Question about Toshiba Televison & Video
Toshiba remote CT - 90 366. net TV, Netflix & Yahoo buttons do not work. Is there a fix?
5 Suggested Answers
cammykins
  • 149 Answers
SOURCE: Toshia CT-90157 remote is not working!
Here is the product information for your remote: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C What is the correct model# for your set?
Posted on Sep 24, 2007
IrishDruid
  • 2712 Answers
SOURCE: toshiba ct-90275 code for direct tv d10
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: Toshiba CT-877 REMOTE
F*** YoU
Posted on May 11, 2008
SOURCE: getting toshiba ct-852 to program
This remote is programed by holding the CODE button and pressing the electronic button that you want to be programed. (For example press and hold CODE and hit DVD.) After you do this you have 10 seconds to input the 2 digit program code for the electronic you want programed. If your manual doesn't have these codes you can This One on page 13.
Hope this helps
Posted on Feb 07, 2009
Where is the netflix button on Toshiba Remote CT-90354?
There isn't one. You press the Smart Button and then navigate to Netflix on the screen.
Nov 28, 2016 | Toshiba Televison & Video
Where is the input/source button
The TV/Video button at the bottom left of the Toshiba CT-859 remote toggles between the TV and external video sources. This button is below the Reset button. The CT-859 remote works for several Toshiba TVs, including the 19A24. The manual for this TV describes the remote buttons on page 6. The manual is available online at Sears Parts Direct here: http://www.searspartsdirect.com/partsdirect/user-manuals/19A24-Toshiba-COLOR+TELEVISION-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0407309.pdf .
I hope this helps.
Jan 04, 2016 | Toshiba CT-859 Remote Control 72795473
I have a Toshiba 19CV100U TV and a Toshiba CT-90275 remote control. My problem is that the dash button doesn't work so I can't put in digital channels. How do I fix this?
If your Toshiba TV does not have digital conversion built in, you will have to install a converter box and separate remote.
I have no idea what a "dash button" is or controls.
Oct 17, 2014 | Televison & Video
How do I get a manual for Toshiba remote controller model CT 90302
Hello
This remote control is for use with Toshiba 22AV500U TV. It is originally coded to use with this TV, yet other TVs also can be programmed with this remote contorl. There si no specific user manual for this remote control itself. All codes and proceedings are with the user manual for the above mentioned model Toshiba Tv. If you haven't that manual, send your email address to me by Fixya. I'll send a copy of that manual to you by return mail. Or go tho this link from where you can download the above said TVs manual for as PDF format. OK
a248.e.akamai.net/pix.crutchfield.com/Manuals/052/05222AV500.PDF
Sep 01, 2011 | Toshiba Ct-90302 Remote Control
Can I use this for another tv?
It will work, to some extent, with most toshiba tvs. You will find that on differant models, some buttons won't work and others won't do as they say but other functions, but will work 100% for same model.
Jun 13, 2009 | Toshiba CT-90157 Remote Control
Toshiba Remote CT-877 problem
I contacted Toshiba. Take out the batteries. Press every button on the remote. But the batteries back in. The remote will work because you just reset it.
Jan 10, 2008 | Jensen SC-340A Remote Control
Sep 22, 2007 | Toshiba CT-90157 Remote Control
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
