Question about iLO (2 GB) MP3 Player
Freezing If I try to start the device it shows "searching files 20%... and it freezes and does not allow to shut down unless I remove battery mechanically. I tried to resolve the problem by formatting the drive without success because it freezes my computer as well.Byambaa Jambal.
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
Evite website keeps freezing up. Both in chrome and explorer. works on another computer just fine. popups have been allowed. cookies and cache are cleared. It seems to freeze up when it's trying to...
Fixing Hardware or Software Issues
  • If the freeze happens every time a certain hardware device is plugged in or switched on, the device itself might be to blame. Check the manufacturer's website for updated drivers for the device, and download and install them to erase any bugs that might exist in your version. Similarly, if the freeze only happens when using one particular application, that program might also be the root cause. Check the developer's website for updates. If the problem persists, uninstall and reinstall the program. This process replaces any software files or settings that may have been damaged or deleted.
Overwhelming a PC's processor or memory by requests can also lead to the computer freezing up. If the issue occurs when large files or complex applications are being handled, shut down any running application or background utilities you don't need for the project you're working on. This frees up CPU time and RAM space. Within individual programs, avoid opening up multiple files or websites at the same time. If the problem persists and if opening multiple large files simultaneously can't be avoided, consider a hardware upgrade
Please follow this instruction.
God bless you
May 25, 2013 | Computers & Internet
My phone wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Sep 05, 2012 | HTC Vivid
My fm radio stopped working on my creative zen vision, and the display is all messed up. It also freezes for about 20 minutes when I turn it on. After 20 minutes, it will play normal, but it freezes...
Support for Zen Vision M on this site:
One of the Knowledgebase Solutions for "freezing" gives this answer:
Solution ID: 64087
dot-clear.gifSolution ID # 64087 -->dot-clear.gifdot-clear.gif -->
Player is Freezing
Keywords / Key Phrases: freeze, freezes, freezing, hang, hanging, freezes at creative logo, at docked screen, rebuilding library screen, playing audio files, switching to other functions or menus while shutting down, freezes at recovery mode, freezing at music playing now screen
  1. Gently push the end of a thin object (such as a pin or straightened paperclip) into the Reset hole.
    The reset button for your player is located at the bottom of the player, to the left of the sync adapter port.
  2. Refer to the article below to access the recovery mode and perform a Clean Up.
    SID 64088: Accessing the Recovery/Rescue Mode of your Player
    1. Clean Up scans a player\'s hard disk/memory card and removes any invalid links from the music library. It does not affect the working music files at all. It is recommended that you perform "Clean Up" first before formatting or reloading the player\'s firmware.
    2. It is advisable for you to clean up your player regularly if you are frequently transferring files from you computer to your player or vice versa.
Last updated: June 16th, 2009
Aug 08, 2009 | Creative Labs ZEN Vision:M Digital Media...
Installed new update to fix freezing problem - created new one
I had the same problem. Mine originally stopped at 23/92 files. Then after a cool night, I started it again in the morning and got 91/92 files loaded before it started to fail again. I left the disk in and after about 20 fails in a row, it finally loaded!!! Recommend you just leave it in there and it should work. good luck
Mar 03, 2009 | Pioneer AVIC-Z2 Car DVD Player
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Feb 27, 2009 | Sony Playstation 3 (PS3) Console
Acer 1642 freezes and will not power down unless battery is remov
sounds like a virus or malware, try this, go to spybot, search and destroy and download thier free program, also AVG. com, also free, and run them both in safe mode, also defrag your hard drive, start,programs, accesories, system tools, defrag, it may run several hours, let it a lone, first spybot, then avg, then defrag
Jan 03, 2009 | Acer Aspire 3000 Notebook
System freezes
well .... try to install a coolermod in your system...
maybe overheat problem can freeze and you need to shut down your system...
need to power up the rpm of your coller...more ventilation to control overheat..this is coolermod!
Good Luck!
Dec 05, 2008 | Sony Playstation 3 (PS3) Console
R31 freezes up
Your computer shut down due a bad battery, Need to replaced.
Replace the battery first and see if your computer still freezing.
The reason(s) you may experience computer freezes, could be software related or hardware related; perhaps it's a combination of both.
Below is a broad list of some of common causes of computer freezes.
  • Memory
  • Video
  • Device Drivers
  • Bad Motherboard
  • Bad Devices
  • System Resources
  • Software
Sep 25, 2008 | IBM ThinkPad R31 2657 Notebook
Rca th1012
I have the same problem and just used mixmaster's solution to a different problem to solve this one. Here's what he said:
e4087a1.jpg By master_s.gif mixmaster
Rank: Master
Rating: 78.68%, 258 votes
Try removing the battery and connecting it to the computer.
If it shows up on the Computer, format it.
To format in My Computer>Device Name (Lyra)>Right Click and select format.
This will erase everything on the device and allow you to start over.
Best of Luck.
Sep 29, 2007 | RCA Lyra TH1012 MP3 Player
iLO (2 GB) MP3 Player Logo
19 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
