Question about Scotts Roundup GC 280 ml Liquid Concentrate Weedkiller
How much concentrate liquid do I add to make a litre of ready to go liquid?
If i have a concentrated formula of 1 qt of liquid how many ounces of this concentrate would it take to make 2 eight oz solutions per day for 8 days?
you have posted in the wrong section but my maths is pretty good so hope this helps.It would be much easier and more exact if you made up the whole amount then decant into 8oz containers, you have a quart =2 pts so will need 6pts to make the gallon , which i expect you already new ,if you must do it the other way then use 2oz of the concentrate and add 6oz of water
Nov 10, 2014 | Cars & Trucks
Glysophate How much to use in 6 litre spray
This depends on the exact product which you bought. It is available from ready-to-use to very concentrated forms, as well presumably in solid (powder or crystals) form. You should follow the instructions on your package. If none are available, dispose of the weedkiller safely (do not pour it down the drain, take it to a garden centre - I would hope that they would not just do the same !!), and buy new. It is a poison !
12.August.2014
Aug 12, 2014 | Garden
How many mg is 10 ml?
If it's liquid, 10ml is generally assumed to be about 10mg... but that's TOTAL volume. If you're measuring medicine, the CONCENTRATION of that medicine may significantly change that number. If the concentration is 100%, the number will be pretty close. If the concentration is 0.01%, though, that number will only be 1/10,000 as much as you might think if you didn't take conctration in mind.
Aug 01, 2014 | Benadryl Childrens Allergy Liquid Cherry 8...
Ph calculation
Number of moles [H+] in first solution =concentration of [H+] in mol/L times the number of liters. [C1]=10^(-pH)=10^(-3) mol /L
Number of moles N1=10^(-3) mol/L * 1L= 10^(-3) mol [H+]
Concentration [C2] of second solution
[C2]= 10^(-5.5)=3.16227766*10^(-6) mol/L of [H+]
Number of moles of H+ in second solution
N2=[C2]*10 L =31.6227766*10^(-6) mol of H+
Total number of moles H+ in the new solution
N=10^(-3) +31.6227766*10^(-6) =1.031622777*10^(-3) mol
Concentration of H+ in new solution
[C]=1.031622777*10^(-3) mol / (1+10) L=9.358388878 *10^(-5) mol/L
Resulting pH=-log( 9.358388878 *10^(-5) =4.02787
pH is 4.03
Jun 15, 2014 | Office Equipment & Supplies
I cant read the instructions
If it is extended control Round-up, it should be ready to use! Make sure not to use it close to any trees or bushes, as it can damage or kill them! (hint: add a squirt of dish soap into the container to aid in coverage on the leaves) If its concentrate, mix it at 6 fluid oz. per Gallon. Most "ready to use" containers come with a sprayer, as concentrates do not. Happy spraying!
Sep 24, 2011 | Roundup MS5700010 1GAL ROUNDUP CONTROL 1...
How do you refill roundup pump and go
The Pump N Go can be refilled with either the Roundup Super Concentrate or Roundup Ready To Use Plus Refill Bottle.
To refill the Pump N Go with the Roundup Super Concentrate (purple cap), add 6.5 fl oz of the Super Concentrate to container and slowly fill with water.
To refill with the Ready To Use Plus Refill bottle, just slowly fill the Pump N Go with the refill container.
We do not recommend using Roundup Concentrate Plus (red cap) to refill the Pump N Go because it has different active ingredients and different information regarding use around edibles.
To open to Pump N Go container, please follow the directions below:
Stabilize container by holding between your feet
While holding the pump handle push down slightly and turn left (the pump will be out of the locked position)
The first time it is opened it will be difficult to open because for shipping safety the top is but on very tightly at the factory.
If you have any further questions, please contact us at 877-465-5160.
Hilary @Roundup
Aug 29, 2011 | Roundup "" Weed & Grass Killer
My wife just received "8PK
google it i am sure it will be there
Jan 13, 2011 | Ojon 2 Swa+ Concentrated Liquid hair...
What kind of coolant do i use in my 2002 pt cruiser?
eythelene glycol ,any make any colour its all the same stuff ,pure is best rather a diluted solution as it works out cheaper to buy 5 litres of concentrated and dilute it than a ready mixed stuff and pay for the packaging ,you can use the concentrated neat into teh rad it will not hurt it ,in fact its better for teh vehicle as will allow the cooling system to corrode
Nov 14, 2010 | 2002 Chrysler PT Cruiser
I need step by step instrucions on how to dissolve.
You need a solvent: the substance in which you want to dissolve (water).
You need a solute: the substance you want to dissolve (sugar, salt, instant coffee)
The solvent is of much larger quantity than the solute: 1 liter of water (1kg) to dissolve 50 g of sugar.
In a container (graduated cylinder, a bottle, a flask,) you put a small quantity of water and you pour a portion of the solute (in liquide form or a powder), and you mix thorougly without splashing liquid on your face or your clothes. As the solute dissolves, add some more water and some more solute. Mix the whole. Keep doing that until the prescribed quantity of solute has dissolved. Then add the necessary quantity of water to complete the (prescribed) final volume of solution.
If the solution has a final volume of 100 ml and it contains 25 g of solute you can say that the concentration of your solution is 25 g/100 ml. That is one of several ways to evaluate the concentration.
Generally speaking the concentration of a solution is defined as the ratio of the quantity of solute per quantity of solution.
Do not forget to wear your safety goggles (on top of your eyeglasses) , your lab coat, and your lab gloves.
Hope it helps.
Sep 29, 2009 | The Learning Company Achieve! Math &...
Spots on clothes
By spots I'm guessing that this is a permanent mark on the cloth. If that's the case, you are possibly putting concentrated liquid bleach into the machine...it is being added and causing the spots. Solution is to dilute the bleach or other concentrated cleaner. If you're adding it manually through a hopper...add it later in the cycle.
If the spots are black...you may have a bearing leak into the machine. Repair is a big job.
Dec 02, 2008 | Kenmore Elite 45986 Front Load Washer
Scotts Roundup GC 280 ml Liquid Concentrate Weedkiller Logo
280 people viewed this question
Top Scotts Garden Experts
Rod Doney
Rod Doney
JOHN PACE
JOHN PACE
Are you a Scotts Garden Expert? Answer questions, earn points and help others
