Question about Makita Tools & Hardware - Others
Why does it stop working after 10 minutes chipping ?
I installed a Woods 59720 timer switch to control a small bathroom fan. First time I turned it on 5min cycle it worked fine. Now, it runs only 10-15 seconds, then turns off. Set for maximum 30 minutes, it...
I looked it up and it sounds like your unit is defective. It should run for 5, 10, 15, or 30 minutes. There are no "seconds" options. The timer chip/module may be defective.
Gary
Sep 04, 2011 | Woods 59720 Automatic Wall Switch Timer...
Passlock dont starter
The Passlock system is notorious for failing. There are 3 different parts of this system that can shut down the car and activate the Antitheft security system. The problem will be one of these 3 things. The key. the ignition lock cylinder, or the TDM. The easiest one is the key. The key will either have a small black chip in the key shaft or a transponder hidden in the key head. If there is a chip, they are known for wearing down and not reading correctly. Try wiggling it, cleaning the chip with alcohol, and taking all other keys off the key chain because it pulls on the key and causes problems. If you have no chip and instead a transponded key, (it will have a little "+" sign by the plastic) you can try performing a relearn procedure. It goes like this.
1. Perform a security system relearn.
2. Let the vehicle sit for more than 10 minutes with the key off.
3. Attempt to start the engine, leave the key in the run position monitoring the security system indicator.
4. After 10 minutes, the security indicator will change state.
5. Turn the key off and wait 10 seconds.
6. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
7. After the second 10 minute timer has expired, turn the key off for 10 seconds.
8. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
9. After the 3rd 10 minute timer has expired, shut the key off for 10 seconds.
10. The security system will relearn on the 4th starting attempt and the engine should start and run.
If that doesnt work, you will need to start replacing parts. Like i said, there are 3 parts. The key, the ignition lock cylinder, and the Theft Deterrent Module (TDM). all of these are involved in the Passlock system and could be responsible for shutting down the vehicle. And trust me they are all expensive. I always share this link for this problem because there is so much information on there and will be helpful no matter what you decide to do. If all else fails, there is PERMANENT FIX for this problem. You can bypass all aspects of the system and never worry again. That is also on this link.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 19, 2011 | 1997 Oldsmobile Achieva
Security light is on and the car wont start
Try removing the negative battery cable and charging the battery full. Then hook it back up and wait 10 minutes or so. If this fails try having the key checked as these keys have a chip in them and the chip can stop working. Most high end Key shops can make you a new Key if that is the problem.
Aug 12, 2011 | 1995 Pontiac Bonneville
Tried a key with out a chip and a security lite came up and stayed on continuously
Yes, your car has gone into antitheft mode. This happened because you put the non chipped key in. go to this link. Do the "quick fix" 10 minute procedure with the correct key. If this does not fix the problem, do it 3 times with out trying to start it in between cycles. If this does not work, id be looking into the bypass procedures listed. Bypassing is extremely less expensive than fixing. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jun 08, 2011 | Oldsmobile 88 Cars & Trucks
It plays for about 30 minutes and then just stops, as if overheating. After a cooldown period, it starts up again for another short period. Suggestions? Any recommended vents I could cut in...
The small Fender products often have a TDA2050 power chip in them. The chip is on a thin aluminum heatsink and is intended for light use. If you try to sound like a bass guitar amp with this, the chip will go into thermal protection mode. Cutting vents will not help very much, and pushing it to these levels will destroy the speaker eventually. If you need more power, buy a bigger amp. This one would be suitable for a 10 foot by 10 foot room.
May 24, 2011 | Fender Musical Instruments Corporation...
2001 monty carlo changed battery securty light flashing car wont start. car ran great before any trick or code i dont know to get it to start
Leave the key in the run position until the security light stops blinking. This should take 10 minutes. Then turn the key off, wait 5 seconds and try to start it. The security light should be blinking again. Leave the key on again for 10 minutes. Repeat this 3 times. After the third time on the the next start it should start and run fine. This will reprogram your theft system.
Feb 06, 2011 | 2001 Chevrolet Monte Carlo
I drove the car to my mothers yesterday, went to my dads got there just finr. We went to leave and the car won't start turn over nothing. The security light is flashing. My dad could get it to start from...
you need to get a new ign. lock cylinder and chip key. Or you can get a lock cylinder and copy your old key with a regular key no chip. Take new cylinder, put old chip key in it. Plug into harness at the bottom of steering column just behind the dash, fine orange wire from existing one in the column. Hide lock cylinder under dash and start car with copy of old key.
Dec 26, 2010 | 1991 Buick Park Avenue
SECURITY LIGHT COMES AND CAR WILL NOT START FOR ABOUT 10 MINUTES UNTIL SECURITY LIGHT STOPS FLASHING. WHAT CAN WE DO TO FIX THIS?
Does the ignition key have a chip? If so, then the chip and or key is dirty. Carefully clean the key and around the chip. Be careful not to wet the chip or break during cleaning. That should clear up the problem.
Feb 17, 2010 | 2004 Oldsmobile Alero
Programing ignition key for 2000 grand am security light comes on and the car will not start for 10 to 15 minutes.
Turn the key on and wait for the security light to stop blinking (may take about ten minutes). Then turn the key off and wait for at least one minute. Then try to start. That should program the key chip.
Sep 24, 2009 | 2000 Pontiac Grand Am GT
Won't start, security light blinks for 10 minutes
there is a computer chip in the lock cylinder that goes bad ,so change the key and cylinder,then leave new key on until the light stops flashing about ten minutes this will set your new key to the security system hope this helps
Feb 06, 2009 | 1999 Pontiac Grand Am GT
Tools & Hardware - Others Logo
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
