Question about Music
I have a guitar that I received with the battery jacket missing.... does the wt-92 run on a 9v battery? and where can I get a new jacket?
Replacing the battery
It is easy to replace the battery in your Washburn guitar.
The battery compartment is located where you plug in an instrument cable to your guitar. Simply open it and take out the old battery and put in a new 9V. battery.
Regards
Sep 05, 2014 | Washburn WD10SCE Cutaway Acoustic-Electric...
We need to change battery
The battery should be located in the control cavity of the guitar. It is in the back of the bass. Usually 4 screws holding it on. Inside your 9v battery will be located. Good luck
Feb 22, 2013 | ESP LTD Surveyor-414 Electric Bass Guitar
My MT-2 wont distort my guitar.
A few things to try....
Usually the adapter will over ride the battery when used.
1) Make sure your 1/4" cables are working properly without the pedal "in-line".
2) Take out battery, and use just the adapter only. Make sure it is the correct and proper adapter that works with Boss. Usually the PSA-120. If you are not using a Boss Adapter, make sure yours is a direct replacement with same specifications. 9V/200mA. And "tip negative". DO NOT use Radio Shack stuff, nothing against them, but there adapters just don't mix well with Boss products and the like.
2) Try just the battery, no AC adapter. Remember to unplug the input when not in use. Saves battery.
Basic rule of thumb...when using correct AC adapters for all your pedals all the time, and all sounds good, then take out the batteries.
If you still experience problems, it would be an internal IC chip most likely. From there post another question maybe.
Apr 01, 2010 | Boss Mt 2 Metal Zone Effects Pedal
Washburn acoustic electric guitar eq & turner system wt-92 how do you use it for tuning
Try this site:
Select the lesson on "Tuning Machines"
This looks like a good resource for information.
Dec 15, 2009 | Washburn D10sbc Acoustic Guitar
Can't figure out where the batteries go on yamaha AP500 acoustic electric guitar. I unscrewed the small little box and pulled out a bigger box with no obvious batteries in sight.
If it is an APX-500, the battery is in a holder between the neck and the tuner on the curved sides of the guitar. It should unlatch. The battery (9V) goes into the holder and is inserted and latches.
Oct 15, 2009 | Yamaha Music
I'm think about buying an alexi 200 guitar, but i want to replace the esp pick up for an emg 81. Is there a place for the battery the pickup will require?
There should be enough room inside for the battery. If there isn't you could do some routing to the body to make it fit. I personally don't have this guitar but more than likely you can position the 9v battery to fit. To keep it from moving around, you can put a piece of sponge in the cavity.
Jun 09, 2009 | ESP Ltd Alexi 200 Electric Guitar
Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
Music Logo
23 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
