How do I get my fx 991es to calculate the antilog 0.69/2.3?
  • Office Equip... Master
  • 8,073 Answers
Use SHIFT Log (0.69/2.3)
How do I get my fx 991es to calculate the antilog  - 25636840-evidcyi5elrxnpoifo1rvuyf-5-0.jpg
Posted on Jul 03, 2015
SOURCE: I need to find the antilog to -6.80 on a casioi fx-300ms calculat
Alot of people have this doubt, so I might as well make it clear.
Press the 10^x button (while pressing SHIFT, of course; it's exactly above the LOG button) followed by the number whose antilog you desire.
Example :
Let's say we need antilog(-6.8),
1. Press SHIFT, followed by LOG (i.e 10^x); this'll display a 10 on the screen;
2. Type in -6.8;
3. Press "=";
4. This'll display 1.584893192x10^-7 as the solution, which is correct!
5. Bye, lol :P
Posted on Apr 09, 2009
  • 8073 Answers
SOURCE: mode change
Just so that we know what we are talking about. The natural display is the display mode in which fractions appear on two lines, radicals appear as radicals, log can be calculated in any base, etc. If that is what you understand by Natural Display, we are in agreement.
To set this mode, you turn calculator ON and press [SHIFT][MODE] (setup). The option is called MathIO, and it has the number 1.
Thus [SHIFT][MODE][1:MathIO].
Hope it helps.
Posted on Oct 13, 2009
SOURCE: how can we do linear interpolation in casio fx-991ES calculator
how solve interpolation by casio fx 991 ex
Posted on Nov 28, 2010
  • 8073 Answers
SOURCE: How do i calculate antilog
For common logs (logs in base 10) use the 10^x function : Press [SHIFT] [Log] to access it.
For natural logs, use the exponential function. Press [SHIFT][ln] to access it.
Posted on Dec 03, 2010
SOURCE: Casio fx-991ES, how to calculate
At a blank screen, enter your IRR formula in terms of the variables using ALPHA and ')' for variable X. For example: -1000 200/((1 X)^1) 200/((1 X)^2) ... rest of subsequent years. Then, press CALC. It will prompt you to enter values of your variable (X in this example). Don't worry if there's already a value displayed - this is just the most recent value that has been stored as that letter. Simply enter your value (in terms of your IRR guess) and then press [=]. You will have to repeat this for each IRR guess until you reach almost ZERO.
Posted on Sep 19, 2011
Combinations on fx-991ES
Press [SHIFT][ division key]. It is marked with nCr.
May 03, 2014 | Casio Brand New-Fx-991es Plus - Scientific...
Is there a verify mode on the CASIO fx-991es plus calculator?
You should try to explore the calculator to find its capabilities. You can also read the manual. Everything is in it.
Press the Mode button, then the down arrow key. On the second page of the mode list you find 2:Verif
Mar 23, 2014 | Casio Brand New-Fx-991es Plus - Scientific...
Find antilog on es991
The natural logarithm function, denoted ln(x) has an inverse function called the exponential function, denoted e^x. That is what you call the antilog (I prefer the euphony of the exponential).
On calculators the two functions share the same physical key: One function is accessed directly and the other indirectly (SHIFT, 2nd F, or 2nd)
On the Casio FX-991ES the function ln and e key is the the one above the tan key.
The common logarithm or logarithm in base 10, denoted log(x) has an inverse function, the power function in base 10 or 10^x. In your terminology this would also be an antilogarithm.
The common log is accessed by pressing the log key to the left of the ln key, and the 10^x function is obtained with the sequence [SHIFT][log]
Note: The Input/output mode in the foregoing screen displays is the MathIO mode.
Dec 21, 2013 | Casio Office Equipment & Supplies
Calculators fx algebra
The FX-991ES Plus barely handles simple operations on matrices of dimensions up to 3X3. It cannot find eigenvalues or eigenvectors.
Oct 24, 2013 | Casio Brand New-Fx-991es Plus - Scientific...
I use casiofx-991ES,its numbers looking upside down.How can i fix it?
I had the same problem with my casio fx-991ES calculator, i tried initializing the calculator by keying in shift9(CLR)3(all)=(yes) but that didn't fix the display,so i opened the calculator and removed the battery for about 5days then put the battery back guess what the display started operating well! no more inverted display or numbers.if initializing the calculator does not fix the problem,take out the battery for some few days then put it back in that should fix the problem.cheers
Sep 27, 2013 | Casio Fx-991es Scientific Calculator
I need help with the fx-115 ES on how to find what to hit to input calculation for antilog
Use the shifted function of the appropriate log key (log for common (base 10) log/antilog and ln for natural (base e) log/antilog). For example, to calculate the common antilog of 2, press SHIFT log 2 = and to calculate the natural antilog of 2, press SHIFT ln 2 =.
Apr 09, 2011 | Casio FX-115ES Scientific Calculator
Will the CASIO fx-300ES find the antilog? If so, how do I use this function?
Antilog is a somewhat outdated terminology for the inverse function of the logarithm.
To calculate on your FX-300ES the base 2 antilog of 4, key in
Correct result is 16.
Jan 20, 2011 | Casio fx-300ES Calculator
How to find out antilog on scientific calculator
To calculate on your FX-115ES the base 2 antilog of 4, key in
Jan 16, 2011 | Casio FX-115ES Scientific Calculator
How to find antilog on casio fx-991MS?
For common antilog, use 10^x, the shifted function of the log key. For natural antilog, use e^x, the shifted function of the ln key. In either case, press the appropriate function and then enter the expression whose antilog you're seeking.
Oct 26, 2010 | Casio FX-300MS Calculator
Doubts
how to calculate antilog in fx-82MS
Nov 18, 2008 | Casio FX-300MS Calculator
73 people viewed this question
k24674
jasbo
jasbo
