I connect wires of switch botton to the mother bond of desktop but is not switch off
    New Friend:
    Problem Solver:
  • 7 Answers
There are several tutorials on youtube about how to plug in those connectors. here's a tutorial on how to fully build a computer. How to Build Gaming Computer 2014
skip to 7:01 to see where to put the power button inputs
Posted on Apr 11, 2015
    Brigadier General:
  • 3,400 Answers
WRITE MOORE CLEARLY.
Posted on Apr 09, 2015
Wired in 5224 switch using (1) white wire and (3) black ones and it popped the breaker. I switched the wires and now both toggle switches control same light. The previous switch controlled a light and a...
10-25-12
Copy following link for wiring diagrams for Leviton double switch.
http://waterheatertimer.org/How-to-wire-switches.html#double
Only 3 wires will connect to switch. Not 4
If you blew breaker than you connected Neutral wire to switch.
Neutral wire never connects to switch.
Identify Hot wire.
There is only one Hot wire that carries power to switch box.
This wire connects to one side of device ... which side? ... the side where both screws are bonded together.
Oct 25, 2012 | Leviton Electrical Supplies
I have emachine t seris t2862 desktop and I donnot know how to connect power swich in mother board please help me
On the motherboard there will be a small set of connectors marked FPANEL, next to each of these will be a set of letters (usually PW, RES, HDD, MSG) and an earth pin, From the power switch you will see a two wire set normally black and white ending in a connector, this connects to the PW pins on the FPANEL
Jan 06, 2011 | E-Machines eMachines Refurbished EMA...
Emachine d2880 power on switch is bad. How do I work around? Is there a way to short the pins on mother board to turn on my PC? In words do you have connection details for power on switch wires to mother...
In your computer you have a power switch located on the PC chassis, you will find two wires coming off of it. At the end these two wires you should find a black 2 pin push plug. This should be connected to your mainboard. On your mainboard, the header for LEDs, hdd, power etc, you should see two pins labled power. Switch push plug goes over these two pins or these two pins labeled power can be shorted with a screwdriver, however this can be risky as it is very easy to touch other pins in the process and kill the mainboard. Rather use a push plug!
You can also read my guide as your computer my not be POSTing, my published guide is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
All the best!
damnor01
Nov 22, 2010 | E-Machines eMachines Desktop PC
Where do you remove the Ground Neutral bond on a EU6500is generator? I need to do this to hook it up to a transfer switch as per Service Bulletin #20.
Page 39 of the current owners manual for the both EU6500 and the EM5000 generators indicate that there is not a neutral ground bond on these units.
Per the wiring diagram, the ground pin on the outlets is connected to the frame ground of the generators (on both generators). To have grounded electrical service, a bond wire would connect the generator frame to the ground terminal on the transfer switch. The ground system from the breaker / distribution box (usually to a ground rod) then serves as the electrical ground for the generator, as well as the balance of the rest of the system, satisfying NEC requirements.
See Page 39 in both manuals:
EU6500 EM5000
"The system ground is not connected to the AC neutral
wire. If the generator is tested with a receptacle tester, it will not show the same ground circuit condition as for a home receptacle."
Sep 22, 2010 | Honda Transfer Kit for EM 5000iSAB and EU...
Power switch
When looking at the motherboard, position yourself so that the RAM slots are running vertically on the right side of the board. The PCI and AGP slots should be running horizontally on the lower left side of the board.
In the bottom right of the board, you will see a block that has 9 pins, a row of 4 on the top and a row of 5 on the bottom.
The middle pins, one above the other, are the power button connectors. Insert your PWRBTN# on the top and the GND wire onto the botton pin.
May 01, 2010 | Asrock P4i65G Motherboard
My computer wont turn on
take out the psu completely from the cpu/tower, plug in the power cord,if there is a switch on the psu turn it on, next locate the main power connector (24pin) and find green wire,take a piece of wire and insert it into the green wire connector,next touch the other end of the wire to the psu outer case or a black wire on the main connector,if all is well the psu will turn on,if you have a dc voltage tester check the voltages on the red and black wires on molex connector...5vdc,yellow and black...12vdc.if ok look at the main board and inspect the capacitors to see if they are swollen, if ok
replace psu and disconnect hdd,cd/dvd,floppy ect from main board only leave memory,processor and video, power on if ok shut off and reconnect hdd, power on, if ok shutoff and connect floppy, if ok power off and connect cd/dvd drive.during this testing you will know what is bad.let me know how it turns out.email; arjoon.ken@gmail.com
Feb 19, 2010 | Computers & Internet
Wireing thee wire to four wire,small metal tab between ground and middle wire.?do I take it off?
If you have a 3-wire appliance and you are replacing the 3-wire cable with a 4-wire cable, yes, you _must_ remove the metal tab (bonding strap) that is connected from the white wire on the terminal block to the frame.
Connect the black, red, and white wires to the terminal block, then connect the green wire to the frame using the green screw.
Usually the bonding strap stays under the (green) screw without being connected to the terminal block so should someone need to connect it back to a 3-wire cable the bonding strap will be there.
Jan 13, 2010 | General Electric Stove/Oven/Range Chrome...
On and off connection to board
The wires from the on-off switch only go to the power supply. From the power supply there will either a 10 or 14 pin connector that is plugged into the motherboard.
Feb 25, 2009 | E-Machines eMachines Desktop PC
How to connect Power LED, Power SW, Power Reset and HDD LED
it is written in the motherboard..
re-reset botton
pw- power botton
hdd led- hard disk led
pw LED- power led
the code is pin 1....
Jan 28, 2009 | Zerus Intel Desktop Board D815EEA...
Emachine 2685 no power up
from the spec of the motherboard it should be one of the pin headers near the Bios battery (looks like a coin on the mobo)
hopefully (if you look close enough) it should be marked pwr
Oct 13, 2007 | E-Machines eMachines W2686 PC Desktop
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
