kits and food grade lubricant for doing this. (I have only been able to buy parts from Europe online) One could by a new brew unit off of e-bay and change out the whole thing. But a simple cleaning or rebuild will typically suffice. One note. The cleaning tablets tend to strip the lubricant from the inside of the brew unit over time. Ocassionaly the seals in the brew unit will fall apart and bind up the unit. Either of these is usually accompanied by a sound of the brew unit motor straining to cycle the machine. If you are not savy in repairing it you may want to send it in. I suspect they will tell you it needs a new brew unit aand quote about $300 USD for the repair. About two hours, much patience, and about $10 in parts is most likely all it may need.
Mike
Posted on Jul 05, 2009
localwonder
  • 6784 Answers
SOURCE: range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Posted on Nov 08, 2009
Mar 22, 2008 | Jenn-Air JES8750 Electric Kitchen Range
Had power outage & when electric company put new transformer on, stove came on with this error f11 error, when open oven door it mesg goes off & on, oven wont work now
I appreciate your post, Katherine!
Based off the information you have provided your Frigidaire range is displaying an "F11" error code after a power outage. An "F11" error code stands for a shorted keypad. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not work you may need to have a professional technician out to provide proper repairs. This will prevent you from any unnecessary part purchases. Hopefully this is helpful. -Matt
May 02, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
Water heater stopped working flame kicks on but dont stay on
1) Copy following link for American/AO Smith intellivent gas control valve troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Sorry earlier answer mistaken model number for Rheem tankless instead of American power vent with intellivent gas control valve.
2) Reset gas control valve, using troubleshoot manuals on link above.
Check that outlet has 120 volts and 80% rated voltage.
Check that outlet has correct polarity, and is grounded.
Check that ground is connected to manifold tube under the gas control valve.
Install whole house surge protector to protect appliances with electronic controls. Simple power outage can knock out gas control valves.
Jan 29, 2013 | American Water Heater PVG62-40T42-NV 40...
F9 whirpool range
I had a power fail & when the power came back on I had the F9 error code on my range with a beep beeping that would not stop until I pressed cancel, beeping stop however F9 error code stayed on, I solved the problem by turning off the power, then turning power on again and then I pressed start button and it removed the F9 error code and all is working GREAT now...
whzurdaddy...
Feb 26, 2012 | Whirlpool Kitchen Ranges
Amana ACF3325A Gas oven, F9 error won't go away
The door latch switch has failed. Probally from the power outage. This is easy to replace and inexpensive. You can enter your model # at www.appliancehelponline.com for diagrams and illustrations.
Apr 29, 2010 | Amana ACF3325 Gas Kitchen Range
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
Envision Monitor doesn't turn on.
monitor has sustained damage from the power fluctuation's from the outage I would report it to your power company they are obligated to replace any damaged equipment that may be damaged because of their failure to provide non outage service and then go take the monitor to a repair center they can determine if the boards internally were hit with a power spike and damaged, meanwhile while you send the report to the power company you can either buy a new one and then submit the price for refund from the power company
May 01, 2008 | Gateway FPD2275W LCD Monitor
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Tatung LCD television
The power outage simply precipitates a pre-existing flaw in the power supply unit of this TV. You will need to either order a new power supply and put it in yourself, or send it to Tatung to fix. I had the same problem. Contact this person:
Vila Khamkathok
Customer services supervisor
Tel: 800-827-2850 x161
Aug 06, 2007 | Tatung V30DMTT 29.6 in. LCD Television
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
Owen Barnes
